Re: Compilation Error [message #1772751 is a reply to message #1772742] |
Thu, 14 September 2017 17:49 |
levven testing Messages: 5 Registered: September 2017 |
Hey thank you for your reply. I did try what you asked me. I also googled it and found this link on the same:
https://www.eclipse.org/forums/index.php/t/1083764/
Unfortunately it still didn't work for me. Following are the messages in the Eclipse console window:
0 [main] INFO text.xtext.generator.XtextGenerator - Initializing Xtext generator
12 [main] INFO lipse.emf.mwe.utils.StandaloneSetup - Adding generated EPackage 'org.eclipse.xtext.common.types.TypesPackage'
212 [main] WARN lipse.emf.mwe.utils.StandaloneSetup - Skipping conflicting project annotations at 'archive:file:/C:/ESH/eclipse/configuration/org.eclipse.osgi/453/0/.cp/lib/annotations.jar!/' and using 'archive:file:/C:/ESH/ws/.metadata/.plugins/org.eclipse.pde.core/.bundle_pool/plugins/org.eclipse.pde.ds.lib_1.1.0.v20170303-1624/annotations.jar!/' instead.
488 [main] WARN lipse.emf.mwe.utils.StandaloneSetup - No project file found for C:\ESH\git\smarthome\bundles\model\org.eclipse.smarthome.model.item\src. The folder was neither an Eclipse 'bin' folder, nor a Maven 'target/classes' folder.
501 [main] WARN lipse.emf.mwe.utils.StandaloneSetup - No project file found for C:\ESH\git\smarthome\bundles\model\org.eclipse.smarthome.model.persistence\src. The folder was neither an Eclipse 'bin' folder, nor a Maven 'target/classes' folder.
513 [main] WARN lipse.emf.mwe.utils.StandaloneSetup - No project file found for C:\ESH\git\smarthome\bundles\model\org.eclipse.smarthome.model.rule\src. The folder was neither an Eclipse 'bin' folder, nor a Maven 'target/classes' folder.
532 [main] WARN lipse.emf.mwe.utils.StandaloneSetup - No project file found for C:\ESH\git\smarthome\bundles\model\org.eclipse.smarthome.model.script\src. The folder was neither an Eclipse 'bin' folder, nor a Maven 'target/classes' folder.
545 [main] WARN lipse.emf.mwe.utils.StandaloneSetup - No project file found for C:\ESH\git\smarthome\bundles\model\org.eclipse.smarthome.model.sitemap\src. The folder was neither an Eclipse 'bin' folder, nor a Maven 'target/classes' folder.
560 [main] WARN lipse.emf.mwe.utils.StandaloneSetup - No project file found for C:\ESH\git\smarthome\bundles\model\org.eclipse.smarthome.model.thing\src. The folder was neither an Eclipse 'bin' folder, nor a Maven 'target/classes' folder.
567 [main] INFO lipse.emf.mwe.utils.StandaloneSetup - Registering project org.eclipse.smarthome.model.item at 'file:/C:/ESH/git/smarthome/bundles/model/org.eclipse.smarthome.model.item/'
567 [main] INFO lipse.emf.mwe.utils.StandaloneSetup - Registering project org.eclipse.smarthome.model.item.ide at 'file:/C:/ESH/git/smarthome/bundles/model/org.eclipse.smarthome.model.item.ide/'
568 [main] INFO lipse.emf.mwe.utils.StandaloneSetup - Registering project org.eclipse.smarthome.model.item.ui at 'file:/C:/ESH/git/smarthome/bundles/model/org.eclipse.smarthome.model.item.ui/'
577 [main] INFO lipse.emf.mwe.utils.StandaloneSetup - Using resourceSet registry. The registered Packages will not be registered in the global EPackage.Registry.INSTANCE!
