Home » Eclipse Projects » Eclipse Platform » Build from source problem(Could not resolve dependencies for project)
Build from source problem [message #1840261] |
Sat, 10 April 2021 12:46 |
Kirill Kotovich Messages: 2 Registered: March 2021 |
Hello!
I wanted to build the Eclipse platform from the source codes for this manual: https://wiki.eclipse.org/Platform-releng/Platform_Build. Started building by checking dependencies (mvn -X clean validate) and got the following error:
[DEBUG] =======================================================================
[DEBUG] Could not find metadata org.eclipse.osgi:org.eclipse.osgi:3.16.300-SNAPSHOT/maven-metadata.xml in local (/home/main/.m2/repository)
[DEBUG] Dependency collection stats: {ConflictMarker.analyzeTime=78713, ConflictMarker.markTime=61270, ConflictMarker.nodeCount=2, ConflictIdSorter.graphTime=24137, ConflictIdSorter.topsortTime=40652, ConflictIdSorter.conflictIdCount=1, ConflictIdSorter.conflictIdCycleCount=0, ConflictResolver.totalTime=1380744, ConflictResolver.conflictItemCount=1, DefaultDependencyCollector.collectTime=5510133, DefaultDependencyCollector.transformTime=1819431}
[DEBUG] org.eclipse.osgi:org.eclipse.osgi.util:eclipse-plugin:3.6.0-SNAPSHOT
[DEBUG] org.eclipse.osgi:org.eclipse.osgi:jar:3.16.300-SNAPSHOT:provided
[INFO] ------------------------------------------------------------------------
[INFO] Reactor Summary:
[INFO]
[INFO] eclipse-platform-parent 4.20.0-SNAPSHOT ............ SUCCESS [ 4.167 s]
[INFO] eclipse-sdk-prereqs 4.20.0-SNAPSHOT ................ SUCCESS [ 0.371 s]
[INFO] eclipse jdt 4.20.0-SNAPSHOT ........................ SUCCESS [ 0.362 s]
[INFO] rt.equinox.framework 4.20.0-SNAPSHOT ............... SUCCESS [ 0.370 s]
[INFO] org.eclipse.osgi 3.16.300-SNAPSHOT ................. SUCCESS [ 11.336 s]
[INFO] org.eclipse.osgi.util 3.6.0-SNAPSHOT ............... FAILURE [ 0.295 s]
[INFO] org.eclipse.osgi.services 3.10.100-SNAPSHOT ........ SKIPPED
[INFO] rt.equinox.bundles 4.20.0-SNAPSHOT ................. SKIPPED
[INFO] org.eclipse.equinox.common 3.14.100-SNAPSHOT ....... SKIPPED
[ERROR] Failed to execute goal on project org.eclipse.osgi.util: Could not resolve dependencies for project org.eclipse.osgi:org.eclipse.osgi.util:eclipse-plugin:3.6.0-SNAPSHOT: Could not find artifact org.eclipse.osgi:org.eclipse.osgi:jar:3.16.300-SNAPSHOT -> [Help 1]
org.apache.maven.lifecycle.LifecycleExecutionException: Failed to execute goal on project org.eclipse.osgi.util: Could not resolve dependencies for project org.eclipse.osgi:org.eclipse.osgi.util:eclipse-plugin:3.6.0-SNAPSHOT: Could not find artifact org.eclipse.osgi:org.eclipse.osgi:jar:3.16.300-SNAPSHOT
I post the logs and pom.xml from the root
Thanks for attention!
Attachment: logs.txt
(Size: 5.56MB, Downloaded 133 times) -
Attachment: pom.xml
(Size: 2.38KB, Downloaded 159 times)
Re: Build from source problem [message #1844600 is a reply to message #1840280] |
Fri, 17 September 2021 09:45 |
Ingo Kappler Messages: 10 Registered: June 2021 |
Hello!
was there a solution to this? I am having a similar issue.
