Home » Language IDEs » Java Development Tools (JDT) » Boxing of call arguments
Boxing of call arguments [message #1827717] Thu, 21 May 2020 16:52 Go to next message
Has the boxing of call arguments changed since 4.15?
In https://bugs.eclipse.org/bugs/show_bug.cgi?id=563068 I am currently struggling with miraculous regressions that only make sense if JDT previously boxed boolean to Boolean outside the function call, but now boxes inside the called function. i.e new code calling new code is ok, old code calling old code is ok, but new code called by old code is not ok.
Ed Willink
Re: Boxing of call arguments [message #1827724 is a reply to message #1827717] Thu, 21 May 2020 17:59 Go to previous messageGo to next message
Stephan Herrmann is currently offline Stephan HerrmannFriend
I'm not aware of recent changes directly concerning boxing, but checks for unnecessary casts have changed. Do you care to show an example?
Re: Boxing of call arguments [message #1827726 is a reply to message #1827724] Thu, 21 May 2020 19:06 Go to previous messageGo to next message
Yes. I'm pretty confident now after a day of my struggles and probably similar time of IT struggles
https://bugs.eclipse.org/bugs/show_bug.cgi?id=563442
Running OCL, built post M2, on almost any vintage of Xtext fails.
Ed
Re: Boxing of call arguments [message #1827754 is a reply to message #1827726] Fri, 22 May 2020 14:35 Go to previous message
Wrong. JDT is without fault. The problem is an Xtext API evolution. See https://bugs.eclipse.org/bugs/show_bug.cgi?id=563476
Ed Willink
Previous Topic:OpenHTMLtoPDF
Next Topic:JAR File Import Problem
Current Time: Thu Dec 26 13:24:40 GMT 2024
Powered by FUDForum. Page generated in 0.06980 seconds
