Home » Eclipse Projects » OM2M » problem to build om2m (Unable to build the om2m, following official website given steps )
problem to build om2m [message #1810201] Sat, 03 August 2019 11:08 Go to next message
Draco IoT is currently offline Draco IoTFriend
Hello Sir/Madam,
I am quite interesting in OM2M, I ried to build the om2m in my laptop but I could not make it.
Some points:
1) I already have java 1.8. (Defined path also)
2) I already have Maven 3.6.1 (Defined path also)
3) I also have Tycho installed in eclipse.
Now the thing is that I have tried via command line and eclipse both way but could not make it.
PS C:\Users\git\org.eclipse.om2m> mvn clean install
[INFO] Scanning for projects...
[WARNING] No explicit target runtime environment configuration. Build is platform dependent.
Internal error: java.lang.RuntimeException: No solution found because the problem is unsatisfiable.: [Unable to satisfy dependency from org.eclipse.om2m.commons 1.1.0.qualifier to package org.apache.commons.logging 0.0.0.; No solution found because the problem is unsatisfiable.] -> [Help 1]
org.apache.maven.InternalErrorException: Internal error: java.lang.RuntimeException: No solution found because the problem is unsatisfiable.: [Unable to satisfy dependency from org.eclipse.om2m.commons 1.1.0.qualifier to package org.apache.commons.logging 0.0.0.; No solution found because the problem is unsatisfiable.]
Re: problem to build om2m [message #1816070 is a reply to message #1810201] Fri, 18 October 2019 15:52 Go to previous message
romuald dubuc is currently offline romuald dubucFriend
You need to use java 1.8.0_212 et maven 3.6.0 (https://bugs.eclipse.org/bugs/show_bug.cgi?id=527022)
Best regard,
Previous Topic:Subscription resource is deleted
Next Topic:JSON content "con" attribute in ContentInstance
Current Time: Thu Dec 26 16:35:07 GMT 2024
Powered by FUDForum. Page generated in 0.03764 seconds
