Re: How to create a Dashboard in a TablePage [message #1766301 is a reply to message #1766298] |
Tue, 20 June 2017 07:18 |
Urs Beeli wrote on Tue, 20 June 2017 05:58I believe this is from the closed-source part of Scout, but someone from BSI will probably be better informed :-)
With closed source you mean, that BSI has got more sophisticated UI controls in place, and such a dashboard is not doable with the publicly available UI controls/features?
Peter
Re: How to create a Dashboard in a TablePage [message #1766313 is a reply to message #1766304] |
Tue, 20 June 2017 08:03 |
Matthias Zimmermann wrote on Tue, 20 June 2017 07:24Quote:With closed source you mean, that BSI has got more sophisticated UI controls in place, and such a dashboard is not doable with the publicly available UI controls/features?
this is partially true:
- yes in the sense of: the screenshot above is from our commercial product
- no in the sense of: these are just custom controls and scout is designed in a way that anybody can built her/his own custom controls with their javascript library of choice
thanks for the quick answer :)
So more or less, I can use every control Scout provides.... its just a matter of the layout manager how to display them?
Peter
Re: How to create a Dashboard in a TablePage [message #1766320 is a reply to message #1766314] |
Tue, 20 June 2017 08:29 |
Matthias Zimmermann wrote on Tue, 20 June 2017 08:08not quite: the squares in the dashboard can be moved around using the mouse, a feature that is specific to the dashboard control.
Well in a first version, it would be more than enough, when the dashboard items are fixed....
Therefore i could use any of the default controls? Am I right?
Peter
Re: How to create a Dashboard in a TablePage [message #1766334 is a reply to message #1766332] |
Tue, 20 June 2017 11:10 |
[quote title=Urs Beeli wrote on Tue, 20 June 2017 10:48]Quote:I think in the example you showed, there is probably a CustomField for each square as well as for the overall dashboard containing the squares.
that might be the case for sure. My problem is, that I haven't got any JavaScript knowledge... So therefore its quite cumbersome for me :)
Peter
Re: How to create a Dashboard in a TablePage [message #1766338 is a reply to message #1766336] |
Tue, 20 June 2017 11:29 |
Matthias Zimmermann wrote on Tue, 20 June 2017 11:12well, there are several options: you know somebody that knows javascript, you learn javascript, or you pay somebody to solve your javascript needs ;-)
I'll prefer the first 2 options :)) Learning takes time... But I'm not in a hurry :)
FUDForum. Page generated in 0.05768 seconds
