Home » Eclipse Projects » RCP Testing Tool » Configure Drak Mode Problem(Dark Mode)
Configure Drak Mode Problem [message #1804956] Wed, 03 April 2019 16:48 Go to next message
Gerardo Peralta is currently offline Gerardo PeraltaFriend
Question how can I configure so that the Dark Mode reflects on my IDE?
index.php/fa/35220/0/
Re: Configure Drak Mode Problem [message #1805052 is a reply to message #1804956] Fri, 05 April 2019 03:51 Go to previous messageGo to next message
Olga Yurchuk is currently offline Olga YurchukFriend
Could you please clarify the question?
Do you want to set Dark mode in AUT?
It is possible to set it the same way in Prefences.
Yours sincerely,
Olga.
Re: Configure Drak Mode Problem [message #1805090 is a reply to message #1805052] Fri, 05 April 2019 14:31 Go to previous message
Hello Olga,
I set up the dark mode in DevTools for my IDE and as you can see does not respect the same colors when I write a test.
Is there a way to force it?
Gerardo
Previous Topic:Checking graph contents
Next Topic:Message box info is absent using get-last-message-box
Current Time: Wed Jan 15 11:19:20 GMT 2025
Powered by FUDForum. Page generated in 0.09508 seconds
