XText Generator making random mistakes while generating java classes [message #1796034] |
Thu, 04 October 2018 07:37  |
I have a quite large grammar.
When I generate the Xtext Artifacts, many many java classes are generated. Generators run successfully. However, almost always some of the classes which are generated have random mistakes in them, which makes them unable to compile.
It is usually only one or two .java classes among almost a hundred which have mistakes, and it is not the same classes, the mistakes seem to come randomly.
Bit it is usually inside the the package implementation class.
Here is an example mistake:
public EClass getActionDeclaration()
if (actionDeclarationEClass == null)
actionDeclarationEClass = (EClass)EPackage.Registry.INSTANCE.getEPackage(HmiPackage.eNS_URI).getEClassifiers().g(96);
return compositeActionEClass;
this code should actually look like this:
actionDeclarationEClass = (EClass)EPackage.Registry.INSTANCE.getEPackage(HmiPackage.eNS_URI).getEClassifiers().get(92);
return actionDeclarationEClass;
so the instead of "get" there is "g"
Here is my Workflow, if that helps:
module de.bmw.rhmi.GenerateHmi
import org.eclipse.xtext.xtext.generator.*
import org.eclipse.xtext.xtext.generator.model.project.*
import org.eclipse.emf.mwe.utils.*
var rootPath = ".."
var projectName = "de.bmw.rhmi"
var runtimeProject = "../${projectName}"
Workflow {
bean = StandaloneSetup {
scanClassPath = true
platformUri = "${rootPath}"
registerGenModelFile = "platform:/resource/de.bmw.rhmi.resource/model/generated/Strings.genmodel"
registerGenModelFile = "platform:/resource/de.bmw.rhmi.resource/model/Image.genmodel"
registerGenModelFile = "platform:/resource/de.bmw.rhmi/model/generated/App.genmodel"
registerGenModelFile = "platform:/resource/de.bmw.rhmi/model/generated/Hmi.genmodel"
registerGeneratedEPackage = "de.bmw.rhmi.resource.image.ImagePackage"
registerGeneratedEPackage = "de.bmw.rhmi.resource.strings.StringsPackage"
component = XtextGenerator {
configuration = {
project = StandardProjectConfig {
baseName = "de.bmw.rhmi"
rootPath = rootPath
runtimeTest = {
enabled = true
genericIde = {
enabled = true
mavenLayout = true
code = {
encoding = "UTF-8"
lineDelimiter = "\n"
fileHeader = "/*\n * generated by Xtext \${version}\n */"
language = XtextGeneratorLanguage {
name = "de.bmw.rhmi.App"
fileExtensions = "rapp"
referencedResource = "platform:/resource/org.eclipse.xtext.xbase/model/Xbase.genmodel"
fragment = grammarAccess.GrammarAccessFragment2 {}
fragment = ecore.EMFGeneratorFragment2 {}
fragment = serializer.SerializerFragment2 {}
fragment = resourceFactory.ResourceFactoryFragment2 {}
fragment = parser.antlr.XtextAntlrGeneratorFragment2 {}
fragment = validation.ValidatorFragment2 {}
fragment = scoping.ImportNamespacesScopingFragment2 {}
fragment = exporting.QualifiedNamesFragment2 {}
fragment = builder.BuilderIntegrationFragment2 {}
fragment = formatting.Formatter2Fragment2 {}
fragment = ui.labeling.LabelProviderFragment2 {}
fragment = ui.outline.QuickOutlineFragment2 {}
fragment = ui.outline.OutlineTreeProviderFragment2 {}
fragment = ui.quickfix.QuickfixProviderFragment2 {}
fragment = ui.contentAssist.ContentAssistFragment2 {}
fragment = junit.JUnitFragment {}
fragment = ui.refactoring.RefactorElementNameFragment2 {}
fragment = ui.templates.CodetemplatesGeneratorFragment2 {}
fragment = ui.compare.CompareFragment2 {}
fragment = idea.parser.antlr.XtextAntlrIDEAGeneratorFragment {}
fragment = ui.projectWizard.TemplateProjectWizardFragment {}
fragment = ui.fileWizard.TemplateFileWizardFragment {}
referencedResource = "platform:/resource/de.bmw.rhmi/src/main/java/de/bmw/rhmi/App.xtext"
name = "de.bmw.rhmi.Hmi"
fileExtensions = "hmi"
Why is this happening?
