I can't choose workspace [message #1821769] |
Wed, 19 February 2020 21:34 |
max tillquist Messages: 1 Registered: February 2020 |
!ENTRY org.eclipse.osgi 4 0 2020-02-19 22:28:22.062
!MESSAGE Application error
!STACK 1
java.lang.NoClassDefFoundError: org/w3c/dom/stylesheets/StyleSheet
at org.eclipse.e4.ui.css.swt.internal.theme.ThemeEngineManager.getCSSSWTEngine(ThemeEngineManager.java:41)
at org.eclipse.e4.ui.css.swt.internal.theme.ThemeEngineManager.getEngineForDisplay(ThemeEngineManager.java:30)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.createThemeEngine(PartRenderingEngine.java:1428)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.initializeStyling(PartRenderingEngine.java:1281)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine$9.run(PartRenderingEngine.java:1036)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.run(PartRenderingEngine.java:1032)
at org.eclipse.e4.ui.internal.workbench.E4Workbench.createAndRunUI(E4Workbench.java:148)
at org.eclipse.ui.internal.Workbench$5.run(Workbench.java:636)
at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:579)
at org.eclipse.ui.internal.ide.application.IDEApplication.start(IDEApplication.java:135)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:382)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:236)
at java.base/jdk.internal.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62)
at java.base/jdk.internal.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43)
at java.base/java.lang.reflect.Method.invoke(Method.java:567)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:648)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:603)
at org.eclipse.equinox.launcher.Main.run(Main.java:1465)
Caused by: java.lang.ClassNotFoundException: org.w3c.dom.stylesheets.StyleSheet cannot be found by org.eclipse.e4.ui.css.core_0.10.100.v20140424-2042
at org.eclipse.osgi.internal.loader.BundleLoader.findClassInternal(BundleLoader.java:423)
at org.eclipse.osgi.internal.loader.BundleLoader.findClass(BundleLoader.java:336)
at org.eclipse.osgi.internal.loader.BundleLoader.findClass(BundleLoader.java:328)
at org.eclipse.osgi.internal.loader.ModuleClassLoader.loadClass(ModuleClassLoader.java:160)
at java.base/java.lang.ClassLoader.loadClass(ClassLoader.java:521)
... 25 more
here is the log file.
FUDForum. Page generated in 0.02296 seconds
