Home » Newcomers » Newcomers » Type Inference with Eclipse(JEP 286: Local-Variable Type Inference with Eclipse 4.7.3 (Oxygen 3))
Type Inference with Eclipse [message #1784146] Thu, 22 March 2018 21:51 Go to next message
Manuel Prochnow is currently offline Manuel ProchnowFriend
I updated my Eclipse how you tell us. But it dosen´t work.
The reserved type name var has the color violet and i think eclipse know the new oportunity.
But the Error message is:
var cannot be resolved to a type
why doesn´t work it?
I need youre help.
this is my code sniped:
var list = new ArrayList<String>(); // infers ArrayList<String>
var stream = list.stream(); // infers Stream<String>
// int
var zahl = 5;
// String
var string = "Hello World";
// BigDecimal
var objekt = BigDecimal.ONE;
Re: Type Inference with Eclipse [message #1784171 is a reply to message #1784146] Fri, 23 March 2018 08:23 Go to previous messageGo to next message
You installed this? https://marketplace.eclipse.org/content/java-10-support-oxygen
Ed Merks
Re: Type Inference with Eclipse [message #1784222 is a reply to message #1784171] Fri, 23 March 2018 17:27 Go to previous messageGo to next message
Yes. I have it installed as described in the Eclipse newsletter link.
4.7.3-build 20180322-1830
Re: Type Inference with Eclipse [message #1784223 is a reply to message #1784171] Fri, 23 March 2018 17:48 Go to previous messageGo to next message
Sorry ... i post it too fast ...
After updating the version no. is still 4.7.3 and not 4.7.3a!
Before updateing Eclipse leav the color of var black
After updating Eclipse change automatically the color of var to violet.
Re: Type Inference with Eclipse [message #1784238 is a reply to message #1784223] Sat, 24 March 2018 08:50 Go to previous message
So it's working now? You might need to set JDT preferences to Java 10, perhaps even have a Java 10 JDK configured, though I'm not sure about that....
Ed Merks
Previous Topic:Easiest way to build Eclipse IDE (JAVA) on my local PC
Next Topic:Plugins re-installation on any platform restart
Current Time: Wed Feb 05 07:46:42 GMT 2025
Powered by FUDForum. Page generated in 0.07962 seconds
