Home » Eclipse Projects » OM2M » Create AE via MQTT Binding(MQTT Binding)
Create AE via MQTT Binding [message #1764634] Thu, 01 June 2017 05:12 Go to next message
teak jin kim is currently offline teak jin kimFriend
Hi.
I already did Create AE via HTTP (REST API) following OM2M HTTP binding Wiki.
There were many examples like create AE , Create DESCRIPTOR container so on..
But I don't know How to send a message via MQTT binding.
Is Anyone know How to do this?
I need a topic and payload that can follow to do this.
Also If you have a example like under method plz tell me.
1. Create a application
2. Create a DESCRIPTOR container
3. Create a description contentInstance
4. Create a DATA container
5. Create a data contentInstance
Is anyone know how to do this reply me.!
Re: Create AE via MQTT Binding [message #1764829 is a reply to message #1764634] Fri, 02 June 2017 13:48 Go to previous messageGo to next message
Maite Bezunartea is currently offline Maite BezunarteaFriend
There is an example on how to create a container in the MQTT Binding tutorial:
https://wiki.eclipse.org/OM2M/one/MQTT_Binding
You can use tools such as MQTTLens to test this.
Cheers!
[Updated on: Fri, 02 June 2017 13:49]
Report message to a moderator
Re: Create AE via MQTT Binding [message #1764955 is a reply to message #1764829] Sun, 04 June 2017 23:59 Go to previous messageGo to next message
Thank you for your reply.
I tried Create Container via MQTT and it responsed 'there is no parent AE'
So I tried to make Application for and here is my topic and json.
topic : /oneM2M/req/MY-SENSOR/in-cse/json
payload :
"m2m:rqp" : {
"fr" : "MY-SENSOR",
"to" : "/in-cse",
"op" : 1,
"rqi": 123456,
"pc": {
"m2m:ae" : {
"rn": "MY-SENSOR",
"rr": "false"
"ty": 2
But still not working So Can you give me a example to make AE?
like https://wiki.eclipse.org/OM2M/REST_API page
Create a "MY_SENSOR" application >> This API to MQTT
Re: Create AE via MQTT Binding [message #1765050 is a reply to message #1764955] Tue, 06 June 2017 08:04 Go to previous messageGo to next message
This works for me:
Topic: /oneM2M/req/MY-SENSOR/in-cse/json
Payload:
"m2m:rqp": {
"fr" : "admin:admin",
"to" : "/in-cse/in-name",
"op" : 1,
"rqi": 123456,
"pc": {
"m2m:ae" : {
"api": "app-sensor",
"rr": "false",
"rn": "MY-SENSOR"
"ty": 2
I hope it helps.
Cheers!
Re: Create AE via MQTT Binding [message #1776824 is a reply to message #1764829] Wed, 22 November 2017 05:15 Go to previous messageGo to next message
hieu tran is currently offline hieu tranFriend
What is MY-SENSOR ? Can i understand it is Client ID of mqttlen
And, when you publish into Topic: /oneM2M/req/MY-SENSOR/in-cse/json
Have any response ? Could you show me it ?
[Updated on: Wed, 22 November 2017 14:41]
Re: Create AE via MQTT Binding [message #1778805 is a reply to message #1764634] Thu, 21 December 2017 16:01 Go to previous messageGo to next message
Gordian Zomer is currently offline Gordian ZomerFriend
Whenever I throw a correctly formatted JSON object at the MQTT broker, I get the following error in in-cse:
[INFO] - org.eclipse.om2m.core.router.Router
OM2M exception caught in Router: No Operation provided
I followed examples provided here, in "Test MQTT blinding in OM2M" and in the MQTT bindings section. Nothing seems to work.
The part which says "No operation provided", does it refer to "op" field in "m2m:rqp"?
Re: Create AE via MQTT Binding [message #1778840 is a reply to message #1764634] Fri, 22 December 2017 11:35 Go to previous messageGo to next message
I started to do some debugging through the MQTT request process. It turns out that an MQTT request is caught by the MqttRequestHelper and send to the method stringToObj in datamapping/jaxb/Mapper for un-marshalling. The string representation seems to be valid, but un-marshalling returns an empty object?
Re: Create AE via MQTT Binding [message #1778841 is a reply to message #1764634] Fri, 22 December 2017 11:36 Go to previous messageGo to next message
Re: Create AE via MQTT Binding [message #1778843 is a reply to message #1778841] Fri, 22 December 2017 11:41 Go to previous messageGo to next message
I found in Router.java the exception: - line 130
code]if(request.getOperation() == null){
throw new BadRequestException("No Operation provided");
}[[/code]
The code seem not to read the "op" filed.
