Home » Modeling » OCL » Parsing constraints having elements from differents packages(When an OCL constraint points an element that does not belong to the same package as the rest of the constraint, it is not possible to parse the constraint)
Parsing constraints having elements from differents packages [message #1817955] |
Tue, 03 December 2019 15:04 |
Elyes Cherfa Messages: 2 Registered: August 2017 Location: France |
I'm trying to parse OCL constraints of the UML metamodel using an UML.ecore file containing different UML packages, each of these packages represents a UML diagram (Actions, Activities, ...).
The constraints that use elements from one package are perfectly parsed, However, I am getting errors like "Unknown type" or "Unrecognized variable" when an element that is pointed in the constraint does not belong to THE package containing the "context class". In other words, in a UML MM hierarchy, some superclasses do not belong to the same package as the subclasses, so when trying to access to an attribute defined in this superclass from the subclass, the OCL engine does not find it!
Here is my constraint:
package UML::Activities::CommonBehaviors::Communications
context UML::Actions::CompleteActions::AcceptCallAction
inv result_pins : let parameter: OrderedSet(Parameter) = trigger.event->asSequence()->first().oclAsType(CallEvent).operation.inputParameters() in
result->size() = parameter->size() and
Sequence{1..result->size()}->forAll(i |
parameter->at(i).type.conformsTo(result->at(i).type) and
parameter->at(i).isOrdered = result->at(i).isOrdered and
parameter→at(i).compatibleWith(result→at(i)))
endpackage
How can I proceed to fix this issue? is it by merging the packages to get only one package?
The metamodel is also joined.
Thank you in advance
Attachment: UML.ecore
(Size: 1.39MB, Downloaded 168 times) -
(Size: 1.39MB, Downloaded 145 times)
Re: Parsing constraints having elements from differents packages [message #1818073 is a reply to message #1818030] |
Thu, 05 December 2019 09:22 |
Hi Ed,
Thank you for your answer, I'm trying to transform UML's constraints from ".OCL" to ".Xmi" to get a syntactical tree with the OCL metamodel components.
To parse the constraints first, I'm using a class that I suspect to be outdated. The code is the following :
public class ModelOCL {
* @param args
private ResourceSet resSet;
private Collection<Constraint> Contraintes;
public ModelOCL(){
resSet = new ResourceSetImpl();
resSet.getResourceFactoryRegistry().getExtensionToFactoryMap().put(XMIResource.Factory.Registry.DEFAULT_EXTENSION, new XMIResourceFactoryImpl());
public void loadModel(String pathModel, String pathOCL){
ResourceSet resourceSet = new ResourceSetImpl();
// Register the default resource factory -- only needed for stand-alone!
resourceSet.getResourceFactoryRegistry().getExtensionToFactoryMap().put(XMIResource.Factory.Registry.DEFAULT_EXTENSION, new XMIResourceFactoryImpl());
URI fileURI = URI.createFileURI(pathModel);
// Demand load the resource for this file.
Resource resource = resourceSet.getResource(fileURI, true);
EList<EObject> modelContents=resource.getContents();
// Load OCL file
EPackage.Registry.INSTANCE.put(((EPackage) modelContents.get(0)).getName(), modelContents.get(0));
OCL<EPackage, EClassifier, EOperation, EStructuralFeature, EEnumLiteral, EParameter, EObject, CallOperationAction, SendSignalAction, Constraint, EClass, EObject> ocl;
ocl = OCL.newInstance(EcoreEnvironmentFactory.INSTANCE);
InputStream in;
Contraintes = new HashSet<Constraint>();
try
in = new FileInputStream(pathOCL);
// parse the contents as an OCL document
try
OCLInput document = new OCLInput(in);
Contraintes = ocl.parse(document);
catch (ParserException e)
e.printStackTrace();
System.out.println(e.getCause());
finally
try
in.close();
catch (IOException e)
}catch (FileNotFoundException e)
public void OCLToXML(String path) {
Resource newResource = resSet.createResource(URI.createURI(path));
for (Constraint Contrainte:Contraintes )
newResource.getContents().add(Contrainte);
try {
newResource.save(Collections.EMPTY_MAP);
} catch (IOException e) {
//e.printStackTrace();
protected void XmlToOCL(String path) {
File file = new File(path);
String stringOCL = "package \n\n";
for (Constraint Contrainte : Contraintes) {
OCLExpression<EClassifier> body = Contrainte.getSpecification()
.getBodyExpression();
Variable<EClassifier, EParameter> context = Contrainte
.getSpecification().getContextVariable();
stringOCL += "context " + context.getType().getEPackage().getName()+
"::"+context.getType().getName() + "\n"
+ "inv " + Contrainte.getName() + ":\n\t" + body.accept(ToString.getInstance(body)) + "\n\n";
System.out.println(stringOCL);
FileWriter fw = null;
try {
fw = new FileWriter(file);
fw.write(stringOCL);
} finally {
if (fw != null) {
try {
fw.close();
// TODO Auto-generated method stub
ModelOCL test =new ModelOCL();
test.loadModel("./outputs/UML.ecore", "./inputs/UML.ocl");
Is there any package that does this transformation from constraint.ocl to constraint.xmi programmatically?
Elyes
[Updated on: Thu, 05 December 2019 09:24] Report message to a moderator
Current Time: Fri Dec 27 00:37:03 GMT 2024
Powered by FUDForum. Page generated in 0.04123 seconds
