WAR not working if built with Tycho [message #1779926] |
Mon, 15 January 2018 19:42 |
Chris Merg Messages: 12 Registered: January 2018 |
Hi everybody,
I'm currently switching to Tycho as in this example and face a problem when deploying my generated war file.
I just get 404 Error when opening the url even though I use the correct url.
I got the exactly same start levels in my .product file like in my .launch file (except java.servlet ofc) but when launching the app from eclipse everything works fine.
The only difference is that I got my app itself included in the launch config as plugin and in start levels but I can't add it to the .product file cuz my maven build fails with this error:
[ERROR] Cannot resolve dependencies of product bitnet.product:
[ERROR] eclipse-plugin artifact with ID "BitNet" and version matching "0.0.0" was not found in the target platform
When removing my app from the launch options I also get 404 Error when launching from eclipse.
Here is the output from osgi ss command:
"Framework is launched."
id State Bundle
0 ACTIVE org.eclipse.osgi_3.12.50.v20170928-1321
Fragments=1
1 RESOLVED org.eclipse.equinox.servletbridge.extensionbundle_1.3.0
Master=0
2 ACTIVE Core_1.0.0.20180115-1859
3 ACTIVE com.ibm.icu.base_58.2.0.v20170418-1837
4 ACTIVE javax.xml_1.3.4.v201005080400
5 ACTIVE org.apache.commons.fileupload_1.3.2.v20170320-2229
6 ACTIVE org.apache.commons.io_2.2.0.v201405211200
7 ACTIVE org.apache.felix.gogo.command_0.10.0.v201209301215
8 ACTIVE org.apache.felix.gogo.runtime_0.10.0.v201209301036
9 ACTIVE org.apache.felix.gogo.shell_0.10.0.v201212101605
10 ACTIVE org.apache.felix.scr_2.0.10.v20170501-2007
11 ACTIVE org.eclipse.core.commands_3.9.0.v20170530-1048
12 ACTIVE org.eclipse.core.contenttype_3.6.0.v20170207-1037
13 ACTIVE org.eclipse.core.databinding_1.6.100.v20170515-1119
14 ACTIVE org.eclipse.core.databinding.beans_1.4.0.v20170210-0856
15 ACTIVE org.eclipse.core.databinding.observable_1.6.100.v20170515-1119
16 ACTIVE org.eclipse.core.databinding.property_1.6.100.v20170515-1119
17 ACTIVE org.eclipse.core.expressions_3.6.0.v20170207-1037
18 ACTIVE org.eclipse.core.jobs_3.9.2.v20171030-1027
19 ACTIVE org.eclipse.core.runtime_3.13.0.v20170207-1030
20 ACTIVE org.eclipse.equinox.app_1.3.400.v20150715-1528
21 ACTIVE org.eclipse.equinox.cm_1.2.0.v20170105-1446
22 ACTIVE org.eclipse.equinox.common_3.9.0.v20170207-1454
23 ACTIVE org.eclipse.equinox.console_1.1.300.v20170512-2111
24 ACTIVE org.eclipse.equinox.event_1.4.0.v20170105-1446
25 ACTIVE org.eclipse.equinox.http.registry_1.1.400.v20150715-1528
26 ACTIVE org.eclipse.equinox.http.servlet_1.4.0.v20170524-1452
27 ACTIVE org.eclipse.equinox.http.servletbridge_1.0.300.v20130327-1442
28 RESOLVED org.eclipse.equinox.launcher_1.4.0.v20161219-1356
Fragments=29
29 RESOLVED org.eclipse.equinox.launcher.gtk.linux.x86_64_1.1.551.v20171108-1834
Master=28
30 ACTIVE org.eclipse.equinox.preferences_3.7.0.v20170126-2132
31 ACTIVE org.eclipse.equinox.registry_3.7.0.v20170222-1344
32 ACTIVE org.eclipse.equinox.servletbridge_1.3.200.v20160128-1435
33 ACTIVE org.eclipse.help_3.8.1.v20170815-1448
34 ACTIVE org.eclipse.jdt.junit.runtime_3.4.651.v20171130-0906
35 ACTIVE org.eclipse.osgi.services_3.6.0.v20170228-1906
36 ACTIVE org.eclipse.osgi.util_3.4.0.v20170111-1608
37 ACTIVE org.eclipse.rap.filedialog_3.4.0.20171017-0945
38 ACTIVE org.eclipse.rap.fileupload_3.4.0.20171017-0945
39 ACTIVE org.eclipse.rap.jface_3.4.0.20171018-1122
40 ACTIVE org.eclipse.rap.jface.databinding_3.4.0.20171017-0945
41 ACTIVE org.eclipse.rap.nebula.jface.gridviewer_3.4.0.20171017-0945
42 ACTIVE org.eclipse.rap.nebula.widgets.grid_3.4.0.20171020-1239
43 ACTIVE org.eclipse.rap.rwt_3.4.0.20171130-0837
44 ACTIVE org.eclipse.rap.rwt.osgi_3.4.0.20171017-0945
45 ACTIVE org.hamcrest.core_1.3.0.v201303031735
46 ACTIVE org.junit_4.12.0.v201504281640
Thanks for any hints!
