Home » Newcomers » Newcomers » Oomph Preferences and User Storage(Problem with my User Storage)
Oomph Preferences and User Storage [message #1826599] Mon, 27 April 2020 11:30 Go to next message
I am trying to synchronize my User preferences across multiple machines and VMs.
At one stage it seemed I lost most of the preferences on the remote User storage so I decided to delete it and recreate them. I deleted my User data on accounts.eclipse.org but subsequently was unable to synchronize any data using the Preference Recorder on my eclipse instance. I kept getting error messages
Not found: https://api.eclipse.org/
Trying it again today when I clicked Synchronize Now I get the following
Unable to connect to the database server at this time(eclipse).
SQL Trouble: You have an error in your SQL syntax; check the manual that corresponds to your MariaDB server version for the right syntax to use near '= ""' at line 3 [
Can anybody help please?
Re: Oomph Preferences and User Storage [message #1826653 is a reply to message #1826599] Tue, 28 April 2020 06:27 Go to previous messageGo to next message
I tested it just now and did not have such problems. I even deleted my account storage and could sync the local changes back again. Perhaps the server was dead for a while? Does it still happen? If you want to start from scratch, you could delete the .eclipse\org.eclipse.oomph.setup.sync folder in your home folder.
Re: Oomph Preferences and User Storage [message #1826669 is a reply to message #1826653] Tue, 28 April 2020 10:32 Go to previous message
Thank you Ed ..... that worked well.
I am slightly cross that I spent hours researching this & never saw anything relating to this fix. I did try deleting remote.cache in that folder.
Also the error messaging seems inadequate. I know I did see ephemeral screens flickering by when I got error Not found: https://api.eclipse.org/ but it was only the next day that the MariaDB screen showed itself.
However I now know & am grateful for your help!
Previous Topic:java.util.logging is not accessible
Next Topic:Eclipse Neon Remote System Explorer Issue
Current Time: Wed Mar 12 16:10:19 EDT 2025
Powered by FUDForum. Page generated in 0.09515 seconds
