Home » Eclipse Projects » Eclipse Scout » Error java.sql.SQLException: No suitable driver found for jdbc:mysql:XXXXXXXXXXXX (After upgrade to scout 11)
Error java.sql.SQLException: No suitable driver found for jdbc:mysql:XXXXXXXXXXXX [message #1839856] Tue, 30 March 2021 06:36 Go to next message
I have the following error after upgrading to scout 11 on prod.
org.eclipse.scout.rt.platform.exception.BeanCreationException: Exception while invoking @PostConstruct method public void com.scout.app.server.db.sql.DatabaseSetupService.autoCreateDatabase() throws java.sql.SQLException
        at org.eclipse.scout.rt.platform.internal.BeanInstanceUtil.translateException(BeanInstanceUtil.java:171)
        at org.eclipse.scout.rt.platform.internal.BeanInstanceUtil.initializeBeanInstance(BeanInstanceUtil.java:106)
        at org.eclipse.scout.rt.platform.internal.BeanInstanceUtil.initializeBeanInstance(BeanInstanceUtil.java:77)
        at org.eclipse.scout.rt.platform.internal.SingeltonBeanInstanceProducer.createInstance(SingeltonBeanInstanceProducer.java:236)
        at org.eclipse.scout.rt.platform.internal.SingeltonBeanInstanceProducer.getOrCreateInstance(SingeltonBeanInstanceProducer.java:112)
        at org.eclipse.scout.rt.platform.internal.SingeltonBeanInstanceProducer.lambda$0(SingeltonBeanInstanceProducer.java:95)
        at org.eclipse.scout.rt.platform.internal.BeanInstanceUtil.createAndAssertNoCircularDependency(BeanInstanceUtil.java:149)
        at org.eclipse.scout.rt.platform.internal.SingeltonBeanInstanceProducer.produce(SingeltonBeanInstanceProducer.java:95)
        at org.eclipse.scout.rt.platform.internal.BeanImplementor.getInstance(BeanImplementor.java:98)
        at org.eclipse.scout.rt.platform.internal.BeanManagerImplementor.startCreateImmediatelyBeans(BeanManagerImplementor.java:338)
        at org.eclipse.scout.rt.platform.internal.PlatformImplementor.startCreateImmediatelyBeans(PlatformImplementor.java:242)
        at org.eclipse.scout.rt.platform.internal.PlatformImplementor.start(PlatformImplementor.java:141)
        at org.eclipse.scout.rt.platform.internal.PlatformStarter.run(PlatformStarter.java:30)
Caused by: java.sql.SQLException: No suitable driver found for jdbc:mysql:XXXXXXXXXXXX
        at java.sql/java.sql.DriverManager.getConnection(DriverManager.java:702)
        at java.sql/java.sql.DriverManager.getConnection(DriverManager.java:251)
        at com.scout.app.server.db.sql.DatabaseSetupService.autoCreateDatabase(DatabaseSetupService.java:66)
        at java.base/jdk.internal.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62)
        at java.base/jdk.internal.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43)
        at java.base/java.lang.reflect.Method.invoke(Method.java:566)
        at org.eclipse.scout.rt.platform.internal.BeanInstanceUtil.initializeBeanInstance(BeanInstanceUtil.java:103)
        ... 11 common frames omitted
This is not happening on dev environment, only when deploying to tomcat.
Database for dev is same used with tomcat and they are on same machine.
Does anyone have any idea how to solve this issue.
Kind Regards
Re: Error java.sql.SQLException: No suitable driver found for jdbc:mysql:XXXXXXXXXXXX [message #1839871 is a reply to message #1839856] Tue, 30 March 2021 12:27 Go to previous messageGo to next message
Sounds to me if the JDBC driver cannot be found for MySQL. Scout itself does not provide any dependencies to the database drivers because people may use different databases. If you add the MySQL driver as dependency (to the class path) this may help, e.g.
<dependency>
    <groupId>mysql</groupId>
    <artifactId>mysql-connector-java</artifactId>
    <version>8.0.23</version>
</dependency>
Re: Error java.sql.SQLException: No suitable driver found for jdbc:mysql:XXXXXXXXXXXX [message #1839878 is a reply to message #1839871] Tue, 30 March 2021 15:05 Go to previous messageGo to next message
No, that is not the problem, the application was working fine with version 10 and the driver exists like you mentioned, I noticed the issue after upgrading to 11.
Kind Regards
Re: Error java.sql.SQLException: No suitable driver found for jdbc:mysql:XXXXXXXXXXXX [message #1839941 is a reply to message #1839878] Thu, 01 April 2021 10:49 Go to previous messageGo to next message
I solved the issue by adding
Class.forName("com.mysql.cj.jdbc.Driver");
to the DatabaseSetupService just before calling the driver to establish the connection and it works now.
Kind Regards
Re: Error java.sql.SQLException: No suitable driver found for jdbc:mysql:XXXXXXXXXXXX [message #1839943 is a reply to message #1839941] Thu, 01 April 2021 11:25 Go to previous message
Thanks for posting your solution here!
André
Previous Topic:JS - Java questions
Next Topic:REST Client: fetching data and populating a table
Current Time: Tue Jul 01 12:51:48 EDT 2025
Powered by FUDForum. Page generated in 0.04361 seconds
