Re: Forte v1.9 with open62541 on RPI [message #1786790 is a reply to message #1786739] |
Fri, 11 May 2018 15:26 |
when you are cross compiling you need to ensure that the cross environment usese the same library versions then your target system. Jesse and Stretch are quite appart and Ubuntu is always quite on the most recent lib versions. I assume that this was then the problem.
Regarding your monitoring issue: If you can deploy and have "FORTE_SUPPORT_MONITORING" enabled monitroing should work. I don't know of anything special.
Re: Forte v1.9 with open62541 on RPI [message #1786957 is a reply to message #1786949] |
Wed, 16 May 2018 11:26 |
Hi Daniel,
this is really strange. Thanks a lot for your offer in helping us to track this down.
Could you provide us a screenshot of your system configuration. Do you have two devices with the same ip configured in it? This is now a problem. Could you get us your .log file from your workspace?
Alois
Re: Forte v1.9 with open62541 on RPI [message #1787495 is a reply to message #1787476] |
Sat, 26 May 2018 19:20 |
Dear Daniel,
thanks for all the infos. I'm not sure how to interpret the log. But I see that you have a double quote at the end of your MGR_ID config value. This is an invalid value. It looks like that the deployment handles this more gracefully compared to the monitoring. Could you try to remove the double quote at the end and check if it is then working?
Alois
FUDForum. Page generated in 0.04940 seconds
