Plugin not working on latest Eclipse versions [message #1801096] |
Sun, 13 January 2019 20:29 |
Ammad Ahmed![Friend of Eclipse Friend](/donate/web-api/friends_decorator.php?email=ammadahmed23%40gmail.com) Messages: 10 Registered: January 2019 |
I am trying to run the Eclipse plugin which was built using Neon release on the latest versions of Eclipse. So far it works fine on the Oxygen release but doesn't work on the other latest releases.
I have the source code of the plugin (on Neon-rcp) from which I created the plugin's jar file and installed it on Neon and Oxygen versions and it works fine but when I install it on Photon, 2018-09 and 2018-12 and launch the Eclipse IDE it gives me an error message to read the log file. In the log file it states that an error occurred while activating the bundle. I even installed the java 1.8.0_102 in which the plugin was built. I searched for solutions but couldn't find one which could solve this issue. Please see the log:
!SESSION 2019-01-12 16:17:57.069 -----------------------------------------------
eclipse.buildId=4.8.0.I20180611-0500
java.version=1.8.0_102
BootLoader constants: OS=win32, ARCH=x86_64, WS=win32, NL=en_US
Framework arguments: -product org.eclipse.epp.package.java.product
Command-line arguments: -os win32 -ws win32 -arch x86_64 -product org.eclipse.epp.package.java.product
!ENTRY org.eclipse.osgi 4 0 2019-01-12 16:18:20.767
!MESSAGE An error occurred while automatically activating bundle org.eclipse.core.resources (98).
!STACK 0
org.osgi.framework.BundleException: Exception in org.eclipse.core.resources.ResourcesPlugin.start() of bundle org.eclipse.core.resources.
at org.eclipse.osgi.internal.framework.BundleContextImpl.startActivator(BundleContextImpl.java:800)
at org.eclipse.osgi.internal.framework.BundleContextImpl.start(BundleContextImpl.java:729)
at org.eclipse.osgi.internal.framework.EquinoxBundle.startWorker0(EquinoxBundle.java:1002)
at org.eclipse.osgi.internal.framework.EquinoxBundle$EquinoxModule.startWorker(EquinoxBundle.java:354)
at org.eclipse.osgi.container.Module.doStart(Module.java:581)
at org.eclipse.osgi.container.Module.start(Module.java:449)
at org.eclipse.osgi.framework.util.SecureAction.start(SecureAction.java:468)
at org.eclipse.osgi.internal.hooks.EclipseLazyStarter.postFindLocalClass(EclipseLazyStarter.java:114)
at org.eclipse.osgi.internal.loader.classpath.ClasspathManager.findLocalClass(ClasspathManager.java:505)
at org.eclipse.osgi.internal.loader.ModuleClassLoader.findLocalClass(ModuleClassLoader.java:328)
at org.eclipse.osgi.internal.loader.BundleLoader.findLocalClass(BundleLoader.java:392)
at org.eclipse.osgi.internal.loader.sources.SingleSourcePackage.loadClass(SingleSourcePackage.java:36)
at org.eclipse.osgi.internal.loader.BundleLoader.findClassInternal(BundleLoader.java:466)
at org.eclipse.osgi.internal.loader.BundleLoader.findClass(BundleLoader.java:419)
at org.eclipse.osgi.internal.loader.BundleLoader.findClass(BundleLoader.java:411)
at org.eclipse.osgi.internal.loader.ModuleClassLoader.loadClass(ModuleClassLoader.java:150)
at java.lang.Class.getDeclaredConstructors0(Native Method)
at java.lang.Class.privateGetDeclaredConstructors(Unknown Source)
at java.lang.Class.getConstructor0(Unknown Source)
at java.lang.Class.newInstance(Unknown Source)
at org.eclipse.osgi.internal.framework.BundleContextImpl.loadBundleActivator(BundleContextImpl.java:763)
at org.eclipse.osgi.internal.framework.BundleContextImpl.start(BundleContextImpl.java:716)
at org.eclipse.osgi.internal.loader.BundleLoader.findClassInternal(BundleLoader.java:470)
at org.eclipse.osgi.internal.framework.EquinoxBundle.loadClass(EquinoxBundle.java:609)
at org.apache.felix.scr.impl.manager.AbstractComponentManager.initDependencyManagers(AbstractComponentManager.java:992)
at org.apache.felix.scr.impl.manager.AbstractComponentManager.collectDependencies(AbstractComponentManager.java:1019)
at org.apache.felix.scr.impl.manager.SingleComponentManager.getServiceInternal(SingleComponentManager.java:860)
at org.apache.felix.scr.impl.manager.AbstractComponentManager.activateInternal(AbstractComponentManager.java:755)