805 [main] INFO clipse.emf.mwe.utils.GenModelHelper - Registered GenModel 'http://www.eclipse.org/Xtext/Xbase/XAnnotations' from 'platform:/resource/org.eclipse.xtext.xbase/model/Xbase.genmodel'
811 [main] INFO clipse.emf.mwe.utils.GenModelHelper - Registered GenModel 'http://www.eclipse.org/xtext/xbase/Xtype' from 'platform:/resource/org.eclipse.xtext.xbase/model/Xbase.genmodel'
830 [main] INFO clipse.emf.mwe.utils.GenModelHelper - Registered GenModel 'http://www.eclipse.org/xtext/xbase/Xbase' from 'platform:/resource/org.eclipse.xtext.xbase/model/Xbase.genmodel'
830 [main] INFO clipse.emf.mwe.utils.GenModelHelper - Registered GenModel 'http://www.eclipse.org/xtext/common/JavaVMTypes' from 'platform:/resource/org.eclipse.xtext.common.types/model/JavaVMTypes.genmodel'
1605 [main] INFO text.xtext.generator.XtextGenerator - Initializing Xtext generator
1606 [main] INFO lipse.emf.mwe.utils.StandaloneSetup - Adding generated EPackage 'org.eclipse.xtext.common.types.TypesPackage'
1612 [main] WARN lipse.emf.mwe.utils.StandaloneSetup - Skipping conflicting project annotations at 'archive:file:/C:/ESH/ws/.metadata/.plugins/org.eclipse.pde.core/.bundle_pool/plugins/org.eclipse.pde.ds.lib_1.1.0.v20170303-1624/annotations.jar!/' and using 'archive:file:/C:/ESH/eclipse/configuration/org.eclipse.osgi/453/0/.cp/lib/annotations.jar!/' instead.
1665 [main] WARN lipse.emf.mwe.utils.StandaloneSetup - Skipping conflicting project annotations at 'archive:file:/C:/ESH/eclipse/configuration/org.eclipse.osgi/453/0/.cp/lib/annotations.jar!/' and using 'archive:file:/C:/ESH/ws/.metadata/.plugins/org.eclipse.pde.core/.bundle_pool/plugins/org.eclipse.pde.ds.lib_1.1.0.v20170303-1624/annotations.jar!/' instead.
1972 [main] WARN lipse.emf.mwe.utils.StandaloneSetup - No project file found for C:\ESH\git\smarthome\bundles\model\org.eclipse.smarthome.model.item\src. The folder was neither an Eclipse 'bin' folder, nor a Maven 'target/classes' folder.
1988 [main] WARN lipse.emf.mwe.utils.StandaloneSetup - No project file found for C:\ESH\git\smarthome\bundles\model\org.eclipse.smarthome.model.persistence\src. The folder was neither an Eclipse 'bin' folder, nor a Maven 'target/classes' folder.
2002 [main] WARN lipse.emf.mwe.utils.StandaloneSetup - No project file found for C:\ESH\git\smarthome\bundles\model\org.eclipse.smarthome.model.rule\src. The folder was neither an Eclipse 'bin' folder, nor a Maven 'target/classes' folder.
2025 [main] WARN lipse.emf.mwe.utils.StandaloneSetup - No project file found for C:\ESH\git\smarthome\bundles\model\org.eclipse.smarthome.model.script\src. The folder was neither an Eclipse 'bin' folder, nor a Maven 'target/classes' folder.
2034 [main] WARN lipse.emf.mwe.utils.StandaloneSetup - No project file found for C:\ESH\git\smarthome\bundles\model\org.eclipse.smarthome.model.sitemap\src. The folder was neither an Eclipse 'bin' folder, nor a Maven 'target/classes' folder.
2044 [main] WARN lipse.emf.mwe.utils.StandaloneSetup - No project file found for C:\ESH\git\smarthome\bundles\model\org.eclipse.smarthome.model.thing\src. The folder was neither an Eclipse 'bin' folder, nor a Maven 'target/classes' folder.
2047 [main] INFO lipse.emf.mwe.utils.StandaloneSetup - Registering project org.eclipse.smarthome.model.sitemap at 'file:/C:/ESH/git/smarthome/bundles/model/org.eclipse.smarthome.model.sitemap/'
2048 [main] INFO lipse.emf.mwe.utils.StandaloneSetup - Registering project org.eclipse.smarthome.model.sitemap.ide at 'file:/C:/ESH/git/smarthome/bundles/model/org.eclipse.smarthome.model.sitemap.ide/'
2048 [main] INFO lipse.emf.mwe.utils.StandaloneSetup - Registering project org.eclipse.smarthome.model.sitemap.ui at 'file:/C:/ESH/git/smarthome/bundles/model/org.eclipse.smarthome.model.sitemap.ui/'
2049 [main] INFO lipse.emf.mwe.utils.StandaloneSetup - Using resourceSet registry. The registered Packages will not be registered in the global EPackage.Registry.INSTANCE!