[DEBUG] Could not find metadata org.eclipse.osgi:org.eclipse.osgi:3.16.200-SNAPSHOT/maven-metadata.xml in local (C:\Users\user\.m2\repository)
Long:
[INFO] ---------------< org.eclipse.osgi:org.eclipse.osgi.util >---------------
[INFO] Building org.eclipse.osgi.util 3.6.0-SNAPSHOT [60/501]
[INFO] ---------------------------[ eclipse-plugin ]---------------------------
[DEBUG] Resolving plugin prefix dependency from [org.apache.maven.plugins, org.codehaus.mojo]
[DEBUG] Resolved plugin prefix dependency to org.apache.maven.plugins:maven-dependency-plugin from POM org.eclipse.osgi:org.eclipse.osgi.util:eclipse-plugin:3.6.0-SNAPSHOT
[DEBUG] Lifecycle default -> [validate, initialize, generate-sources, process-sources, generate-resources, process-resources, compile, process-classes, generate-test-sources, process-test-sources, generate-test-resources, process-test-resources, test-compile, process-test-classes, test, prepare-package, package, pre-integration-test, integration-test, post-integration-test, verify, install, deploy]
[DEBUG] Lifecycle clean -> [pre-clean, clean, post-clean]
[DEBUG] Lifecycle site -> [pre-site, site, post-site, site-deploy]
[DEBUG] === PROJECT BUILD PLAN ================================================
[DEBUG] Project: org.eclipse.osgi:org.eclipse.osgi.util:3.6.0-SNAPSHOT
[DEBUG] Dependencies (collect): []
[DEBUG] Dependencies (resolve): [test]
[DEBUG] Repositories (dependencies): [eclipse (https://download.eclipse.org/eclipse/updates/4.19/R-4.19-202103031800/, p2, disa-bled), central (https://repo.maven.apache.org/maven2, default, releases)]
[DEBUG] Repositories (plugins) : [tycho-snapshots (https://repo.eclipse.org/content/repositories/tycho-snapshots/, default, releas-es+snapshots), cbi-jdt (https://repo.eclipse.org/content/repositories/eclipse-staging/, default, releases+snapshots), cbi-snapshots (https://repo.eclipse.org/content/repositories/cbi-snapshots/, default, releas-es+snapshots), cbi-releases (https://repo.eclipse.org/content/repositories/cbi-releases/, default, releases+snapshots), eclipse (https://repo.eclipse.org/content/repositories/cbi/, default, releases+snapshots), central (https://repo.maven.apache.org/maven2, default, releases)]
[DEBUG] -----------------------------------------------------------------------
[DEBUG] Goal: org.apache.maven.plugins:maven-dependency-plugin:2.8:tree (de-fault-cli)
[DEBUG] Style: Regular
[DEBUG] Configuration: <?xml version="1.0" encoding="UTF-8"?>
<configuration>
<appendOutput default-value="false">${appendOutput}</appendOutput>
<excludes>${excludes}</excludes>
<includes>${includes}</includes>
<localRepository default-value="${localRepository}"/>
<output>${output}</output>
<outputFile>${outputFile}</outputFile>
<outputType default-value="text">${outputType}</outputType>
<scope>${scope}</scope>
<skip default-value="false">${skip}</skip>
<tokens default-value="standard">${tokens}</tokens>
<verbose default-value="false">${verbose}</verbose>
<project default-value="${project}"/>
</configuration>
[DEBUG] Dependency collection stats {ConflictMarker.analyzeTime=11101, ConflictMark-er.markTime=8700, ConflictMarker.nodeCount=2, ConflictIdSorter.graphTime=3900, Con-flictIdSorter.topsortTime=8400, ConflictIdSorter.conflictIdCount=1, ConflictIdSort-er.conflictIdCycleCount=0, ConflictResolver.totalTime=91400, ConflictResolv-er.conflictItemCount=1, DefaultDependencyCollector.collectTime=1519601, DefaultDepend-encyCollector.transformTime=147199}
[DEBUG] org.eclipse.osgi:org.eclipse.osgi:jar:3.16.200-SNAPSHOT:provided
[INFO]
[INFO] Skipping org.eclipse.equinox.common
[INFO] This project has been banned from the build due to previous failures.
Current Time: Thu Dec 26 12:52:27 GMT 2024
Powered by FUDForum. Page generated in 0.04892 seconds
