Is Java 9 support sun.misc.ServiceConfigurationError? [message #1781328] |
Tue, 06 February 2018 06:50 |
Amit Mestha Messages: 1 Registered: February 2018 |
Currently I'm migrating my project from Java 7 to Java 9.
When building the project in getting below error.
Description Resource Path Location Type
The project was not built since its build path is incomplete. Cannot find the class file for sun.misc.ServiceConfigurationError. Fix the build path then try building this project java Unknown Java Problem
Also I have been using NativeCall.init(). and imported
import com.eaio.nativecall.IntCall;
import com.eaio.nativecall.NativeCall;
import com.eaio.nativecall.VoidCall;
for which Im getting below error
The type sun.misc.ServiceConfigurationError cannot be resolved. It is indirectly referenced from required .class files ModemWavSender.java /java/com/ha/common/modemwavsender line 51 Java Problem
FUDForum. Page generated in 0.03488 seconds