2502 [main] INFO text.xtext.generator.XtextGenerator - Initializing Xtext generator
2502 [main] INFO lipse.emf.mwe.utils.StandaloneSetup - Adding generated EPackage 'org.eclipse.xtext.common.types.TypesPackage'
2506 [main] WARN lipse.emf.mwe.utils.StandaloneSetup - Skipping conflicting project annotations at 'archive:file:/C:/ESH/ws/.metadata/.plugins/org.eclipse.pde.core/.bundle_pool/plugins/org.eclipse.pde.ds.lib_1.1.0.v20170303-1624/annotations.jar!/' and using 'archive:file:/C:/ESH/eclipse/configuration/org.eclipse.osgi/453/0/.cp/lib/annotations.jar!/' instead.
2548 [main] WARN lipse.emf.mwe.utils.StandaloneSetup - Skipping conflicting project annotations at 'archive:file:/C:/ESH/eclipse/configuration/org.eclipse.osgi/453/0/.cp/lib/annotations.jar!/' and using 'archive:file:/C:/ESH/ws/.metadata/.plugins/org.eclipse.pde.core/.bundle_pool/plugins/org.eclipse.pde.ds.lib_1.1.0.v20170303-1624/annotations.jar!/' instead.
2843 [main] WARN lipse.emf.mwe.utils.StandaloneSetup - No project file found for C:\ESH\git\smarthome\bundles\model\org.eclipse.smarthome.model.item\src. The folder was neither an Eclipse 'bin' folder, nor a Maven 'target/classes' folder.
2855 [main] WARN lipse.emf.mwe.utils.StandaloneSetup - No project file found for C:\ESH\git\smarthome\bundles\model\org.eclipse.smarthome.model.persistence\src. The folder was neither an Eclipse 'bin' folder, nor a Maven 'target/classes' folder.
2863 [main] WARN lipse.emf.mwe.utils.StandaloneSetup - No project file found for C:\ESH\git\smarthome\bundles\model\org.eclipse.smarthome.model.rule\src. The folder was neither an Eclipse 'bin' folder, nor a Maven 'target/classes' folder.
2881 [main] WARN lipse.emf.mwe.utils.StandaloneSetup - No project file found for C:\ESH\git\smarthome\bundles\model\org.eclipse.smarthome.model.script\src. The folder was neither an Eclipse 'bin' folder, nor a Maven 'target/classes' folder.
2891 [main] WARN lipse.emf.mwe.utils.StandaloneSetup - No project file found for C:\ESH\git\smarthome\bundles\model\org.eclipse.smarthome.model.sitemap\src. The folder was neither an Eclipse 'bin' folder, nor a Maven 'target/classes' folder.
2901 [main] WARN lipse.emf.mwe.utils.StandaloneSetup - No project file found for C:\ESH\git\smarthome\bundles\model\org.eclipse.smarthome.model.thing\src. The folder was neither an Eclipse 'bin' folder, nor a Maven 'target/classes' folder.
2904 [main] INFO lipse.emf.mwe.utils.StandaloneSetup - Registering project org.eclipse.smarthome.model.script at 'file:/C:/ESH/git/smarthome/bundles/model/org.eclipse.smarthome.model.script/'
2904 [main] INFO lipse.emf.mwe.utils.StandaloneSetup - Registering project org.eclipse.smarthome.model.script.ide at 'file:/C:/ESH/git/smarthome/bundles/model/org.eclipse.smarthome.model.script.ide/'
2905 [main] INFO lipse.emf.mwe.utils.StandaloneSetup - Registering project org.eclipse.smarthome.model.script.ui at 'file:/C:/ESH/git/smarthome/bundles/model/org.eclipse.smarthome.model.script.ui/'
2907 [main] INFO lipse.emf.mwe.utils.StandaloneSetup - Using resourceSet registry. The registered Packages will not be registered in the global EPackage.Registry.INSTANCE!
3107 [main] INFO text.xtext.generator.XtextGenerator - Initializing Xtext generator
3107 [main] INFO lipse.emf.mwe.utils.StandaloneSetup - Adding generated EPackage 'org.eclipse.xtext.common.types.TypesPackage'
3111 [main] WARN lipse.emf.mwe.utils.StandaloneSetup - Skipping conflicting project annotations at 'archive:file:/C:/ESH/ws/.metadata/.plugins/org.eclipse.pde.core/.bundle_pool/plugins/org.eclipse.pde.ds.lib_1.1.0.v20170303-1624/annotations.jar!/' and using 'archive:file:/C:/ESH/eclipse/configuration/org.eclipse.osgi/453/0/.cp/lib/annotations.jar!/' instead.