at org.apache.felix.scr.impl.manager.AbstractComponentManager.enableInternal(AbstractComponentManager.java:675)
at org.apache.felix.scr.impl.manager.AbstractComponentManager.enable(AbstractComponentManager.java:430)
at org.apache.felix.scr.impl.manager.ConfigurableComponentHolder.enableComponents(ConfigurableComponentHolder.java:657)
at org.apache.felix.scr.impl.BundleComponentActivator.initialEnable(BundleComponentActivator.java:341)
at org.apache.felix.scr.impl.Activator.loadComponents(Activator.java:387)
at org.apache.felix.scr.impl.Activator.access$200(Activator.java:52)
at org.apache.felix.scr.impl.Activator$ScrExtension.start(Activator.java:262)
at org.apache.felix.scr.impl.AbstractExtender.createExtension(AbstractExtender.java:196)
at org.apache.felix.scr.impl.AbstractExtender.modifiedBundle(AbstractExtender.java:169)
at org.apache.felix.scr.impl.AbstractExtender.addingBundle(AbstractExtender.java:139)
at org.apache.felix.scr.impl.AbstractExtender.addingBundle(AbstractExtender.java:49)
at org.osgi.util.tracker.BundleTracker$Tracked.customizerAdding(BundleTracker.java:475)
at org.osgi.util.tracker.BundleTracker$Tracked.customizerAdding(BundleTracker.java:1)
at org.osgi.util.tracker.AbstractTracked.trackAdding(AbstractTracked.java:256)
at org.osgi.util.tracker.AbstractTracked.track(AbstractTracked.java:229)
at org.osgi.util.tracker.BundleTracker$Tracked.bundleChanged(BundleTracker.java:450)
at org.eclipse.osgi.internal.framework.BundleContextImpl.dispatchEvent(BundleContextImpl.java:908)
at org.eclipse.osgi.framework.eventmgr.EventManager.dispatchEvent(EventManager.java:230)
at org.eclipse.osgi.framework.eventmgr.ListenerQueue.dispatchEventSynchronous(ListenerQueue.java:148)
at org.eclipse.osgi.internal.framework.EquinoxEventPublisher.publishBundleEventPrivileged(EquinoxEventPublisher.java:230)
at org.eclipse.osgi.internal.framework.EquinoxEventPublisher.publishBundleEvent(EquinoxEventPublisher.java:137)
at org.eclipse.osgi.internal.framework.EquinoxEventPublisher.publishBundleEvent(EquinoxEventPublisher.java:129)
at org.eclipse.osgi.internal.framework.EquinoxContainerAdaptor.publishModuleEvent(EquinoxContainerAdaptor.java:191)
at org.eclipse.osgi.container.Module.publishEvent(Module.java:476)
at org.eclipse.osgi.container.Module.start(Module.java:467)
at org.eclipse.osgi.container.ModuleContainer.start(ModuleContainer.java:777)
at org.eclipse.osgi.container.ModuleContainer.applyDelta(ModuleContainer.java:768)
at org.eclipse.osgi.container.ModuleContainer.resolveAndApply(ModuleContainer.java:538)
at org.eclipse.osgi.container.ModuleContainer.resolve(ModuleContainer.java:484)
at org.eclipse.osgi.container.ModuleContainer.refresh(ModuleContainer.java:1028)
at org.eclipse.osgi.container.ModuleContainer$ContainerWiring.dispatchEvent(ModuleContainer.java:1409)
at org.eclipse.osgi.container.ModuleContainer$ContainerWiring.dispatchEvent(ModuleContainer.java:1)
at org.eclipse.osgi.framework.eventmgr.EventManager$EventThread.run(EventManager.java:340)
Caused by: java.lang.IllegalStateException: The instance data location has not been specified yet.
at org.eclipse.core.internal.runtime.DataArea.assertLocationInitialized(DataArea.java:56)
at org.eclipse.core.internal.runtime.DataArea.getStateLocation(DataArea.java:133)
at org.eclipse.core.internal.runtime.InternalPlatform.getStateLocation(InternalPlatform.java:574)
at org.eclipse.core.runtime.Plugin.getStateLocation(Plugin.java:289)
at org.eclipse.core.internal.resources.LocalMetaArea.<init>(LocalMetaArea.java:60)
at org.eclipse.core.resources.ResourcesPlugin.start(ResourcesPlugin.java:478)
at org.eclipse.osgi.internal.framework.BundleContextImpl$3.run(BundleContextImpl.java:779)
at org.eclipse.osgi.internal.framework.BundleContextImpl$3.run(BundleContextImpl.java:1)
at org.eclipse.osgi.internal.framework.BundleContextImpl.startActivator(BundleContextImpl.java:772)
... 76 more
Root exception:
!ENTRY org.eclipse.osgi 4 0 2019-01-12 16:18:20.774
!MESSAGE An error occurred while automatically activating bundle my.plugin.name.here (545).