Chris
[Updated on: Tue, 16 January 2018 22:33] Report message to a moderator
Re: WAR not working if built with Tycho [message #1780009 is a reply to message #1780007] |
Tue, 16 January 2018 14:07 |
Where do I put my app bundle inside the product file? This is my product file:
<?pde version="3.5"?>
<product name="BitNet" uid="bitnet.product" version="1.0.0.qualifier" useFeatures="false" includeLaunchers="false">
<configIni use="default">
</configIni>
<launcherArgs>
</launcherArgs>
<plugins>
<plugin id="Core"/>
<plugin id="com.ibm.icu.base"/>
<plugin id="javax.xml"/>
<plugin id="org.apache.commons.fileupload"/>
<plugin id="org.apache.commons.io"/>
<plugin id="org.apache.felix.gogo.command"/>
<plugin id="org.apache.felix.gogo.runtime"/>
<plugin id="org.apache.felix.gogo.shell"/>
<plugin id="org.apache.felix.scr"/>
<plugin id="org.eclipse.core.commands"/>
<plugin id="org.eclipse.core.contenttype"/>
<plugin id="org.eclipse.core.databinding"/>
<plugin id="org.eclipse.core.databinding.beans"/>
<plugin id="org.eclipse.core.databinding.observable"/>
<plugin id="org.eclipse.core.databinding.property"/>
<plugin id="org.eclipse.core.expressions"/>
<plugin id="org.eclipse.core.jobs"/>
<plugin id="org.eclipse.core.runtime"/>
<plugin id="org.eclipse.equinox.app"/>
<plugin id="org.eclipse.equinox.cm"/>
<plugin id="org.eclipse.equinox.common"/>
<plugin id="org.eclipse.equinox.console"/>
<plugin id="org.eclipse.equinox.event"/>
<plugin id="org.eclipse.equinox.http.registry"/>
<plugin id="org.eclipse.equinox.http.servlet"/>
<plugin id="org.eclipse.equinox.http.servletbridge"/>
<plugin id="org.eclipse.equinox.preferences"/>
<plugin id="org.eclipse.equinox.registry"/>
<plugin id="org.eclipse.equinox.servletbridge"/>
<plugin id="org.eclipse.help"/>
<plugin id="org.eclipse.osgi"/>
<plugin id="org.eclipse.osgi.services"/>
<plugin id="org.eclipse.osgi.util"/>
<plugin id="org.eclipse.rap.filedialog"/>
<plugin id="org.eclipse.rap.fileupload"/>
<plugin id="org.eclipse.rap.jface"/>
<plugin id="org.eclipse.rap.jface.databinding"/>
<plugin id="org.eclipse.rap.nebula.jface.gridviewer"/>
<plugin id="org.eclipse.rap.nebula.widgets.grid"/>
<plugin id="org.eclipse.rap.rwt"/>
<plugin id="org.eclipse.rap.rwt.osgi"/>
</plugins>
<configurations>
<plugin id="Core" autoStart="true" startLevel="0" />
<plugin id="com.ibm.icu.base" autoStart="true" startLevel="0" />
<plugin id="javax.xml" autoStart="true" startLevel="0" />
<plugin id="org.apache.commons.fileupload" autoStart="true" startLevel="0" />
<plugin id="org.apache.commons.io" autoStart="true" startLevel="0" />
<plugin id="org.apache.felix.gogo.command" autoStart="true" startLevel="0" />
<plugin id="org.apache.felix.gogo.runtime" autoStart="true" startLevel="0" />
<plugin id="org.apache.felix.gogo.shell" autoStart="true" startLevel="0" />
<plugin id="org.apache.felix.scr" autoStart="true" startLevel="0" />
<plugin id="org.eclipse.core.commands" autoStart="true" startLevel="0" />
<plugin id="org.eclipse.core.contenttype" autoStart="true" startLevel="0" />
<plugin id="org.eclipse.core.databinding" autoStart="true" startLevel="0" />
