Home » Modeling » M2T (model-to-text transformation) » Increment of Int in while loop?
Increment of Int in while loop? [message #1827743] Fri, 22 May 2020 06:40 Go to next message
hi!
how can we do this syntax in Acceleo
int x=0;
while ( x < =5)
x = x+1;
Fatima
Re: Increment of Int in while loop? [message #1827747 is a reply to message #1827743] Fri, 22 May 2020 08:01 Go to previous message
Acceleo exploits OCL which is a declarative language; nothing changes, new things are computed.
Your snippet has at least 3 non-Acceleo ststements, so I suspect you are on the newsgroup.
If you really want to make progress declaratively you need to step back and decide what you need to do, not how you would have solved it in a precedural language such as Java.
From what your example tells us, the obvious answer is "let x = 5 in ...."
Ed Willink
Previous Topic:[Acceleo] Remove trailing white spaces in generated Java wrapper
Next Topic:XPAND parser exception contains wrong line number
Current Time: Thu Oct 16 22:27:39 EDT 2025
Powered by FUDForum. Page generated in 0.03295 seconds
