Home » Modeling » TMF (Xtext) » MyDslDocumentProvider failed to save
MyDslDocumentProvider failed to save [message #1764684] |
Thu, 01 June 2017 07:37  |
I have a EMF metamodel (named DSL) (file extension mydsl)
I create an Xtext project from this metamodel. (file extension my)
When I create a myDsl model, the model can be opened using the textual editor or the EMF editor.
However it is saved a TEXT and not XMI.
For me, It must be an xmi file and saved as XMI
To do that, I add this code in my MyDslUiModule
class MyDslUiModule extends AbstractMyDslUiModule {
def Class<? extends XtextDocumentProvider> bindXtextDocumentProvider() {
override Class<? extends IResourceForEditorInputFactory> bindIResourceForEditorInputFactory() {
return MyDslResourceForEditorInputFactory
and I add the following classes
public class MyDslDocumentProvider extends XtextDocumentProvider {
static {
MyDslStandaloneSetup.doSetup();
protected void setDocumentContent(IDocument document, InputStream contentStream, String encoding)
throws CoreException {
ResourceSet resourceSet = createResourceSet();
Resource xmiResource = resourceSet.createResource(URI.createURI("temp.xmi"));
Resource xtextResource = resourceSet.createResource(URI.createURI("temp.mydsl"));
ByteArrayOutputStream os = new ByteArrayOutputStream();
try {
xmiResource.load(contentStream, Collections.emptyMap());
xtextResource.getContents().addAll(xmiResource.getContents());
xtextResource.save(os, Collections.EMPTY_MAP);
} catch (IOException e) {
throw new CoreException(
new Status(IStatus.ERROR, "org.xtext.example.mydsl.ui", "Failed to save", e));
} finally {
try {
os.close();
contentStream.close();
new Status(IStatus.ERROR, "org.xtext.example.mydsl.ui", "Failed to load", e));
document.set(new String(os.toByteArray()));
protected void doSaveDocument(IProgressMonitor monitor, Object element, IDocument document, boolean overwrite)
try {
XtextResource xtextResource = (XtextResource) resourceSet.createResource(URI.createURI("temp.mydsl"));
InputStream is = new ByteArrayInputStream(document.get().getBytes());
xtextResource.load(is, Collections.EMPTY_MAP);
is.close();
URI uri = URI.createPlatformResourceURI(
((org.eclipse.ui.part.FileEditorInput) element).getFile().getFullPath().toString(), true);
resourceSet.getResourceFactoryRegistry().getExtensionToFactoryMap().put("*", new XMIResourceFactoryImpl());
Resource xmiResource = resourceSet.getResource(uri, true);
((XMLResource) xmiResource).getDefaultSaveOptions().put(XMLResource.OPTION_URI_HANDLER,
new URIHandlerImpl.PlatformSchemeAware());
xmiResource.getContents().clear();
xmiResource.getContents().addAll(xtextResource.getContents());
EcoreUtil.resolveAll(xmiResource);
xmiResource.save(Collections.EMPTY_MAP);
private ResourceSet createResourceSet() {
ResourceSet resourceSet = new ResourceSetImpl();
resourceSet.getPackageRegistry().put(MyDslPackage.eNS_URI, MyDslPackage.eINSTANCE);
return resourceSet;
and
public class MyDslResourceForEditorInputFactory extends JavaClassPathResourceForIEditorInputFactory {
@Inject
private IStorage2UriMapper storageToUriMapper;
@Inject
private Provider<XtextResource> provider;
protected Resource createResourceFor(IStorage storage) {
ResourceSet resourceSet = getResourceSet(storage);
URI uri = URI.createPlatformResourceURI(storage.getFullPath().toString(), true);
configureResourceSet(resourceSet, uri);
XtextResource resource = (XtextResource) resourceSet.getResource(uri, false);
// Modified to interpret a null resource and
// so create an XtextResource for an ecore file
if (resource == null) {
resource = (XtextResource) new XtextResourceFactory(provider).createResource(uri);
resourceSet.getResources().add(resource);
resource.setValidationDisabled(false);
return resource;
protected Resource createResourceFor(IJarEntryResource storage) {
URI uri = storageToUriMapper.getUri(storage);
resource.setValidationDisabled(true);
return resource;
From now on, hen I try to create mydsl model, I obtain this error and the model is empty
!ENTRY org.eclipse.ui 4 0 2017-06-01 13:31:39.326
!MESSAGE FileDocumentProvider.createElementInfo
!STACK 1
org.eclipse.core.runtime.CoreException: Failed to save
at org.eclipse.cmf.occi.core.xtext.ui.OCCIDocumentProvider.setDocumentContent(OCCIDocumentProvider.java:48)
at org.eclipse.ui.editors.text.FileDocumentProvider.setDocumentContent(FileDocumentProvider.java:425)
