Home » Archived » Jubula » Facing issue on Java swing application can not identify Object mapping( Jubula test script on Java swing application can not identify Object mapping . )
- Facing issue on Java swing application can not identify Object mapping [message #1832339] Wed, 16 September 2020 14:57 Go to next message
Hrshad Darji is currently offline Hrshad DarjiFriend
While writing test script on Jubula on Java swing application can not identify Object mapping , there is no Green box around Table
Is there anyone can help me out with this issue. Java swing application is develop on P4.
[Updated on: Wed, 16 September 2020 15:00] by Moderator
Report message to a moderator
- Re: Facing issue on Java swing application can not identify Object mapping [message #1833392 is a reply to message #1832339] Mon, 12 October 2020 08:21 Go to previous messageGo to next message
Marvin Mueller is currently offline Marvin MuellerFriend
I am unsure what a P4 application is meant by?
Can you elaborate a little bit more
best regards
Marvin Mueller
- Re: Facing issue on Java swing application can not identify Object mapping [message #1833506 is a reply to message #1833392] Thu, 15 October 2020 10:18 Go to previous messageGo to next message
Nidhi Kashyap is currently offline Nidhi KashyapFriend
I am facing a similar issue.
I am not able to capture the object mapping of table elements like: table's column name, one complete row of a table.
Thanks in advance.
Any help is much apreciated.
Nidhi
- Re: Facing issue on Java swing application can not identify Object mapping [message #1833748 is a reply to message #1833506] Fri, 23 October 2020 08:48 Go to previous message
The Table can only object matched in complete.
The rows and columns are only accessible with the actions from the Table
best regards
Marvin Mueller
Previous Topic:Sorting in OM Table View?
Next Topic:Start AUT button produces "AUT start failed" message
Current Time: Thu Jan 09 00:00:22 GMT 2025
Powered by FUDForum. Page generated in 0.04863 seconds
