Home » Eclipse Projects » Kura » CamelRunner.Builder() null pointer exception
CamelRunner.Builder() null pointer exception [message #1799456] Fri, 07 December 2018 06:25 Go to next message
Aistis Kaikaris is currently offline Aistis KaikarisFriend
Member
Hello
I have used the example provided in the "org.eclipse.kura.example.camel.quickstart" bundle for creating camel context in OSGI.
final BundleContext ctx = FrameworkUtil.getBundle(DeviceRouteRegistry.class).getBundleContext();
Builder builder = new CamelRunner.Builder();
This seemed to work fine in kura version 3.5, but when i tried out kura version 4.0, executing "new CamelRunner.Builder()" throws null pointer exception:
!STACK 0
	at java.base/java.util.Objects.requireNonNull(Objects.java:221)
	at org.eclipse.kura.camel.runner.CamelRunner$Builder.<init>(CamelRunner.java:153)
	at org.eclipse.kura.camel.runner.CamelRunner$Builder.<init>(CamelRunner.java:149)
causing the service activate method to be called again and again (i counted 7 times) until it creates the builder.
Any idea why this could be happening?
Thank you.
Re: CamelRunner.Builder() null pointer exception [message #1799560 is a reply to message #1799456] Mon, 10 December 2018 10:07 Go to previous messageGo to next message
Matteo Maiero is currently offline Matteo MaieroFriend
I've tried to reach the original contributor.
Following his reply:
looking at the source code, I don't see anything obvious that changed.
The reason for the NPE is that the OSGi Framework didn't return a bundle context. So maybe this has something to do with a different start order, or something like that.
I would suggest to use the explicit constructor, passing in the be bundle context manually.
Matteo
Re: CamelRunner.Builder() null pointer exception [message #1799925 is a reply to message #1799560] Mon, 17 December 2018 14:47 Go to previous message
Member
I think it was as you pointed out - a problem with ordering. Seems to have gone away for now. Thanks.
Previous Topic:Password field
Next Topic:Connect an IP Camera to Kura
Current Time: Thu Dec 26 12:13:18 GMT 2024
Powered by FUDForum. Page generated in 0.04267 seconds
