Re: Eclipse Scout Oxygen Releases [message #1753305 is a reply to message #1753304] |
Fri, 03 February 2017 15:58 |
Jeremie Bresson Messages: 1252 Registered: October 2011 |
Oxygen M5 released on 03.02.2017
Remember that this is only a preview release. APIs might change in the next milestone releases. Please consider our Neon release, if you are looking for our stable branch.
Eclipse IDE distribution (also called EPP): Eclipse for Scout Developers
Eclipse Runtime on maven central: Version 6.1.0.M5
Usage example in the parent POM of your scout application:
<dependency>
<groupId>org.eclipse.scout.rt</groupId>
<artifactId>org.eclipse.scout.rt</artifactId>
<version>6.1.0.M5</version>
<type>pom</type>
<scope>import</scope>
</dependency> See this artifact on mvnrepository.com: org.eclipse.scout.rt
Update site to install the Scout SDK in your Eclipse IDE (already installed in the Scout EPP):
http://download.eclipse.org/scout/releases/6.1/6.1.0/M5/
The demo applications using this version can be found on the features/version/6.1.0.M5 branch of our docs repository on GitHub.
[Updated on: Mon, 10 April 2017 15:47] Report message to a moderator
Re: Eclipse Scout Oxygen Releases [message #1759326 is a reply to message #1753305] |
Mon, 10 April 2017 14:53 |
Oxygen M6 released on 17.03.2017
Release Notes (6.1)
Eclipse Runtime on maven central: Version 6.1.0.M6
<dependency>
<version>6.1.0.M6</version>
<type>pom</type>
http://download.eclipse.org/scout/releases/6.1/6.1.0/M6/
The demo applications using this version can be found on the features/version/6.1.0.M6 branch of our docs repository on GitHub.
Next version on the Oxygen release train will be built from our 7.0.x Branch.
[Updated on: Tue, 30 May 2017 08:29] Report message to a moderator
Re: Eclipse Scout Oxygen Releases [message #1764464 is a reply to message #1759326] |
Tue, 30 May 2017 08:33 |
Oxygen M7 released on 19.05.2017
Have a look at the Release Notes (7.0)
Eclipse Runtime on maven central: Version 7.0.0.001_M7
<dependency>
<version>7.0.0.001_M7</version>
<type>pom</type>
http://download.eclipse.org/scout/releases/7.0/7.0.0/001_M7/
The demo applications using this version can be found on the features/version/7.0.0.001_M7 branch of our docs repository on GitHub.
[Updated on: Tue, 30 May 2017 10:31] Report message to a moderator
Re: Eclipse Scout Oxygen Releases [message #1764469 is a reply to message #1764464] |
Tue, 30 May 2017 10:29 |
Oxygen RC1 released on 26.05.2017
Eclipse Runtime on maven central: Version 7.0.0.005_RC1
<dependency>
<version>7.0.0.005_RC1</version>
<type>pom</type>
http://download.eclipse.org/scout/releases/7.0/7.0.0/005_RC1/
The demo applications using this version can be found on the features/version/7.0.0.005_RC1 branch of our docs repository on GitHub.
[Updated on: Thu, 08 June 2017 19:32] Report message to a moderator
FUDForum. Page generated in 0.03775 seconds