Do you have any idea to fix these problem ?
Re: Create AE via MQTT Binding [message #1778848 is a reply to message #1778843] Fri, 22 December 2017 13:13 Go to previous messageGo to next message
hieu tran wrote on Fri, 22 December 2017 11:41
}[[/code]
The exception is not the problem. It seems that the request is empty (and therefore the operation is null), which means that the incoming MQTT request is not parsed. I think the un-marshaller is broken.
[Updated on: Fri, 22 December 2017 13:15]
Re: Create AE via MQTT Binding [message #1778849 is a reply to message #1778843] Fri, 22 December 2017 13:13 Go to previous messageGo to next message
double post
[Updated on: Fri, 22 December 2017 13:14]
Re: Create AE via MQTT Binding [message #1778960 is a reply to message #1778849] Tue, 26 December 2017 14:47 Go to previous messageGo to next message
Hung Nguyen is currently offline Hung NguyenFriend
Anyone can fix "op" problem?
I have same problem that No operation provided.
Any idea to fix that?
Re: Create AE via MQTT Binding [message #1782331 is a reply to message #1778960] Thu, 22 February 2018 05:31 Go to previous messageGo to next message
Muhammad Kamran is currently offline Muhammad KamranFriend
Hi everyone, I am also getting same response, anybody can help to fix that? dms.stringToObj (payload) returns an empty object.
Re: Create AE via MQTT Binding [message #1783210 is a reply to message #1782331] Fri, 09 March 2018 08:45 Go to previous messageGo to next message
Loula Beck is currently offline Loula BeckFriend
Hi, I am facing the same issue. Here is the request I send and the respond I get :
                "m2m:rqp": {
                    "fr": "SENSOR2",
                    "to": "/mn-cse/RSU/SENSOR2/DATA",
		    "op": 1,
                    "rqi": 179,
                    "pc": {
                        "m2m:cin": {
                        "cnf": "dht2",
                        "con": "24.60_25.60"
                    "ty": 4
   "m2m:rsp" : {
      "m2m:rsc" : 4000,
      "m2m:pc" : "No Operation provided",
      "m2m:fr" : "/mn-cse"
If someone know how I can fix it, I could use some help.
Re: Create AE via MQTT Binding [message #1783217 is a reply to message #1783210] Fri, 09 March 2018 10:03 Go to previous messageGo to next message
send request as below:
"m2m:rqp": {
"m2m:fr": "SENSOR2",
"m2m:to": "/mn-cse/RSU/SENSOR2/DATA",
"m2m:op": 1,
"m2m:rqi": 179,
"m2m:pc": {
"m2m:cin": {
"cnf": "dht2",
"m2m:ty": 4
Kamran
Re: Create AE via MQTT Binding [message #1783223 is a reply to message #1783217] Fri, 09 March 2018 10:59 Go to previous messageGo to next message
Ok, first, thank you for your quick answer.
I tried your solution and I now have a different issue :
   "m2m:rsp" : {
      "m2m:rsc" : 4004,
      "m2m:rqi" : "4",
      "m2m:pc" : "Cannot find parent resource",
      "m2m:to" : "SENSOR2",
Re: Create AE via MQTT Binding [message #1783230 is a reply to message #1783223] Fri, 09 March 2018 12:35 Go to previous messageGo to next message
Have you created AE and Container?
Kamran
Re: Create AE via MQTT Binding [message #1783236 is a reply to message #1783230] Fri, 09 March 2018 13:10 Go to previous messageGo to next message
Are you referring to the 3 JSON shown in the MQTT Binding tutorial ? If so yes, at least I tried. Here are the messages I send and receive :
   "m2m:rqp": {
      "m2m:to": "/mn-cse",
      "m2m:op": 2,
      "m2m:rqi": 1111111
    "m2m:rqp" : {
        "m2m:fr" : "SENSOR2",
        "m2m:to" : "/mn-cse/mn-name/SENSOR2",
        "m2m:op" : 1,
        "m2m:rqi": 123456,
        "m2m:pc": {
            "m2m:cnt" : {
                "rn": "DATA"
        "m2m:ty": 3
   "m2m:rsp" : {
      "m2m:rsc" : 2000,
      "m2m:rqi" : "1111111",
      "m2m:pc" : {
         "m2m:cb" : {
            "rn" : "mn-name",
            "ty" : 5,
            "ri" : "/mn-cse",
            "ct" : "20180308T164949",
            "lt" : "20180308T164949",
            "acpi" : [ "/mn-cse/acp-207203953" ],
            "cst" : 1,
            "csi" : "mn-cse",
            "srt" : [ 1, 2, 3, 4, 5, 9, 14, 15, 16, 17, 23, 28 ],
            "poa" : [ "http://127.0.0.1:8282/" ]
   "m2m:rsp" : {
      "m2m:rsc" : 4004,
      "m2m:rqi" : "123456",
      "m2m:pc" : "Resource not found",
                "m2m:rqp": {
                    "m2m:to": "/mn-cse/mn-name/SENSOR2/DATA",
                    "m2m:op": 1,
                    "m2m:rqi": "0",
                    "m2m:pc": {
                        "m2m:cin": {
                            "cnf": "dht2",
                            "con": "25.30_28.40"
                    "m2m:ty": 4
   "m2m:rsp" : {
      "m2m:rsc" : 4004,
      "m2m:rqi" : "0",
Re: Create AE via MQTT Binding [message #1783239 is a reply to message #1783236] Fri, 09 March 2018 13:40 Go to previous messageGo to next message
It seems that AE is not created.
