Home » Language IDEs » Java Development Tools (JDT) » Inverted SWT design?(inverted SWT design )
Inverted SWT design? [message #1775772] Mon, 06 November 2017 08:33 Go to next message
Alex Lim is currently offline Alex LimFriend
So recently I've installed the Swing Designer, SWT Designer and WindowBuilder on eclipse 4.7.1a. When i created a new project and open up the design window, the application window is inverted (refer to attached image). What causes this to happen?
index.php/fa/31227/0/
Re: Inverted SWT design? [message #1775817 is a reply to message #1775772] Mon, 06 November 2017 18:54 Go to previous message
Stephan Herrmann is currently offline Stephan HerrmannFriend
<hint>Have you seen https://www.eclipse.org/forums/index.php/f/214/ ?</hint>
Previous Topic:.java file does not open in Java Editor
Next Topic:trying to port project to Java 9 using Oxygen.1a, can't figure out errors
Current Time: Mon Dec 30 16:51:39 GMT 2024
Powered by FUDForum. Page generated in 0.03895 seconds
