Re: Access restriction on draw2D.jar [message #183533 is a reply to message #183409] |
Fri, 03 June 2005 15:54 |
That JAR no longer exists. The entire plug-in is a jar. Why are you
referencing JARs?
"Skhiri Sabri" <sskhirid@ulb.ac.be> wrote in message
news:0e367bad151003d34ec94ddd52a67966$1@www.eclipse.org...
> I have just upgraded to 3.1M7, and now the draw2d.jar is not accessible
> any more:
> Severity Description Resource In Folder Location Creation Time
> 2 Access restriction: The type AbstractLayout is not accessible due to
> restriction on required library
> /home/sabri/compiler/previewM7/eclipse/plugins/org.eclipse.d raw2d_3.0.1/draw2d.jar
> Thanks !
> Sabri.
Re: Access restriction on draw2D.jar [message #183682 is a reply to message #183669] |
Mon, 06 June 2005 14:59 |
You need to use the PDE to update your classpath properly. You also must be
using 3.1 M6 or later as your IDE. This is not a GEF related problem. Good
luck.
news:f99c2391633b43933639e01856d18ad5$1@www.eclipse.org...
>I don't reference it, I have just added the org.eclipse.draw2d in the
>required plug-in section, but I did that a long time ago !
> The problem is that under the M7, the complier doesn't find any classes of
> draw2d and I get this error !
> I don't understand !
FUDForum. Page generated in 0.03903 seconds
