| Set SearchForm-Field from the TablePage-Value [message #1764947] |
Sun, 04 June 2017 11:54  |
I'm calling a TablePage. When calling the TablePage, a local variable is set.
Depending on the content of this variable, a search-field is to be assigned (the SearchForm belonging to the TablePage).
Concrete one could ...
protected void execInitField() {
if (<<[Here the Value from TablePage.this.localeVariable]>> = 1) {
setValue("yeaha");
}else{
setValue("?whats wrong?");
super.execInitField();
... but how do you get the value from the TablePage?
I think a transfer from the TablePage to the SearchForm can somehow not take place since the SearchForm is just using ...
protected Class<? extends ISearchForm> getConfiguredSearchForm() {
return xxxSearchForm.class;
... is called.
FUDForum. Page generated in 0.04241 seconds
