Re: help with LayoutManagers [message #178432 is a reply to message #178363] |
Wed, 20 April 2005 14:44 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Andreas Holtz![Friend of Eclipse Friend](/donate/web-api/friends_decorator.php?email=andreas.holtz%40ipp.mpg.de) Messages: 53 Registered: July 2009 |
Member |
Pratik Shah wrote:
> Use vertical toolbar layout (for the columns, instead of rows).
But now he has to do some work to keep the height of the left cell as high
as on the right cell, i think.
It would be nice, if the toolbar-layout would consider the minimumSize, if
the minimumSize is larger than the preferredSize, instead of using the
default bounds (0,0,64,36).
There was an diskussion in the newsgroup on the 13.10.2003 and a
"solution" from Brian Fernandes, but it wasnŽt commented.
Strange that this is not listed as a bug.
> I don't know why people on this newsgroup use text-based figures to show
> their problem when a screenshot would convey the problem much more clearly.
How to make a screenshot, if you canŽt visualize it? :)
Or you could just paint it with MS Paint() :)
Andreas
Re: help with LayoutManagers [message #178449 is a reply to message #178432] |
Wed, 20 April 2005 15:27 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Pratik Shah![Friend of Eclipse Friend](/donate/web-api/friends_decorator.php?email=ppshah%40us.ibm.com) Messages: 1077 Registered: July 2009 |
"Andreas Holtz" <A.Holtz@gmx.net> wrote in message
news:4b8493d49da1dd042656b719cecb075f$1@www.eclipse.org...
Yeah, you're right about the height. The ToolbarLayout does take the
minimumSize into account, but it is upto the child figure (or its layout
manager) to ensure that the preferred size is at least as large as the
minimum size.
Scrap my original suggestion. We're trying to use ToolbarLayout in a way
that it wasn't meant to be used. What you really need is something like the
GridLayout. Perhaps it's best to create your own layout manager for this
case.
Re: help with LayoutManagers [message #178809 is a reply to message #178449] |
Fri, 22 April 2005 17:15 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Member |
> case.
Why?
You could create a Figure, that represent one row (use a horizontal
ToolbarLayout) and add the rows to the main figure, which has a vertical
Toolbar Layout.
Each row-Figure has two Figures, one for the Label and one for the Figure.
You only have to ensure, that the Label-Figure has always the same width.
> minimum size.
As mentioned before, if you set the prefSize manually, the figure will not
be streched, as needed.
Re: help with LayoutManagers [message #179020 is a reply to message #178809] |
Mon, 25 April 2005 13:53 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
> Why?
> Toolbar Layout.
Hard-coding the size of the label figures is a bit of a workaround. You
need a layout which handles both horiz. and vert. axes. In other words,
calculate column widths the right way by getting label pref sizes, then
figure out how much vertical space is needed based on the column widths and
the cell's pref heights for those widths. We eventually want to provide a
table layout which conforms to:
http://www.w3.org/TR/REC-CSS2/tables.html#width-layout
Re: help with LayoutManagers [message #179571 is a reply to message #179020] |
Thu, 28 April 2005 17:56 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) |
Eric Wasserman![Friend of Eclipse Friend](/donate/web-api/friends_decorator.php?email=ewasserman%40voxify.com) Messages: 10 Registered: July 2009 |
I tried the figure per row and had trouble getting the preferred size to
stick. Each Label kept reverting to its internally computed preferred size.
I wound up solving this as Randy Hudson suggests below with a custom layout
that works as he describes. I'd share it but I doubt it's general purpose
enough to be of value to anyone else.
Thanks, everyone, for the help.
On 4/25/05 6:53 AM, in article d4isuf$c6j$1@news.eclipse.org, "Randy Hudson"
<none@us.ibm.com> wrote:
>> Why?
>> Toolbar Layout.
FUDForum. Page generated in 0.04762 seconds