at org.eclipse.xtext.ui.editor.model.XtextDocumentProvider.setDocumentContent(XtextDocumentProvider.java:183)
at org.eclipse.ui.editors.text.StorageDocumentProvider.createDocument(StorageDocumentProvider.java:227)
at org.eclipse.xtext.ui.editor.model.XtextDocumentProvider.createDocument(XtextDocumentProvider.java:141)
at org.eclipse.ui.editors.text.FileDocumentProvider.createElementInfo(FileDocumentProvider.java:721)
at org.eclipse.xtext.ui.editor.model.XtextDocumentProvider.createElementInfo(XtextDocumentProvider.java:262)
at org.eclipse.ui.texteditor.AbstractDocumentProvider.connect(AbstractDocumentProvider.java:392)
at org.eclipse.ui.texteditor.AbstractTextEditor.doSetInput(AbstractTextEditor.java:4178)
at org.eclipse.ui.texteditor.StatusTextEditor.doSetInput(StatusTextEditor.java:229)
at org.eclipse.ui.texteditor.AbstractDecoratedTextEditor.doSetInput(AbstractDecoratedTextEditor.java:1466)
at org.eclipse.ui.editors.text.TextEditor.doSetInput(TextEditor.java:150)
at org.eclipse.xtext.ui.editor.XtextEditor.doSetInput(XtextEditor.java:247)
at org.eclipse.ui.texteditor.AbstractTextEditor$5.run(AbstractTextEditor.java:3154)
at org.eclipse.jface.operation.ModalContext.runInCurrentThread(ModalContext.java:437)
at org.eclipse.jface.operation.ModalContext.run(ModalContext.java:353)
at org.eclipse.ui.internal.WorkbenchWindow$14.run(WorkbenchWindow.java:2184)
at org.eclipse.ui.internal.WorkbenchWindow.run(WorkbenchWindow.java:2180)
at org.eclipse.ui.texteditor.AbstractTextEditor.internalInit(AbstractTextEditor.java:3172)
at org.eclipse.ui.texteditor.AbstractTextEditor.init(AbstractTextEditor.java:3197)
at org.eclipse.xtext.ui.editor.XtextEditor.init(XtextEditor.java:288)
at org.eclipse.ui.internal.EditorReference.initialize(EditorReference.java:362)
at org.eclipse.ui.internal.e4.compatibility.CompatibilityPart.create(CompatibilityPart.java:318)
at org.eclipse.e4.core.internal.di.MethodRequestor.execute(MethodRequestor.java:55)
at org.eclipse.e4.core.internal.di.InjectorImpl.processAnnotated(InjectorImpl.java:966)
at org.eclipse.e4.core.internal.di.InjectorImpl.processAnnotated(InjectorImpl.java:931)
at org.eclipse.e4.core.internal.di.InjectorImpl.inject(InjectorImpl.java:151)
at org.eclipse.e4.core.internal.di.InjectorImpl.internalMake(InjectorImpl.java:375)
at org.eclipse.e4.core.internal.di.InjectorImpl.make(InjectorImpl.java:294)
at org.eclipse.e4.core.contexts.ContextInjectionFactory.make(ContextInjectionFactory.java:162)
at org.eclipse.e4.ui.internal.workbench.ReflectionContributionFactory.createFromBundle(ReflectionContributionFactory.java:105)
at org.eclipse.e4.ui.internal.workbench.ReflectionContributionFactory.doCreate(ReflectionContributionFactory.java:74)
at org.eclipse.e4.ui.internal.workbench.ReflectionContributionFactory.create(ReflectionContributionFactory.java:56)
at org.eclipse.e4.ui.workbench.renderers.swt.ContributedPartRenderer.createWidget(ContributedPartRenderer.java:129)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.createWidget(PartRenderingEngine.java:975)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.safeCreateGui(PartRenderingEngine.java:651)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.safeCreateGui(PartRenderingEngine.java:757)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.access$0(PartRenderingEngine.java:728)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine$2.run(PartRenderingEngine.java:722)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.createGui(PartRenderingEngine.java:706)
at org.eclipse.e4.ui.workbench.renderers.swt.StackRenderer.showTab(StackRenderer.java:1324)
at org.eclipse.e4.ui.workbench.renderers.swt.LazyStackRenderer$1.handleEvent(LazyStackRenderer.java:72)
at org.eclipse.e4.ui.services.internal.events.UIEventHandler$1.run(UIEventHandler.java:40)
at org.eclipse.swt.widgets.Synchronizer.syncExec(Synchronizer.java:233)
at org.eclipse.ui.internal.UISynchronizer.syncExec(UISynchronizer.java:145)
at org.eclipse.swt.widgets.Display.syncExec(Display.java:4814)
at org.eclipse.e4.ui.internal.workbench.swt.E4Application$1.syncExec(E4Application.java:211)
at org.eclipse.e4.ui.services.internal.events.UIEventHandler.handleEvent(UIEventHandler.java:36)
at org.eclipse.equinox.internal.event.EventHandlerWrapper.handleEvent(EventHandlerWrapper.java:201)
at org.eclipse.equinox.internal.event.EventHandlerTracker.dispatchEvent(EventHandlerTracker.java:197)