!STACK 0
org.osgi.framework.BundleException: Error starting module.
at org.eclipse.osgi.container.Module.doStart(Module.java:590)
Caused by: java.lang.NoClassDefFoundError: org/eclipse/core/resources/IResourceChangeListener
... 51 more
Caused by: java.lang.ClassNotFoundException: An error occurred while automatically activating bundle org.eclipse.core.resources (98).
at org.eclipse.osgi.internal.hooks.EclipseLazyStarter.postFindLocalClass(EclipseLazyStarter.java:123)
... 60 more
Caused by: org.osgi.framework.BundleException: Exception in org.eclipse.core.resources.ResourcesPlugin.start() of bundle org.eclipse.core.resources.
... 69 more
... 76 more
Root exception:
... 60 more
... 69 more
... 76 more
!ENTRY my.plugin.name.here 4 0 2019-01-12 16:18:20.777
!MESSAGE [DataModel(54)] Could not load implementation object class my.plugin.name.here.model.impl.DataModelImpl
!STACK 0
java.lang.ClassNotFoundException: An error occurred while automatically activating bundle my.plugin.name.here (545).
Caused by: org.osgi.framework.BundleException: Error starting module.
... 48 more
... 51 more
... 60 more
... 69 more
... 76 more
!ENTRY my.plugin.name.here 4 0 2019-01-12 16:18:20.786
!MESSAGE BundleComponentActivator : Bundle [545] Unexpected failure enabling component holder DataModel
!STACK 0
java.lang.IllegalStateException: Could not load implementation object class my.plugin.name.here.model.impl.DataModelImpl
at org.apache.felix.scr.impl.manager.AbstractComponentManager.initDependencyManagers(AbstractComponentManager.java:999)
!ENTRY org.apache.felix.scr 4 0 2019-01-12 16:18:20.975
!MESSAGE Error while disposing components of bundle my.plugin.name.here/545
!STACK 0
java.lang.IllegalStateException: BundleContext is no longer valid
at org.eclipse.osgi.internal.framework.BundleContextImpl.checkValid(BundleContextImpl.java:989)
at org.eclipse.osgi.internal.framework.BundleContextImpl.ungetService(BundleContextImpl.java:664)
at org.osgi.util.tracker.ServiceTracker.removedService(ServiceTracker.java:461)
at org.osgi.util.tracker.ServiceTracker$Tracked.customizerRemoved(ServiceTracker.java:969)
at org.osgi.util.tracker.ServiceTracker$Tracked.customizerRemoved(ServiceTracker.java:1)
at org.osgi.util.tracker.AbstractTracked.untrack(AbstractTracked.java:341)
at org.osgi.util.tracker.ServiceTracker.close(ServiceTracker.java:380)
at org.apache.felix.scr.impl.BundleComponentActivator.dispose(BundleComponentActivator.java:544)
at org.apache.felix.scr.impl.Activator.disposeComponents(Activator.java:436)
at org.apache.felix.scr.impl.Activator.access$300(Activator.java:52)
at org.apache.felix.scr.impl.Activator$ScrExtension.destroy(Activator.java:290)
at org.apache.felix.scr.impl.AbstractExtender$1.run(AbstractExtender.java:216)
at java.util.concurrent.Executors$RunnableAdapter.call(Unknown Source)
at java.util.concurrent.FutureTask.run(Unknown Source)
at org.apache.felix.scr.impl.AbstractExtender.destroyExtension(AbstractExtender.java:238)
at org.apache.felix.scr.impl.AbstractExtender.bundleChanged(AbstractExtender.java:132)
at org.eclipse.osgi.container.Module.doStart(Module.java:587)
at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.dispatchEvent(ModuleContainer.java:1577)
at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.dispatchEvent(ModuleContainer.java:1)
!ENTRY my.plugin.name.here 4 0 2019-01-12 16:18:20.980
!MESSAGE FrameworkEvent ERROR
!STACK 0
org.osgi.framework.BundleException: Error loading bundle activator.
at org.eclipse.osgi.internal.framework.BundleContextImpl.start(BundleContextImpl.java:721)
Caused by: java.lang.ClassNotFoundException: An error occurred while automatically activating bundle my.plugin.name.here (545).
... 2 more
... 48 more
... 51 more
... 60 more
... 69 more
... 76 more
Root exception:
... 48 more
FUDForum. Page generated in 0.03502 seconds
