Home » Modeling » TMF (Xtext) » Content assist edit positions and template variables
Content assist edit positions and template variables [message #1837227] Mon, 25 January 2021 14:00 Go to next message
Dimo Petroff is currently offline Dimo PetroffFriend
Just wondering if I should expect these to work via LSP (e.g. in Theia) at all. In general, there doesn't seem to be any clear documentation that I've been able to find about what Xtext IDE features are supported via LSP, so it's difficult to tell what kind of feature parity to expect between the native Eclipse IDE plugin and an LSP IDE and where the gaps might be. There is not even an LSP section on the Xtext documentation website, while the Web Support section doesn't go into enough detail, and seemingly doesn't cover Monaco-based Theia, so it looks like it's wildly out of date. If I remember correctly, Web Support is basically abandoned in favour of LSP, so this makes sense, I just don't understand why there's no documentation for the LSP side of things.
Re: Content assist edit positions and template variables [message #1837228 is a reply to message #1837227] Mon, 25 January 2021 14:02 Go to previous messageGo to next message
Christian Dietrich is currently offline Christian DietrichFriend
the main reason is: nobody writes it. and nobody funds the writing.
at least templates work with vscode
https://github.com/itemis/xtext-languageserver-example/blob/f2291241f2a1e97c8ebab8187e2d30460923dee1/org.xtext.example.mydsl.ide/src/org/xtext/example/mydsl/ide/contentassist/MyDslIdeContentProposalProvider.xtend#L21
Twitter : @chrdietrich
Day Job: https://www.everest-systems.com
[Updated on: Mon, 25 January 2021 14:04]
Report message to a moderator
Re: Content assist edit positions and template variables [message #1837229 is a reply to message #1837228] Mon, 25 January 2021 14:28 Go to previous messageGo to next message
Tamas Miklossy is currently offline Tamas MiklossyFriend
Hello Dimo,
indeed, the Xtext-LSP section is still missing from the official Xtext documentation .
The corresponding GitHub issue is available under https://github.com/eclipse/xtext/issues/1141
Tamás
Re: Content assist edit positions and template variables [message #1838130 is a reply to message #1837229] Wed, 17 February 2021 06:49 Go to previous messageGo to next message
Hello Dimo,
The LSP Support section has been added to the Xtext documentation.
Tamás
Re: Content assist edit positions and template variables [message #1838244 is a reply to message #1838130] Fri, 19 February 2021 12:32 Go to previous messageGo to next message
Thanks, that makes things clearer. I was actually trying to figure out if the AbstractIdeTemplateProposalProvider API with the variable and cursor methods works in LSP, but I see that the resulting edit positions are ignored in ContentAssistService. Is there a different API available, or do I need to hard-code the variables in my templates using the LSP snippet syntax?
Re: Content assist edit positions and template variables [message #1838248 is a reply to message #1838244] Fri, 19 February 2021 13:50 Go to previous message
yes there is no AbstractIdeTemplateProposalProvider in LSP.
Previous Topic:Display DSL code generation errors in Eclipse
Next Topic:Rename fails if cursor is behind identifier
Current Time: Mon Dec 30 14:36:36 GMT 2024
Powered by FUDForum. Page generated in 0.06070 seconds