Create AE i.e. "SENSOR2" through request as below:
"m2m:rqp": {
"m2m:fr" : "admin:admin",
"m2m:to" : "/in-cse/in-name",
"m2m:op" : 1,
"m2m:rqi": 123456,
"m2m:pc": {
"m2m:ae": {
"api": "123",
"rr": "true",
"rn": "SENSOR2"
"m2m:ty": 2
Kamran
Re: Create AE via MQTT Binding [message #1783242 is a reply to message #1783239] Fri, 09 March 2018 14:11 Go to previous messageGo to next message
I added the creation of the AE and now I have this kind of error :
   "m2m:rsp" : {
      "m2m:rsc" : 4105,
      "m2m:rqi" : "2222222",
      "m2m:pc" : "Name already present in the parent collection.",
      "m2m:to" : "admin:admin",
   "m2m:rsp" : {
      "m2m:rsc" : 4103,
      "m2m:pc" : "Unknown or unauthorized originator",
The error I have when I try to update the container is the same : "Resource not found "
Re: Create AE via MQTT Binding [message #1783243 is a reply to message #1783223] Fri, 09 March 2018 14:21 Go to previous messageGo to next message
Thanks for your helping.
Can you tell me how you know it ?
Did you find in source code or other document ? Can you share with me ?
Re: Create AE via MQTT Binding [message #1783244 is a reply to message #1783243] Fri, 09 March 2018 14:41 Go to previous messageGo to next message
There is nothing to do with the source code.
To come to this point I followed those tutorials, bu I assume you have already look at those :
https://www.eclipse.org/forums/index.php/t/1090165/
Re: Create AE via MQTT Binding [message #1783324 is a reply to message #1783242] Mon, 12 March 2018 05:30 Go to previous messageGo to next message
Can you show me three requests and their corresponding responses?
1. AE creation
2. Container Creation
3. Content instance creation
Kamran
[Updated on: Mon, 12 March 2018 05:32]
Re: Create AE via MQTT Binding [message #1783334 is a reply to message #1783324] Mon, 12 March 2018 07:38 Go to previous messageGo to next message
Hi, I am not so sure of what I am doing but to me the requests are the following :
1. AE creation
        "m2m:rqp": {
                "m2m:to" : "/mn-cse/mn-name",
                "m2m:op" : 1,
                "m2m:rqi": 2222222,
                "m2m:pc": {
                        "m2m:ae": {
                        "api": "123",
                        "rr": "true",
                        "rn": "SENSOR2"
                "m2m:ty": 2
2.Container Creation
    "m2m:rqp" : {
        "m2m:op" : 1,
        "m2m:rqi": 123456,
        "m2m:pc": {
            "m2m:cnt" : {
                "rn": "DATA"
        "m2m:ty": 3
                "m2m:rqp": {
                    "m2m:op": 1,
                    "m2m:rqi": "%s",
                    "m2m:pc": {
                        "m2m:cin": {
                            "cnf": "dht2",
                            "con": "%s"
                    "m2m:ty": 4
Re: Create AE via MQTT Binding [message #1783335 is a reply to message #1783334] Mon, 12 March 2018 07:48 Go to previous messageGo to next message
Modify container and content instance request as follow
It seems that AE has been created but Container not created due to unauthorized originator, as "m2m:fr" parameter is not properly defined.
Kamran
Re: Create AE via MQTT Binding [message #1783337 is a reply to message #1783335] Mon, 12 March 2018 08:28 Go to previous message
It is now working fine !
Thank you for the help (:
Previous Topic:Test MQTT blinding in OM2M
Next Topic: Eclipse OM2M v1.3.0
Current Time: Sat Dec 21 12:28:43 GMT 2024
Powered by FUDForum. Page generated in 0.07092 seconds
