Home » Modeling » Eclipse Layout Kernel » Getting started (GEF + ELK)
Getting started (GEF + ELK) [message #1794100] Thu, 23 August 2018 10:00 Go to next message
Hello guys and thank your for developing ELK.
I have a GEF project and want ELK to integrate the project so that I can define Layout Algorithms and, more importantly, to define the number and labels for each node inputs/outputs.
However, I'm having difficulties with the "getting started" phase. With that said, can someone please provide me with a link to some GEF/ELK project examples? I'm looking online and I can't seem to find any.
Thank you in advance.
[Updated on: Thu, 23 August 2018 12:47] by Moderator
Re: Getting started (GEF + ELK) [message #1794101 is a reply to message #1794100] Thu, 23 August 2018 10:14 Go to previous messageGo to next message
Which version of GEF are you working with?
Re: Getting started (GEF + ELK) [message #1794103 is a reply to message #1794101] Thu, 23 August 2018 10:53 Go to previous messageGo to next message
The latest one, GEF5.0.0. So far I'm actually using most of the parts of one of their tutorials - MindMap tutorial: https://info.itemis.com/en/gef/tutorials/
However, if there are only examples with previous versions of GEF, I don't mind and will probably learn from them as well.
Re: Getting started (GEF + ELK) [message #1794124 is a reply to message #1794103] Fri, 24 August 2018 02:53 Go to previous messageGo to next message
I haven't used the new GEF with ELK yet, but the general procedure is always the same. Read the following documentation section and its subsections to get started:
https://www.eclipse.org/elk/documentation/tooldevelopers/usingeclipselayout.html
You can also have a look at existing implementations like the GMF layout connector:
https://github.com/eclipse/elk/blob/master/plugins/org.eclipse.elk.conn.gmf/src/org/eclipse/elk/conn/gmf/GmfDiagramLayoutConnector.java
Re: Getting started (GEF + ELK) [message #1794136 is a reply to message #1794124] Fri, 24 August 2018 04:39 Go to previous messageGo to next message
Thank you very much @Miro for the links.
One really specific designing doubt that I'm having: within GEF, as far as I know it, I can't have multiple ports. The GEF library has no idea of the port concept.
Thus, I can have one node with 5 outgoing connections to other nodes but I don't have controllable and distinguishable ports. My main question with the ELK+GEF integration is if ELK will be able to create ports and label them, or if I need to take care of that somehow in GEF side.
What do you think?
[Updated on: Fri, 24 August 2018 04:43] by Moderator
Re: Getting started (GEF + ELK) [message #1794156 is a reply to message #1794136] Fri, 24 August 2018 11:12 Go to previous messageGo to next message
I tried for 6 hours and couldn't integrate ELK with GEF. Please help me.
Please provide some really small example of GEF+ELK if possible.
I already have my Module implementing MvcFxModule, so I have no idea of what I need to do to implement a new binding for IDiagramLayoutConnector and ILayoutConfigurationStore.Provider.
This is what I have in my module:
public class MapModule extends MvcFxModule {
	protected void bindIContentPartFactoryAsContentViewerAdapter(MapBinder<AdapterKey<?>, Object> adapterMapBinder) {
		adapterMapBinder.addBinding(AdapterKey.defaultRole()).to(MapPartsFactory.class);
	 * @param adapterMapBinder
	protected void bindMapNodePartAdapters(MapBinder<AdapterKey<?>, Object> adapterMapBinder) {
		// bind anchor provider used to create the connection anchors
		adapterMapBinder.addBinding(AdapterKey.defaultRole()).to(MapAnchorProvider.class);
		// bind a geometry provider, which is used in our anchor provider
		adapterMapBinder.addBinding(AdapterKey.defaultRole()).to(ShapeOutlineProvider.class);
		 * We need to tell GEF, how to render the hover and selection feedback for our
		 * parts. We do this by binding two providers to the MapNodePart.