My Idea was to increase the timeout variable for the generator, but I am not sure if that has to do with it or how to do it.
Re: XText Generator making random mistakes while generating java classes [message #1796067 is a reply to message #1796046] |
Thu, 04 October 2018 11:59   |
I think i found the solution
it has to do with the runTimeVersion Attribute of the genmodels.
I realize that when the genmodels are generated by xtext, runtime version is automatically set to 2.14, which causes the genmodels to be corrupted (i.e. when I try to open them, I get an illegal runtimeVersion error)
They only get better if I set the runtimeVersion Attribute manually to 2.2
If I do this (change the runtime version), delete everything in the xtext-gen folder, and regenerate the model code, everything works as expected.
How can I make it so that, when xtext generates the genmodels, the runtime version is automatically 2.2? Or that 2.14 is an accepted runtime Version?
Does this have to do with the EMF Version not being in sync ? I don't understand
[Updated on: Thu, 04 October 2018 12:10] by Moderator
Re: XText Generator making random mistakes while generating java classes [message #1809211 is a reply to message #1796124] |
Thu, 11 July 2019 12:25   |
I get the same error with Xtext 2.18.0 and EMF 2.18.0:
This is the stack trace of the Maven build:
Jul 11, 2019 6:09:33 PM org.eclipse.emf.mwe.utils.StandaloneSetup setResourceSet
INFORMATION: Using resourceSet registry. The registered Packages will not be registered in the global EPackage.Registry.INSTANCE!
597 ERROR Mwe2Launcher - Problems running workflow de.abas.screen.smartscreen.GenerateSmartScreen: org.eclipse.emf.ecore.xmi.IllegalV
alueException: Value '2.18' is not legal. (platform:/resource/de.abas.screen.model.screen/model/screen.genmodel, 9, 71)
java.lang.RuntimeException: Problems running workflow de.abas.screen.smartscreen.GenerateSmartScreen: org.eclipse.emf.ecore.xmi.IllegalValue
at org.eclipse.emf.mwe2.launch.runtime.Mwe2Runner.run(Mwe2Runner.java:104)
at org.eclipse.emf.mwe2.launch.runtime.Mwe2Runner.run(Mwe2Runner.java:62)
at org.eclipse.emf.mwe2.launch.runtime.Mwe2Runner.run(Mwe2Runner.java:52)
at org.eclipse.emf.mwe2.launch.runtime.Mwe2Launcher.run(Mwe2Launcher.java:78)
at org.eclipse.emf.mwe2.launch.runtime.Mwe2Launcher.main(Mwe2Launcher.java:36)
at org.codehaus.mojo.exec.ExecJavaMojo$1.run(ExecJavaMojo.java:282)
at java.lang.Thread.run(Thread.java:748)
Caused by: org.eclipse.emf.ecore.resource.impl.ResourceSetImpl$1DiagnosticWrappedException: org.eclipse.emf.ecore.xmi.IllegalValueException:
at org.eclipse.emf.ecore.resource.impl.ResourceSetImpl.handleDemandLoadException(ResourceSetImpl.java:319)
at org.eclipse.emf.ecore.resource.impl.ResourceSetImpl.demandLoadHelper(ResourceSetImpl.java:278)
at org.eclipse.xtext.resource.XtextResourceSet.getResource(XtextResourceSet.java:265)
