Re: Equinox java 10 compatibility [message #1794762 is a reply to message #1794755] |
Thu, 06 September 2018 08:20 |
Tharindu Wijewardane Messages: 7 Registered: September 2018 |
Hi Thomas,
Thanks for the info. Looks like Kepler is not compatible with java 10. I definitely have to upgrade the equinox version used.
Hi Ed,
We use maven for the build. Since eclipse releases are not available in maven central repo what I did was, downloaded the equinox-SDK-Photon.zip and manually installed the jars into my local maven repo with customized GroupIDs.
ArtifactIDs and version numbers are taken from the filenames of the jars. Does it has any impact on the issue here? I tried adding org.tukaani.xz as a dependency to my pom as well.
[Updated on: Thu, 06 September 2018 08:23] Report message to a moderator
FUDForum. Page generated in 0.03900 seconds
