Home » Eclipse Projects » RCP Testing Tool » RRCPT does not add the URL (update sites) when run the AUT(AUT Update Sites)
RRCPT does not add the URL (update sites) when run the AUT [message #1802715] Thu, 14 February 2019 13:56 Go to next message
Gerardo Peralta is currently offline Gerardo PeraltaFriend
index.php/fa/34886/0/Hello,
I would like to ask the following question:
Why RRCPT not add the update sites url of my Eclipse when running it through RRCPT.
I have checked it by running the APP without RRCPT and the urls are ok (by default), but not when running it with RRCPT.
Is it a bug or am I missing something? I have attached a screenshot of both situations in order to clarify.
index.php/fa/34887/0/
Re: RRCPT does not add the URL (update sites) when run the AUT [message #1803098 is a reply to message #1802715] Fri, 22 February 2019 10:56 Go to previous messageGo to next message
Olga Yurchuk is currently offline Olga YurchukFriend
Thank you for finding this issue.
I raised a bug.
What is the purpose of the test you create?
Do you want to install update from update site or just check the list?
Yours sincerely,
Olga.
Re: RRCPT does not add the URL (update sites) when run the AUT [message #1803828 is a reply to message #1803098] Mon, 11 March 2019 17:24 Go to previous messageGo to next message
I just wanna check the list items,
Thanks!
Re: RRCPT does not add the URL (update sites) when run the AUT [message #1803829 is a reply to message #1803828] Mon, 11 March 2019 17:28 Go to previous messageGo to next message
Agustin Celentano is currently offline Agustin CelentanoFriend
Member
Hi Olga,
I've just checked the bug raised and it has been closed as invalid. Can you clarify what is the correct way to set a subtset of updates sites in order to see them when opening my AUT with RCPTT?
Thanks in advance
Agustin.
Re: RRCPT does not add the URL (update sites) when run the AUT [message #1803890 is a reply to message #1803829] Wed, 13 March 2019 09:26 Go to previous message
Hello Agustin,
This was a small misunderstanding.
Sorry for that.
We've reopened the bug.
Yours sincerely,
Olga.
Previous Topic:However, it does not work in Eclipse RAP v3.7.0.
Next Topic:Unwanted conversion to float when passing a string to a proc
Current Time: Sat Dec 21 13:23:47 GMT 2024
Powered by FUDForum. Page generated in 0.04912 seconds
