Home » Language IDEs » C / C++ IDE (CDT) » Running an alias before debug runs(as per title)
Running an alias before debug runs [message #1790710] Thu, 14 June 2018 17:47 Go to next message
a b is currently offline a bFriend
Using eclipse CDT. Can't figure out where to put in an alias that sets some environment variables and sources a few files (linux file system) before attempting to run the debug configuration. I know that eclipse's shell is separate from linux's shell.
Where is such a thing set?
Cheers
Re: Running an alias before debug runs [message #1790844 is a reply to message #1790710] Mon, 18 June 2018 22:07 Go to previous message
David VavraFriend
The launch configuration dialogs have tabs for
    Environment variables
    Source lookup paths
    and other things
You get to them using
    Run --> Debug Configurations .. or
    Run --> Run Configurations ... or
    the arrows next to the Debug or Run As tool bar buttons
If you want to run something in addition to the debugger you could try replacing the debug command with something like
bash bashScriptFilename.sh or
bash /c "bunch of commands"
Never tried it.
May not work.
Just so you know, the launch configurations are unique by name and workspace.
If you edit one with Debug Configurations .. you get a Debugger tab and the Debug (vs. Run) button
[Updated on: Mon, 18 June 2018 22:16]
Report message to a moderator
Previous Topic:Disable Automatic Refactor
Next Topic:Exclude (duplicate) header from project
Current Time: Wed Feb 05 16:59:39 GMT 2025
Powered by FUDForum. Page generated in 0.03092 seconds