		// provides a hover feedback to the shape, used by the HoverBehavior
		AdapterKey<?> role = AdapterKey.role(DefaultHoverFeedbackPartFactory.HOVER_FEEDBACK_GEOMETRY_PROVIDER);
		adapterMapBinder.addBinding(role).to(ShapeOutlineProvider.class);
		// provides a selection feedback to the shape
		role = AdapterKey.role(DefaultSelectionFeedbackPartFactory.SELECTION_FEEDBACK_GEOMETRY_PROVIDER);
		adapterMapBinder.addBinding(role).to(ShapeBoundsProvider.class);
		// support moving nodes via mouse drag
		adapterMapBinder.addBinding(AdapterKey.defaultRole()).to(TransformPolicy.class);
		adapterMapBinder.addBinding(AdapterKey.defaultRole()).to(TranslateSelectedOnDragHandler.class);
		// bind create connection handler
		adapterMapBinder.addBinding(AdapterKey.defaultRole()).to(CreateMapConnectionOnClickHandler.class);
		// bind the context menu policy to the part
		adapterMapBinder.addBinding(AdapterKey.defaultRole()).to(ShowMapNodeContextMenuOnClickHandler.class);
	protected void configure() {
		// start the default configuration
		super.configure();
		bindMapNodePartAdapters(AdapterMaps.getAdapterMapBinder(binder(), MapNodePart.class));
		binder().bind(IDiagramLayoutConnector.class).to(GEFDiagramLayoutConnector.class);
	protected void bindAbstractContentPartAdapters(MapBinder<AdapterKey<?>, Object> adapterMapBinder) {
		super.bindAbstractContentPartAdapters(adapterMapBinder);
		// binding the HoverOnHoverPolicy to every part
		// if a mouse is moving above a part it is set to the HoverModel
		adapterMapBinder.addBinding(AdapterKey.defaultRole()).to(HoverOnHoverHandler.class);
		// add the focus and select policy to every part, listening to clicks
		// and changing the focus and selection model
		adapterMapBinder.addBinding(AdapterKey.defaultRole()).to(FocusAndSelectOnClickHandler.class);
	 * {@link HoverBehavior} listens to changes in the HoverModel and updates the
	 * graphical representation. The behaviors for selection and focus are already
	 * bound in the superclass.
	protected void bindIRootPartAdaptersForContentViewer(MapBinder<AdapterKey<?>, Object> adapterMapBinder) {
		super.bindIRootPartAdaptersForContentViewer(adapterMapBinder);
		// support creation of nodes via mouse click
		adapterMapBinder.addBinding(AdapterKey.defaultRole()).to(CreateMapNodeOnClickHandler.class);
		// adding the creation feedback behavior
		adapterMapBinder.addBinding(AdapterKey.defaultRole()).to(CreateConnectionFeedbackBehavior.class);
	protected void bindIViewerAdaptersForContentViewer(MapBinder<AdapterKey<?>, Object> adapterMapBinder) {
		super.bindIViewerAdaptersForContentViewer(adapterMapBinder);
		// bind the model to the content viewer
		adapterMapBinder.addBinding(AdapterKey.defaultRole()).to(ItemCreation.class);
		// binding the creation feedback part factory using the role that is specified in the behavior
		AdapterKey<?> role = AdapterKey.role(CreateConnectionFeedbackBehavior.CREATE_FEEDBACK_PART_FACTORY);
		adapterMapBinder.addBinding(role).to(CreateConnectionFeedbackFactory.class);
Re: Getting started (GEF + ELK) [message #1794188 is a reply to message #1794136] Mon, 27 August 2018 03:18 Go to previous messageGo to next message
You don't need to use ports with ELK, you can connect edges directly to nodes instead.
Don't use the same Guice module for different things. Create a new Guice module like it's done for the GMF layout connector (see link in my first post).
Re: Getting started (GEF + ELK) [message #1794344 is a reply to message #1794188] Wed, 29 August 2018 05:46 Go to previous messageGo to next message
Miro Spönemann wrote on Mon, 27 August 2018 08:18
Ok, but I need to have multiple distinguishable connections between nodes. For example:
index.php/fa/33756/0/
Can I then connect an outgoing edge of a node with another node with n incoming distinguishable inputs (edges with different names)?
