Home » Archived » XML Schema Definition (XSD) » XML
XML [message #1816891] Mon, 11 November 2019 09:15 Go to next message
Clever Alves is currently offline Clever AlvesFriend
Hi there!
I've been reading about XML and have the following doubt: Can XML be also used to represent methods/operations (behaviours) somehow, rather than just data/structure?
Thank you for your attention.
Clever.
Re: XML [message #1816897 is a reply to message #1816891] Mon, 11 November 2019 11:30 Go to previous messageGo to next message
Well, given that methods/operations can be (and typical are) expressed as a syntax trees (regardless of the language involved), and given that a syntax tree is "just a data structure", yes, XML Is able to express any arbitrary data structure including one that represents a syntax tree that could be interpreted as a method/operation by some compiler/generator/transformer/interpreter.
Ed Merks
XML [message #1816961 is a reply to message #1816897] Wed, 13 November 2019 03:21 Go to previous messageGo to next message
Thank you for your reply, Ed!
Would you know any example of such an implementation (a URL)?
Clever.
Re: XML [message #1816975 is a reply to message #1816961] Wed, 13 November 2019 08:59 Go to previous message
No, but if you export an Ecore model with EOperations to an XML Schema (via the GenModel for that Ecore model) those operations are represented in the *.xsd that's produced, so that's sort of an example, but it doesn't include syntax for the operation body. If the EOperation does have a body annotation, that's just serialized as text content. E.g., https://git.eclipse.org/c/emf/org.eclipse.emf.git/tree/plugins/org.eclipse.emf.ecore/model/Ecore.xsd#n238
Ed Merks
Previous Topic:The {max occurs} of an element in an 'all' model group must be 0 or 1
Next Topic:XSD with a variable subtree definition
Current Time: Wed Feb 05 15:59:46 GMT 2025
Powered by FUDForum. Page generated in 0.02533 seconds
