Home » Eclipse Projects » WindowBuilder » Custom property editor(Unable to add custom property editor using configurableEditor)
Custom property editor [message #1781276] Mon, 05 February 2018 12:27 Go to next message
santhi kumari is currently offline santhi kumariFriend
In plugin.xml, I am adding below code
<extension
point="org.eclipse.wb.core.propertyEditors">
<configurableEditor id="componentEditor" class="FullyQualified name of my editor"/>
</extension>
In *wbp-component.xml
<property id="setRegion(com......)" >
<editor id="componentEditor"/>
</property>
But in designer view I get exception
Caused by: java.lang.IllegalArgumentException: Can not find configurable editor with id 'componentEditor'.
at org.eclipse.wb.internal.core.model.description.helpers.DescriptionPropertiesHelper.getConfigurableEditor(DescriptionPropertiesHelper.java:132)
at org.eclipse.wb.internal.core.model.description.rules.PropertyEditorRule.begin(PropertyEditorRule.java:48)
Request your suggestions.
Is there a sample custom editor code avilable for verifying?
Quick help would be appreciated.
Santha
Re: Custom property editor [message #1795272 is a reply to message #1781276] Wed, 19 September 2018 15:08 Go to previous message
Wim Jongman is currently offline Wim JongmanFriend
Did you export your class in the runtime tab of the manifest?
Previous Topic:Where to find Design Tab
Next Topic:WindowBuilder reverse engineering
Current Time: Wed Feb 05 15:53:32 GMT 2025
Powered by FUDForum. Page generated in 0.04825 seconds
