Home » Eclipse Projects » GEF » Access restriction on draw2D.jar
Access restriction on draw2D.jar [message #183409] Thu, 02 June 2005 14:36 Go to next message
Skhiri Sabri is currently offline Skhiri SabriFriend
I have just upgraded to 3.1M7, and now the draw2d.jar is not accessible
any more:
Severity Description Resource In Folder Location Creation Time
2 Access restriction: The type AbstractLayout is not accessible due to
restriction on required library
/home/sabri/compiler/previewM7/eclipse/plugins/org.eclipse.d raw2d_3.0.1/draw2d.jar
Thanks !
Sabri.
Re: Access restriction on draw2D.jar [message #183533 is a reply to message #183409] Fri, 03 June 2005 15:54 Go to previous messageGo to next message
That JAR no longer exists. The entire plug-in is a jar. Why are you
referencing JARs?
"Skhiri Sabri" <sskhirid@ulb.ac.be> wrote in message
news:0e367bad151003d34ec94ddd52a67966$1@www.eclipse.org...
> any more:
> Thanks !
> Sabri.
Re: Access restriction on draw2D.jar [message #183669 is a reply to message #183533] Mon, 06 June 2005 13:55 Go to previous messageGo to next message
I don't reference it, I have just added the org.eclipse.draw2d in the
required plug-in section, but I did that a long time ago !
The problem is that under the M7, the complier doesn't find any classes of
draw2d and I get this error !
I don't understand !
Re: Access restriction on draw2D.jar [message #183682 is a reply to message #183669] Mon, 06 June 2005 14:59 Go to previous message
You need to use the PDE to update your classpath properly. You also must be
using 3.1 M6 or later as your IDE. This is not a GEF related problem. Good
luck.
news:f99c2391633b43933639e01856d18ad5$1@www.eclipse.org...
Previous Topic:PropertyPage and FileDialog
Next Topic:Problems in understanding GEF!
Current Time: Thu Dec 26 13:48:26 GMT 2024
Powered by FUDForum. Page generated in 0.02550 seconds