at org.eclipse.xtext.xtext.generator.XtextGeneratorResourceSetInitializer.loadResource(XtextGeneratorResourceSetInitializer.java:51)
at org.eclipse.xtext.xtext.generator.XtextGeneratorResourceSetInitializer.lambda$initialize$0(XtextGeneratorResourceSetInitializer.j
ava:41)
at java.util.ArrayList.forEach(ArrayList.java:1257)
at org.eclipse.xtext.xtext.generator.XtextGeneratorResourceSetInitializer.initialize(XtextGeneratorResourceSetInitializer.java:43)
at org.eclipse.xtext.xtext.generator.XtextGeneratorLanguage.initialize(XtextGeneratorLanguage.java:218)
at org.eclipse.xtext.xtext.generator.XtextGenerator.initialize(XtextGenerator.java:185)
at org.eclipse.xtext.xtext.generator.XtextGenerator.checkConfigurationInternal(XtextGenerator.java:139)
at org.eclipse.emf.mwe.core.lib.AbstractWorkflowComponent2.checkConfiguration(AbstractWorkflowComponent2.java:22)
at org.eclipse.emf.mwe.core.lib.Mwe2Bridge.preInvoke(Mwe2Bridge.java:68)
at org.eclipse.emf.mwe.core.lib.AbstractWorkflowComponent.preInvoke(AbstractWorkflowComponent.java:207)
at org.eclipse.emf.mwe2.runtime.workflow.AbstractCompositeWorkflowComponent.preInvoke(AbstractCompositeWorkflowComponent.java:30)
at org.eclipse.emf.mwe2.runtime.workflow.Workflow.run(Workflow.java:19)
at org.eclipse.emf.mwe2.launch.runtime.Mwe2Runner.run(Mwe2Runner.java:102)
... 10 more
Caused by: org.eclipse.emf.ecore.xmi.IllegalValueException: Value '2.18' is not legal. (platform:/resource/de.abas.screen.model.screen/model
at org.eclipse.emf.ecore.xmi.impl.XMLHandler.setFeatureValue(XMLHandler.java:2697)
at org.eclipse.emf.ecore.xmi.impl.XMLHandler.setAttribValue(XMLHandler.java:2751)
at org.eclipse.emf.ecore.xmi.impl.SAXXMIHandler.handleObjectAttribs(SAXXMIHandler.java:79)
at org.eclipse.emf.ecore.xmi.impl.XMLHandler.createObjectFromFactory(XMLHandler.java:2229)
at org.eclipse.emf.ecore.xmi.impl.XMLHandler.createObjectByType(XMLHandler.java:1366)
at org.eclipse.emf.ecore.xmi.impl.XMLHandler.createTopObject(XMLHandler.java:1504)
at org.eclipse.emf.ecore.xmi.impl.XMLHandler.processElement(XMLHandler.java:1026)
at org.eclipse.emf.ecore.xmi.impl.XMIHandler.processElement(XMIHandler.java:78)
at org.eclipse.emf.ecore.xmi.impl.XMLHandler.startElement(XMLHandler.java:1008)
at org.eclipse.emf.ecore.xmi.impl.XMLHandler.startElement(XMLHandler.java:719)
at org.eclipse.emf.ecore.xmi.impl.XMIHandler.startElement(XMIHandler.java:190)
at com.sun.org.apache.xerces.internal.parsers.AbstractSAXParser.startElement(AbstractSAXParser.java:509)
at com.sun.org.apache.xerces.internal.impl.dtd.XMLDTDValidator.startElement(XMLDTDValidator.java:745)
at com.sun.org.apache.xerces.internal.impl.XMLDocumentFragmentScannerImpl.scanStartElement(XMLDocumentFragmentScannerImpl.java:1359)
at com.sun.org.apache.xerces.internal.impl.XMLDocumentScannerImpl$ContentDriver.scanRootElementHook(XMLDocumentScannerImpl.java:1289
at com.sun.org.apache.xerces.internal.impl.XMLDocumentFragmentScannerImpl$FragmentContentDriver.next(XMLDocumentFragmentScannerImpl.