3159 [main] WARN lipse.emf.mwe.utils.StandaloneSetup - Skipping conflicting project annotations at 'archive:file:/C:/ESH/eclipse/configuration/org.eclipse.osgi/453/0/.cp/lib/annotations.jar!/' and using 'archive:file:/C:/ESH/ws/.metadata/.plugins/org.eclipse.pde.core/.bundle_pool/plugins/org.eclipse.pde.ds.lib_1.1.0.v20170303-1624/annotations.jar!/' instead.
3395 [main] WARN lipse.emf.mwe.utils.StandaloneSetup - No project file found for C:\ESH\git\smarthome\bundles\model\org.eclipse.smarthome.model.item\src. The folder was neither an Eclipse 'bin' folder, nor a Maven 'target/classes' folder.
3405 [main] WARN lipse.emf.mwe.utils.StandaloneSetup - No project file found for C:\ESH\git\smarthome\bundles\model\org.eclipse.smarthome.model.persistence\src. The folder was neither an Eclipse 'bin' folder, nor a Maven 'target/classes' folder.
3412 [main] WARN lipse.emf.mwe.utils.StandaloneSetup - No project file found for C:\ESH\git\smarthome\bundles\model\org.eclipse.smarthome.model.rule\src. The folder was neither an Eclipse 'bin' folder, nor a Maven 'target/classes' folder.
3430 [main] WARN lipse.emf.mwe.utils.StandaloneSetup - No project file found for C:\ESH\git\smarthome\bundles\model\org.eclipse.smarthome.model.script\src. The folder was neither an Eclipse 'bin' folder, nor a Maven 'target/classes' folder.
3439 [main] WARN lipse.emf.mwe.utils.StandaloneSetup - No project file found for C:\ESH\git\smarthome\bundles\model\org.eclipse.smarthome.model.sitemap\src. The folder was neither an Eclipse 'bin' folder, nor a Maven 'target/classes' folder.
3448 [main] WARN lipse.emf.mwe.utils.StandaloneSetup - No project file found for C:\ESH\git\smarthome\bundles\model\org.eclipse.smarthome.model.thing\src. The folder was neither an Eclipse 'bin' folder, nor a Maven 'target/classes' folder.
3449 [main] INFO lipse.emf.mwe.utils.StandaloneSetup - Registering project org.eclipse.smarthome.model.rule at 'file:/C:/ESH/git/smarthome/bundles/model/org.eclipse.smarthome.model.rule/'
3449 [main] INFO lipse.emf.mwe.utils.StandaloneSetup - Registering project org.eclipse.smarthome.model.rule.ide at 'file:/C:/ESH/git/smarthome/bundles/model/org.eclipse.smarthome.model.rule.ide/'
3450 [main] INFO lipse.emf.mwe.utils.StandaloneSetup - Registering project org.eclipse.smarthome.model.rule.ui at 'file:/C:/ESH/git/smarthome/bundles/model/org.eclipse.smarthome.model.rule.ui/'
3451 [main] INFO lipse.emf.mwe.utils.StandaloneSetup - Using resourceSet registry. The registered Packages will not be registered in the global EPackage.Registry.INSTANCE!