<plugin id="org.eclipse.core.databinding.beans" autoStart="true" startLevel="0" />
<plugin id="org.eclipse.core.databinding.observable" autoStart="true" startLevel="0" />
<plugin id="org.eclipse.core.databinding.property" autoStart="true" startLevel="0" />
<plugin id="org.eclipse.core.expressions" autoStart="true" startLevel="0" />
<plugin id="org.eclipse.core.jobs" autoStart="true" startLevel="0" />
<plugin id="org.eclipse.core.runtime" autoStart="true" startLevel="0" />
<plugin id="org.eclipse.equinox.app" autoStart="true" startLevel="0" />
<plugin id="org.eclipse.equinox.cm" autoStart="true" startLevel="0" />
<plugin id="org.eclipse.equinox.common" autoStart="true" startLevel="0" />
<plugin id="org.eclipse.equinox.event" autoStart="true" startLevel="0" />
<plugin id="org.eclipse.equinox.http.registry" autoStart="true" startLevel="0" />
<plugin id="org.eclipse.equinox.http.servlet" autoStart="true" startLevel="0" />
<plugin id="org.eclipse.equinox.http.servletbridge" autoStart="true" startLevel="0" />
<plugin id="org.eclipse.equinox.preferences" autoStart="true" startLevel="0" />
<plugin id="org.eclipse.equinox.registry" autoStart="true" startLevel="0" />
<plugin id="org.eclipse.equinox.servletbridge" autoStart="true" startLevel="0" />
<plugin id="org.eclipse.help" autoStart="true" startLevel="0" />
<plugin id="org.eclipse.osgi" autoStart="true" startLevel="0" />
<plugin id="org.eclipse.osgi.services" autoStart="true" startLevel="0" />
<plugin id="org.eclipse.osgi.util" autoStart="true" startLevel="0" />
<plugin id="org.eclipse.rap.filedialog" autoStart="true" startLevel="0" />
<plugin id="org.eclipse.rap.fileupload" autoStart="true" startLevel="0" />
<plugin id="org.eclipse.rap.jface" autoStart="true" startLevel="0" />
<plugin id="org.eclipse.rap.jface.databinding" autoStart="true" startLevel="0" />
<plugin id="org.eclipse.rap.nebula.jface.gridviewer" autoStart="true" startLevel="0" />
<plugin id="org.eclipse.rap.nebula.widgets.grid" autoStart="true" startLevel="0" />
<plugin id="org.eclipse.rap.rwt" autoStart="true" startLevel="0" />
<plugin id="org.eclipse.rap.rwt.osgi" autoStart="true" startLevel="0" />
</configurations>
</product>
My URL looks like this: http://serverip:8080/bitnet/bitnet
The path is set like this: application.addEntryPoint("/bitnet", BasicEntryPoint.class, properties);
Note that before using Tycho I always used Libra War Tool and it's working fine with it. So the URL should be fine. Also when deploying the same app with Libra Tool I have my app bundle started in the osgi console:
1 ACTIVE BitNet_1.0.0.201801162328
The bundle is also listed as plugin in the .warproduct file. But I'm not able to add my app bundle to the .product file plugins as I get the already posted error when building with maven.
No, Core is a custom plugin I'm using. My app bundle is called BitNet but it's not listed in the osgi console.
Thanks for your help,
Chris
[Updated on: Tue, 16 January 2018 22:32] Report message to a moderator
FUDForum. Page generated in 0.04455 seconds