java:3132)
at com.sun.org.apache.xerces.internal.impl.XMLDocumentScannerImpl$PrologDriver.next(XMLDocumentScannerImpl.java:852)
at com.sun.org.apache.xerces.internal.impl.XMLDocumentScannerImpl.next(XMLDocumentScannerImpl.java:602)
at com.sun.org.apache.xerces.internal.impl.XMLDocumentFragmentScannerImpl.scanDocument(XMLDocumentFragmentScannerImpl.java:505)
at com.sun.org.apache.xerces.internal.parsers.XML11Configuration.parse(XML11Configuration.java:842)
at com.sun.org.apache.xerces.internal.parsers.XML11Configuration.parse(XML11Configuration.java:771)
at com.sun.org.apache.xerces.internal.parsers.XMLParser.parse(XMLParser.java:141)
at com.sun.org.apache.xerces.internal.parsers.AbstractSAXParser.parse(AbstractSAXParser.java:1213)
at com.sun.org.apache.xerces.internal.jaxp.SAXParserImpl$JAXPSAXParser.parse(SAXParserImpl.java:643)
at com.sun.org.apache.xerces.internal.jaxp.SAXParserImpl.parse(SAXParserImpl.java:327)
at org.eclipse.emf.ecore.xmi.impl.XMLLoadImpl.load(XMLLoadImpl.java:175)
at org.eclipse.emf.ecore.xmi.impl.XMLResourceImpl.doLoad(XMLResourceImpl.java:261)
at org.eclipse.emf.ecore.resource.impl.ResourceImpl.load(ResourceImpl.java:1518)
at org.eclipse.emf.ecore.resource.impl.ResourceImpl.load(ResourceImpl.java:1297)
at org.eclipse.emf.ecore.resource.impl.ResourceSetImpl.demandLoad(ResourceSetImpl.java:259)
at org.eclipse.emf.ecore.resource.impl.ResourceSetImpl.demandLoadHelper(ResourceSetImpl.java:274)
... 24 more
Caused by: java.lang.IllegalArgumentException: The value '2.18' is not a valid enumerator of 'GenRuntimeVersion'
at org.eclipse.emf.codegen.ecore.genmodel.impl.GenModelFactoryImpl.createGenRuntimeVersionFromString(GenModelFactoryImpl.java:394)
at org.eclipse.emf.codegen.ecore.genmodel.impl.GenModelFactoryImpl.createFromString(GenModelFactoryImpl.java:114)
at org.eclipse.emf.ecore.xmi.impl.XMLHelperImpl.createFromString(XMLHelperImpl.java:1615)
at org.eclipse.emf.ecore.xmi.impl.XMLHelperImpl.setValue(XMLHelperImpl.java:1156)
at org.eclipse.emf.ecore.xmi.impl.XMLHandler.setFeatureValue(XMLHandler.java:2692)
... 54 more
In my genmodel I set the runtime version to 2.18.
Re: XText Generator making random mistakes while generating java classes [message #1809247 is a reply to message #1809246] |
Fri, 12 July 2019 06:00  |
Thanks for the hint!
I found following working dependencies configuration:
<dependencies>
<dependency>
<groupId>org.eclipse.emf</groupId>
<artifactId>org.eclipse.emf.mwe.utils</artifactId>
<version>1.4.0</version>
</dependency>
<dependency>
<artifactId>org.eclipse.emf.mwe2.runtime</artifactId>
<version>2.10.0</version>
</dependency>
<dependency>
<artifactId>org.eclipse.emf.mwe2.launch</artifactId>
</dependency>
<dependency>
<groupId>org.eclipse.xtext</groupId>
<artifactId>org.eclipse.xtext.xtext.generator</artifactId>
<version>2.18.0</version>
</dependency>
<dependency>
<artifactId>org.eclipse.xtext.xbase</artifactId>
</dependency>
<dependency>
<artifactId>xtext-antlr-generator</artifactId>
<version>[2.1.1, 3)</version>
</dependency>
<dependency>
<artifactId>org.eclipse.emf.codegen</artifactId>
<version>2.16.0</version>
</dependency>
<dependency>
<artifactId>org.eclipse.emf.codegen.ecore</artifactId>
</dependency>
<dependency>
<artifactId>org.eclipse.emf.common</artifactId>
</dependency>
<dependency>
<artifactId>org.eclipse.emf.ecore</artifactId>
</dependency>
<dependency>
<artifactId>org.eclipse.emf.ecore.change</artifactId>
<version>2.14.0</version>
</dependency>
<dependency>
<artifactId>org.eclipse.emf.ecore.xmi</artifactId>
</dependency>
</dependencies>
I.e. Xtext 2.18.0 and EMF 2.18.0 work together with these dependencies.
[Updated on: Fri, 12 July 2019 06:02] by Moderator
FUDForum. Page generated in 0.05658 seconds