3476 [main] ERROR mf.mwe2.launch.runtime.Mwe2Launcher - Problems running workflow all: java.io.FileNotFoundException: C:\ESH\git\smarthome\bundles\model\org.eclipse.smarthome.model.script\model\generated\Script.ecore (The system cannot find the path specified)
java.lang.RuntimeException: Problems running workflow all: java.io.FileNotFoundException: C:\ESH\git\smarthome\bundles\model\org.eclipse.smarthome.model.script\model\generated\Script.ecore (The system cannot find the path specified)
at org.eclipse.emf.mwe2.launch.runtime.Mwe2Runner.run(Mwe2Runner.java:104)
at org.eclipse.emf.mwe2.launch.runtime.Mwe2Runner.run(Mwe2Runner.java:62)
at org.eclipse.emf.mwe2.launch.runtime.Mwe2Runner.run(Mwe2Runner.java:52)
at org.eclipse.emf.mwe2.launch.runtime.Mwe2Launcher.run(Mwe2Launcher.java:78)
at org.eclipse.emf.mwe2.launch.runtime.Mwe2Launcher.main(Mwe2Launcher.java:36)
Caused by: org.eclipse.emf.ecore.resource.impl.ResourceSetImpl$1DiagnosticWrappedException: java.io.FileNotFoundException: C:\ESH\git\smarthome\bundles\model\org.eclipse.smarthome.model.script\model\generated\Script.ecore (The system cannot find the path specified)
at org.eclipse.emf.ecore.resource.impl.ResourceSetImpl.handleDemandLoadException(ResourceSetImpl.java:319)
at org.eclipse.emf.ecore.resource.impl.ResourceSetImpl.demandLoadHelper(ResourceSetImpl.java:278)
at org.eclipse.xtext.resource.XtextResourceSet.getResource(XtextResourceSet.java:265)
at org.eclipse.xtext.xtext.generator.XtextGeneratorResourceSetInitializer.loadResource(XtextGeneratorResourceSetInitializer.java:51)
at org.eclipse.xtext.xtext.generator.XtextGeneratorResourceSetInitializer.lambda$initialize$0(XtextGeneratorResourceSetInitializer.java:41)
at java.util.ArrayList.forEach(ArrayList.java:1249)
at org.eclipse.xtext.xtext.generator.XtextGeneratorResourceSetInitializer.initialize(XtextGeneratorResourceSetInitializer.java:43)
at org.eclipse.xtext.xtext.generator.XtextGeneratorLanguage.initialize(XtextGeneratorLanguage.java:219)
at org.eclipse.xtext.xtext.generator.StandardLanguage.initialize(StandardLanguage.java:175)
at org.eclipse.xtext.xtext.generator.XtextGenerator.initialize(XtextGenerator.java:185)
at org.eclipse.xtext.xtext.generator.XtextGenerator.checkConfigurationInternal(XtextGenerator.java:139)
at org.eclipse.emf.mwe.core.lib.AbstractWorkflowComponent2.checkConfiguration(AbstractWorkflowComponent2.java:21)
at org.eclipse.emf.mwe.core.lib.Mwe2Bridge.preInvoke(Mwe2Bridge.java:65)
at org.eclipse.emf.mwe.core.lib.AbstractWorkflowComponent.preInvoke(AbstractWorkflowComponent.java:197)
at org.eclipse.emf.mwe2.runtime.workflow.AbstractCompositeWorkflowComponent.preInvoke(AbstractCompositeWorkflowComponent.java:29)
at org.eclipse.emf.mwe2.runtime.workflow.Workflow.run(Workflow.java:18)
at org.eclipse.emf.mwe2.launch.runtime.Mwe2Runner.run(Mwe2Runner.java:102)
... 4 more
Caused by: java.io.FileNotFoundException: C:\ESH\git\smarthome\bundles\model\org.eclipse.smarthome.model.script\model\generated\Script.ecore (The system cannot find the path specified)
at java.io.FileInputStream.open0(Native Method)
at java.io.FileInputStream.open(FileInputStream.java:195)
at java.io.FileInputStream.<init>(FileInputStream.java:138)
at org.eclipse.emf.ecore.resource.impl.FileURIHandlerImpl.createInputStream(FileURIHandlerImpl.java:99)
at org.eclipse.emf.ecore.resource.impl.ExtensibleURIConverterImpl.createInputStream(ExtensibleURIConverterImpl.java:360)
at org.eclipse.xtext.resource.XtextResourceSet$1.createInputStream(XtextResourceSet.java:298)
at org.eclipse.emf.ecore.resource.impl.PlatformResourceURIHandlerImpl.createInputStream(PlatformResourceURIHandlerImpl.java:532)
at org.eclipse.emf.ecore.resource.impl.ResourceImpl.load(ResourceImpl.java:1269)
at org.eclipse.emf.ecore.resource.impl.ResourceSetImpl.demandLoad(ResourceSetImpl.java:259)
at org.eclipse.emf.ecore.resource.impl.ResourceSetImpl.demandLoadHelper(ResourceSetImpl.java:274)
... 20 more
Seems like the folder
is missing. I tried to navigate to the path and it only exists up until
there is no folder called model\generated\Script.ecore within that path.
Any suggestions?
Thank you again for your time.
FUDForum. Page generated in 0.04060 seconds
