memory leak [message #1786243] |
Fri, 27 April 2018 13:58 |
I actually experience a memory leak using Gendoc 0.7.0 Papyrus Edition.
Can anybody confirm this?
/pica
Re: memory leak [message #1786285 is a reply to message #1786246] |
Sun, 29 April 2018 17:21 |
many thanks for the answer.
My current example is a 23 page GenDoc script, that I do not like to publish ;-)
Each generation eats some 1 GByte of memory.
/pica
Re: memory leak [message #1786370 is a reply to message #1786365] |
Wed, 02 May 2018 08:43 |
Hi Antonio,
- Eclipse version.
Oxygen.3
- Papyrus version.
Oxygen.3
- Acceleo version.
3.7.2
- Model size and number of models.
ups, at the very moment 1 model splitted into exactly 90 small submodels. Combined size of *.uml files is 194123 Bytes. Alltogether 518.8KByte.
- Are you using any profile?
No, at the Moment just plain vanilla UML, no profiles used. Neither SysML, nor BPMN, nor fUML. BTW, Moka is installed. The Moka model checker is active.
- Which type of diagrams are included in the file
At the Moment only class diagrams and state Charts.
Thanks a lot,
Carsten
PS I hope to get the allowance soon, to publish it under the CC by-nc-sa license ;-)
[Updated on: Wed, 02 May 2018 08:44] Report message to a moderator
Re: memory leak [message #1786424 is a reply to message #1786370] |
Thu, 03 May 2018 08:21 |
Tristan Faure Messages: 460 Registered: July 2009 |
Hello a tip (not sure it is documented somewhere) to reduce the memory footprint (if there are several gendoc tags)
declare the usage of the service : TagFileBuffer
@All what is the syntax do use services (i don't remember :() ? service="" or serviceId="" ?
[Updated on: Thu, 03 May 2018 08:22] Report message to a moderator
Re: memory leak [message #1786434 is a reply to message #1786424] |
Thu, 03 May 2018 09:14 |
Hello Tristan,
many thanks for that tip. I will try it.
But, since yesterday afternoon I get either a "String index out of range: 642" or a "String index out of range: 643" message on a former working GIT snapshot. I also rolled back my eclipse Installation. But that issue remains.
I asked my Business Manager to establish an NDA between us. That would allow me to send you my files for reference.
Now working on on a branch ;-)
Carsten
[Updated on: Thu, 03 May 2018 09:16] Report message to a moderator
Re: memory leak [message #1786525 is a reply to message #1786424] |
Sat, 05 May 2018 09:38 |
@Tristan -- That "String index out of range" issue was due to an unnamed Association (which is derived from uml::NamedElement) within a file not yet under GIT control.
/pica
Re: memory leak [message #1786526 is a reply to message #1786442] |
Sat, 05 May 2018 09:42 |
Hi Antonio,
here -- I forced it again -- multiple transformation runs in a row definitely make an out of memory error occur.
Currently that very Papyrus installation is configured to use up to 6GiByte of heap and 512MiByte of stack space.
/pica
FUDForum. Page generated in 0.04046 seconds
