Home » Newcomers » Newcomers » Eclipse crashed and now my workplace won't open. What should I do?
Eclipse crashed and now my workplace won't open. What should I do? [message #1786253] Fri, 27 April 2018 13:40 Go to next message
My Eclipse crashed and when I went to open it again it crashes when loading the workplace. I'm assuming the workplace didn't save correctly. Is there any easy fix? Should I make a new workplace? And what's the best way to do that?
This is Release 4.7.0 (Oxygen).
Here's the error message:
!ENTRY org.eclipse.osgi 4 0 2018-04-27 13:30:09.758
!MESSAGE Application error
!STACK 1
java.lang.NoClassDefFoundError: org/eclipse/core/resources/IContainer
	at org.eclipse.ui.internal.ide.application.IDEApplication.start(IDEApplication.java:152)
	at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:653)
	at org.eclipse.equinox.launcher.Main.basicRun(Main.java:590)
	at org.eclipse.equinox.launcher.Main.run(Main.java:1499)
Caused by: java.lang.ClassNotFoundException: An error occurred while automatically activating bundle org.eclipse.core.resources (94).
	at org.eclipse.osgi.internal.hooks.EclipseLazyStarter.postFindLocalClass(EclipseLazyStarter.java:112)
	at org.eclipse.osgi.internal.loader.classpath.ClasspathManager.findLocalClass(ClasspathManager.java:529)
	at org.eclipse.osgi.internal.loader.ModuleClassLoader.findLocalClass(ModuleClassLoader.java:328)
	at org.eclipse.osgi.internal.loader.BundleLoader.findLocalClass(BundleLoader.java:368)
	at org.eclipse.osgi.internal.loader.sources.SingleSourcePackage.loadClass(SingleSourcePackage.java:36)
	at org.eclipse.osgi.internal.loader.BundleLoader.findClassInternal(BundleLoader.java:442)
	at org.eclipse.osgi.internal.loader.BundleLoader.findClass(BundleLoader.java:395)
	at org.eclipse.osgi.internal.loader.BundleLoader.findClass(BundleLoader.java:387)
	at org.eclipse.osgi.internal.loader.ModuleClassLoader.loadClass(ModuleClassLoader.java:150)
	... 13 more
Caused by: org.osgi.framework.BundleException: Exception in org.eclipse.core.resources.ResourcesPlugin.start() of bundle org.eclipse.core.resources.
	at org.eclipse.osgi.internal.framework.BundleContextImpl.startActivator(BundleContextImpl.java:800)
	at org.eclipse.osgi.internal.framework.BundleContextImpl.start(BundleContextImpl.java:729)
	at org.eclipse.osgi.internal.framework.EquinoxBundle.startWorker0(EquinoxBundle.java:933)
	at org.eclipse.osgi.internal.framework.EquinoxBundle$EquinoxModule.startWorker(EquinoxBundle.java:309)
	at org.eclipse.osgi.container.Module.doStart(Module.java:581)
	at org.eclipse.osgi.container.Module.start(Module.java:449)
	at org.eclipse.osgi.framework.util.SecureAction.start(SecureAction.java:468)
	at org.eclipse.osgi.internal.hooks.EclipseLazyStarter.postFindLocalClass(EclipseLazyStarter.java:103)
	... 22 more
Caused by: org.eclipse.core.internal.resources.ResourceException: Incompatible file format. Workspace was saved with an incompatible version: 0.
	at org.eclipse.core.internal.resources.WorkspaceTreeReader.getReader(WorkspaceTreeReader.java:59)
	at org.eclipse.core.internal.resources.WorkspaceTreeReader.getReader(WorkspaceTreeReader.java:67)
	at org.eclipse.core.internal.resources.SaveManager.restoreTree(SaveManager.java:1056)
	at org.eclipse.core.internal.resources.SaveManager.restore(SaveManager.java:719)
	at org.eclipse.core.internal.resources.SaveManager.startup(SaveManager.java:1587)
	at org.eclipse.core.internal.resources.Workspace.startup(Workspace.java:2399)
	at org.eclipse.core.internal.resources.Workspace.open(Workspace.java:2156)
	at org.eclipse.core.resources.ResourcesPlugin.start(ResourcesPlugin.java:467)
	at org.eclipse.osgi.internal.framework.BundleContextImpl$3.run(BundleContextImpl.java:779)
	at org.eclipse.osgi.internal.framework.BundleContextImpl$3.run(BundleContextImpl.java:1)
	at org.eclipse.osgi.internal.framework.BundleContextImpl.startActivator(BundleContextImpl.java:772)
	... 29 more
[Updated on: Fri, 27 April 2018 14:07] by Moderator
Re: Eclipse crashed and now my workplace won't open. What should I do? [message #1786260 is a reply to message #1786253] Sat, 28 April 2018 00:49 Go to previous messageGo to next message
Yes, it looks like the workspace is corrupted (somewhere in the <workspace>/.metadata/.plugins/org.eclipse.core.resources). You could open a new workspace and use File -> Import... -> Existing Projects into Workspace to import the projects from the old workspace into the new workspace (pointing at the old workspace folder if the projects are physically nested in the old workspace folder).
Re: Eclipse crashed and now my workplace won't open. What should I do? [message #1786355 is a reply to message #1786260] Tue, 01 May 2018 19:25 Go to previous messageGo to next message
I've been having that problem a lot lately. What has worked for me, so far, is to force quit Eclipse if necessary. Then turn the computer off, leave it off for at least 20 seconds, and restart. Restart Eclipse, and if it come us at all, then move to a different workspace. Doing so appears to cause Eclipse to flush garbage from the workspace wherein you had problems. Then you can move back to the first workspace. If you are lucky, everything will be fine.
Re: Eclipse crashed and now my workplace won't open. What should I do? [message #1786358 is a reply to message #1786260] Tue, 01 May 2018 20:34 Go to previous message
What happens if you just trash the hidden file?
Previous Topic:Remove red box around brackets
Next Topic:ABAP Development Tools
Current Time: Thu Oct 30 00:07:47 EDT 2025
Powered by FUDForum. Page generated in 0.08292 seconds
