Home » Eclipse Projects » OM2M » print messages on console(print messages on incse console message not coming)
Re: print messages on console [message #1816594 is a reply to message #1816493] |
Fri, 01 November 2019 05:37 |
Krupa K Messages: 5 Registered: October 2019 |
Hi Gulliame,
Thank you for the reply. We shall use that.
Can you suggest how to connect to MySQL database.
In postman we get
CSE service is not available.
and OSGi console,
Exception in thread "pool-2-thread-1" javax.persistence.RollbackException: Exception [EclipseLink-4002] (Eclipse Persistence Services - 2.5.2.v20140319-9ad6abd): org.eclipse.persistence.exceptions.DatabaseException
Internal Exception: com.mysql.jdbc.exceptions.jdbc4.MySQLSyntaxErrorException: You have an error in your SQL syntax; check the manual that corresponds to your MySQL server version for the right syntax to use near 'CREATE, DELETE, DISCOVERY, NOTIFY, RETRIEVE, UPDATE) VALUES (1, 1, 1, 1, 1, 1, 1' at line 1
Error Code: 1064
Call: INSERT INTO ACR (ACR_ID, CREATE, DELETE, DISCOVERY, NOTIFY, RETRIEVE, UPDATE) VALUES (?, ?, ?, ?, ?, ?, ?)
bind => [7 parameters bound]
Query: InsertObjectQuery(org.eclipse.om2m.commons.entities.AccessControlRuleEntity@6c873167)
at org.eclipse.persistence.internal.jpa.transaction.EntityTransactionImpl.commit(EntityTransactionImpl.java:157)
at org.eclipse.om2m.persistence.eclipselink.internal.DBTransactionJPAImpl.commit(DBTransactionJPAImpl.java:45)
at org.eclipse.om2m.core.CSEInitializer.initACP(CSEInitializer.java:370)
at org.eclipse.om2m.core.CSEInitializer.init(CSEInitializer.java:92)
at org.eclipse.om2m.core.Activator$2$1.run(Activator.java:106)
at java.util.concurrent.ThreadPoolExecutor.runWorker(Unknown Source)
at java.util.concurrent.ThreadPoolExecutor$Worker.run(Unknown Source)
Caused by: Exception [EclipseLink-4002] (Eclipse Persistence Services - 2.5.2.v20140319-9ad6abd): org.eclipse.persistence.exceptions.DatabaseException
Error Code: 1064
Please tell how to correct this.
Current Time: Wed Jan 15 05:41:46 GMT 2025
Powered by FUDForum. Page generated in 0.02649 seconds
