Home » Eclipse Projects » Eclipse TEA » How to execute Clean-Up Action
Re: How to execute Clean-Up Action [message #1792066 is a reply to message #1785392] |
Tue, 10 July 2018 16:43 |
John-Paul Cunliffe Messages: 2 Registered: February 2018 |
Hi Markus,
thanks for your reply. I am trying to get started, and followed your tutorial: https://www.eclipse.org/tea/documentation/samples/getting-started.php
I created a plugin project, added the classes you mention, added OSGI support and the dependencies (annotations.jar, org.eclipse.tea_core, javax.inject, org.eclipse.e4.core.annotations), and launched it as a eclipse application with the plugin itself activated (by default).
import javax.inject.Named;
import org.eclipse.e4.core.di.annotations.Execute;
import org.eclipse.tea.core.services.TaskingLog;
@Named("MyTask")
public class CleanUpTask {
@Execute
public void demo(final TaskingLog log) {
log.info("Hello World!");
import org.eclipse.tea.core.TaskExecutionContext;
import org.eclipse.tea.core.annotations.TaskChainContextInit;
import org.eclipse.tea.core.annotations.TaskChainMenuEntry;
import org.eclipse.tea.core.services.TaskChain;
import org.eclipse.tea.core.services.TaskChain.TaskChainId;
import org.osgi.service.component.annotations.Component;
@TaskChainId(description = "TaskChain", alias = "MyChainAlias")
@TaskChainMenuEntry(path = "TEA")
@Component
public class CleanUpChain implements TaskChain {
@TaskChainContextInit
public void init(final TaskExecutionContext c) {
c.addTask(CleanUpTask.class);
When I start, I get some logs, but no "hello world", no new entry under the "TEA" top menu bar, and a outside break point on the @execute method won't stop either. Also, in the started eclipse, I can see my Plugin-Name under installations details/plug-ins.
Quote:!SESSION 2018-07-10 18:46:09.638 -----------------------------------------------
eclipse.buildId=4.7.3.M20180301-0715
java.version=1.8.0_101
BootLoader constants: OS=win32, ARCH=x86_64, WS=win32, NL=de_DE
Framework arguments: -product org.eclipse.platform.ide
Command-line arguments: -product org.eclipse.platform.ide -data D:\ws\ipg/../runtime-EclipseApplication -dev file:D:/ws/ipg/.metadata/.plugins/org.eclipse.pde.core/Eclipse Application/dev.properties -os win32 -ws win32 -arch x86_64 -consoleLog
!ENTRY org.eclipse.ui 2 0 2018-07-10 18:46:21.210
!MESSAGE Warnings while parsing the images from the 'org.eclipse.ui.commandImages' extension point.
!SUBENTRY 1 org.eclipse.ui 2 0 2018-07-10 18:46:21.210
!MESSAGE Cannot bind to an undefined command: plug-in='org.eclipse.lsp4e', id='org.eclipse.lsp4e.togglehighlight'
SLF4J: Class path contains multiple SLF4J bindings.
SLF4J: Found binding in [bundleresource://1350.fwk1015658596:1/org/slf4j/impl/StaticLoggerBinder.class]
SLF4J: Found binding in [bundleresource://1350.fwk1015658596:2/org/slf4j/impl/StaticLoggerBinder.class]
SLF4J: See http://www.slf4j.org/codes.html#multiple_bindings for an explanation.
SLF4J: Actual binding is of type [ch.qos.logback.classic.util.ContextSelectorStaticBinder]
!ENTRY org.eclipse.jface 2 0 2018-07-10 18:46:29.069
!MESSAGE Keybinding conflicts occurred. They may interfere with normal accelerator operation.
!SUBENTRY 1 org.eclipse.jface 2 0 2018-07-10 18:46:29.069
!MESSAGE A conflict occurred for CTRL+SHIFT+T:
Binding(CTRL+SHIFT+T,
ParameterizedCommand(Command(org.eclipse.jdt.ui.navigate.open.type,Open Type,
Open a type in a Java editor,
Category(org.eclipse.ui.category.navigate,Navigate,null,true),
org.eclipse.ui.internal.WorkbenchHandlerServiceHandler@5eb1fd44,
,,true),null),
org.eclipse.ui.defaultAcceleratorConfiguration,
org.eclipse.ui.contexts.window,,,system)
ParameterizedCommand(Command(org.eclipse.lsp4e.symbolinworkspace,Go to Symbol in Workspace,
Category(org.eclipse.lsp4e.category,Language Servers,null,true),
org.eclipse.ui.internal.WorkbenchHandlerServiceHandler@20b42094,
,,true),null),
log4j:WARN No appenders could be found for logger (org.springsource.ide.eclipse.commons.core.templates.TemplateProcessor).
log4j:WARN Please initialize the log4j system properly.
18:46:35.217 [Worker-8] INFO c.g.t.t.d.PublishedGradleVersions - Gradle version information cache is up-to-date. Trying to read.
!ENTRY org.eclipse.egit.ui 2 0 2018-07-10 18:46:35.466
!MESSAGE Warning: The environment variable HOME is not set. The following directory will be used to store the Git
user global configuration and to define the default location to store repositories: 'C:\Users\XXX'. If this is
not correct please set the HOME environment variable and restart Eclipse. Otherwise Git for Windows and
EGit might behave differently since they see different configuration options.
This warning can be switched off on the Team > Git > Confirmations and Warnings preference page.
18:46:46.131 [Worker-13] DEBUG o.e.m.c.i.p.r.ProjectRegistryRefreshJob - Queued refresh request: [/RemoteSystemsTempFiles/pom.xml]
oldUrl: null
newUrl: file:///D:/ws/runtime-EclipseApplication/.metadata/.plugins/org.springsource.ide.eclipse.commons.gettingstarted/dashboard/1531241193216/index.html
18:46:49.004 [Worker-20] DEBUG o.e.a.i.i.DefaultLocalRepositoryProvider - Using manager EnhancedLocalRepositoryManager with priority 10.0 for d:\.m2\repo
18:46:49.060 [Worker-20] DEBUG o.e.a.i.i.DefaultLocalRepositoryProvider - Using manager EnhancedLocalRepositoryManager with priority 10.0 for d:\.m2\repo
18:46:49.062 [Worker-20] DEBUG o.e.m.c.i.p.r.ProjectRegistryManager - Refreshing: [L/RemoteSystemsTempFiles/pom.xml]
18:46:49.088 [Worker-20] DEBUG o.e.m.c.i.p.r.ProjectRegistryManager - Refreshed: [L/RemoteSystemsTempFiles/pom.xml]
Any suggestions?
[Updated on: Wed, 11 July 2018 12:35] Report message to a moderator
Current Time: Thu Oct 10 23:28:16 GMT 2024
Powered by FUDForum. Page generated in 0.02966 seconds