Thank you for the help so far
P.S: Btw, I still couldn't connect ELK with GEF, almost giving up
[Updated on: Wed, 29 August 2018 05:51] by Moderator
Re: Getting started (GEF + ELK) [message #1794347 is a reply to message #1794188] Wed, 29 August 2018 06:34 Go to previous messageGo to next message
[quote title=Miro Spönemann wrote on Mon, 27 August 2018 08:18]Quote:
I created a new Guice Module.
package mmi.presentation.views.graphicalEditor;
import java.util.Collection;
import org.eclipse.elk.core.service.IDiagramLayoutConnector;
import org.eclipse.elk.core.service.ILayoutSetup;
import com.google.inject.Binder;
import com.google.inject.Guice;
import com.google.inject.Injector;
import com.google.inject.Module;
import com.google.inject.util.Modules;
import mmi.presentation.views.graphicalEditor.connectors.GEFDiagramLayoutConnector;
import mmi.presentation.views.graphicalEditor.parts.MapConnectionPart;
import mmi.presentation.views.graphicalEditor.parts.MapNodePart;
import mmi.presentation.views.graphicalEditor.parts.ParentMapPart;
public class GEFLayoutSetup implements ILayoutSetup {
	public boolean supports(Object object) {
		if (object instanceof Collection) {
            Collection<?> collection = (Collection<?>) object;
            for (Object o : collection) {
                if (o instanceof MapNodePart) {
                    return true;
            return false;
        return object instanceof ParentMapPart || object instanceof MapNodePart
                || object instanceof MapConnectionPart;
	public Injector createInjector(Module defaultModule) {
		return Guice.createInjector(Modules.override(defaultModule).with(new LayoutModule()));
	public static class LayoutModule implements Module {
		public void configure(Binder binder) {
		      binder.bind(IDiagramLayoutConnector.class).to(GEFDiagramLayoutConnector.class);
But where do I now instantiate it? The other module, the one doing the GEF graphs is being instantiated like this:
		MapModule module = new MapModule();
		this.domain = (HistoricizingDomain) Guice.createInjector(module).getInstance(IDomain.class);
		// create viewers
		hookViewers(parent);
		// activate domain
		domain.activate();
		// load contents
		populateViewerContents();
I tried instantiating it there without success. I mean, "createInjector()" and "configure()" of Layout Module are being called but "buildLayoutGraph()" from GEFLayoutConnector is never called:
		//ELK Module
		GEFLayoutSetup layoutELK = new GEFLayoutSetup();
		layoutELK.createInjector(module);
Damn Miro, I know that you must be full of work and that for you this is easy as hell, but can you provide me with a little bit more help?
The GMF link you provided didn't help me at all
[Updated on: Wed, 29 August 2018 07:34] by Moderator
Re: Getting started (GEF + ELK) [message #1794437 is a reply to message #1794347] Thu, 30 August 2018 11:04 Go to previous messageGo to next message
Okay, after a lot of time I managed to do something by writing this:
DiagramLayoutEngine.invokeLayout(null, getContentViewer().getAdapter(ParentMapPart.class), null);
where ParentMapPart is an instance of my GEF Grpah created by me.
Now, buildLayoutGraph is called and I correctly create the LayoutMapping within this function. I inspect the mapping variable and it has all the Nodes and Connections from my GEF Graph.
The new problem now is that applyLayout doesn't do anything and I can't see any differences applied to my GEF graph. From what I saw in the GMF example that you suggested previously, they use "org.gef.request" from a previous version of GEF to notify the Graph (not sure about this though! ). GEF5 does not have this class or equivalent.
Miro, do you know what I'm missing? I feel that I'm almost there...
Re: Getting started (GEF + ELK) [message #1795081 is a reply to message #1794437] Fri, 14 September 2018 03:51 Go to previous message
The injector is not created directly. Instead you register your layout setup with the layoutConnectors extension point.
I've never tried to apply layout to a GEF5 diagram, so I cannot help there. You should ask the GEF developers what is the best way to programmatically set a layout in your diagram.
Previous Topic:ELK algorithm change FixPointAnchor y Position to "-1"
Next Topic:ELK and Sirius "Arrange All"?
Current Time: Sat Sep 13 21:58:26 EDT 2025
Powered by FUDForum. Page generated in 0.04509 seconds
