Home » Modeling » EMF Diff/Merge » Diff/Merge adding elements
Diff/Merge adding elements [message #1830105] Fri, 17 July 2020 11:06 Go to next message
Michael C is currently offline Michael CFriend
Member
I m using Diff/Merge to compare 2 parts of a model with FilteredModelScope.
I m using the Dialog to compare. When an element is added to the left or right side I m trying to surcharge the method that set the container in witch the object will be created and modify one of his attribute.
Also I was wondering how I could set the label of the the right and left scope.
edit : I found a way to add the element in the correct container, I just needed to include them both side and play with the matchIdPolicy. Also to modify I figured out that I can modify the object in the scope after the completion.
I just need to modify the labels now.
[Updated on: Fri, 17 July 2020 13:25]
Report message to a moderator
Re: Diff/Merge adding elements [message #1830127 is a reply to message #1830105] Fri, 17 July 2020 16:05 Go to previous messageGo to next message
Olivier Constant is currently offline Olivier ConstantFriend
Hi Michael,
The label of the scopes is deduced from a "scope originator" object. It can be an object for which the editing domain is able to provide a text and icon, or a simple string, or anything else that can be turned into a meaningful text. You just need to override method getOriginator() of the scope.
Re: Diff/Merge adding elements [message #1830191 is a reply to message #1830127] Mon, 20 July 2020 09:47 Go to previous message
Member
Hi Olivier, thanks for the answer. It's working perfectly.
Previous Topic:'Generic' EMF Diff/Merge
Next Topic:Support for git crypt
Current Time: Fri Nov 08 21:57:11 GMT 2024
Powered by FUDForum. Page generated in 0.03073 seconds