at org.eclipse.equinox.internal.event.EventHandlerTracker.dispatchEvent(EventHandlerTracker.java:1)
at org.eclipse.osgi.framework.eventmgr.EventManager.dispatchEvent(EventManager.java:230)
at org.eclipse.osgi.framework.eventmgr.ListenerQueue.dispatchEventSynchronous(ListenerQueue.java:148)
at org.eclipse.equinox.internal.event.EventAdminImpl.dispatchEvent(EventAdminImpl.java:135)
at org.eclipse.equinox.internal.event.EventAdminImpl.sendEvent(EventAdminImpl.java:78)
at org.eclipse.equinox.internal.event.EventComponent.sendEvent(EventComponent.java:39)
at org.eclipse.e4.ui.services.internal.events.EventBroker.send(EventBroker.java:94)
at org.eclipse.e4.ui.internal.workbench.UIEventPublisher.notifyChanged(UIEventPublisher.java:60)
at org.eclipse.emf.common.notify.impl.BasicNotifierImpl.eNotify(BasicNotifierImpl.java:374)
at org.eclipse.e4.ui.model.application.ui.impl.ElementContainerImpl.setSelectedElement(ElementContainerImpl.java:173)
at org.eclipse.e4.ui.internal.workbench.ModelServiceImpl.showElementInWindow(ModelServiceImpl.java:617)
at org.eclipse.e4.ui.internal.workbench.ModelServiceImpl.bringToTop(ModelServiceImpl.java:581)
at org.eclipse.e4.ui.internal.workbench.PartServiceImpl.delegateBringToTop(PartServiceImpl.java:770)
at org.eclipse.e4.ui.internal.workbench.PartServiceImpl.bringToTop(PartServiceImpl.java:401)
at org.eclipse.e4.ui.internal.workbench.PartServiceImpl.showPart(PartServiceImpl.java:1214)
at org.eclipse.ui.internal.WorkbenchPage.busyOpenEditor(WorkbenchPage.java:3261)
at org.eclipse.ui.internal.WorkbenchPage.access$25(WorkbenchPage.java:3176)
at org.eclipse.ui.internal.WorkbenchPage$10.run(WorkbenchPage.java:3158)
at org.eclipse.ui.internal.WorkbenchPage.openEditor(WorkbenchPage.java:3153)
at org.eclipse.ui.internal.WorkbenchPage.openEditor(WorkbenchPage.java:3117)
at org.eclipse.ui.internal.WorkbenchPage.openEditor(WorkbenchPage.java:3107)
at org.eclipse.ui.ide.IDE.openEditor(IDE.java:563)
at org.eclipse.ui.ide.IDE.openEditor(IDE.java:518)
at org.eclipse.ui.wizards.newresource.BasicNewFileResourceWizard.performFinish(BasicNewFileResourceWizard.java:103)
at org.eclipse.jface.wizard.WizardDialog.finishPressed(WizardDialog.java:790)
at org.eclipse.jface.wizard.WizardDialog.buttonPressed(WizardDialog.java:423)
at org.eclipse.jface.dialogs.Dialog$2.widgetSelected(Dialog.java:618)
at org.eclipse.swt.widgets.TypedListener.handleEvent(TypedListener.java:249)
at org.eclipse.swt.widgets.Display.sendEvent(Display.java:4256)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1501)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1524)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1509)
at org.eclipse.swt.widgets.Widget.notifyListeners(Widget.java:1313)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.java:4080)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3706)
at org.eclipse.jface.window.Window.runEventLoop(Window.java:818)
at org.eclipse.jface.window.Window.open(Window.java:794)
at org.eclipse.ui.internal.navigator.wizards.WizardShortcutAction.run(WizardShortcutAction.java:99)
at org.eclipse.jface.action.Action.runWithEvent(Action.java:473)
at org.eclipse.jface.action.ActionContributionItem.handleWidgetSelection(ActionContributionItem.java:565)
at org.eclipse.jface.action.ActionContributionItem.lambda$4(ActionContributionItem.java:397)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine$4.run(PartRenderingEngine.java:1121)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.run(PartRenderingEngine.java:1022)
at org.eclipse.e4.ui.internal.workbench.E4Workbench.createAndRunUI(E4Workbench.java:150)
at org.eclipse.ui.internal.Workbench$5.run(Workbench.java:693)
at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:610)
at org.eclipse.ui.internal.ide.application.IDEApplication.start(IDEApplication.java:138)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:673)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:610)
at org.eclipse.equinox.launcher.Main.run(Main.java:1519)
at org.eclipse.equinox.launcher.Main.main(Main.java:1492)
Caused by: org.eclipse.emf.ecore.resource.Resource$IOWrappedException: Fin prématurée du fichier.
at org.eclipse.emf.ecore.xmi.impl.XMLLoadImpl.load(XMLLoadImpl.java:195)
at org.eclipse.emf.ecore.xmi.impl.XMLResourceImpl.doLoad(XMLResourceImpl.java:261)
at org.eclipse.emf.ecore.resource.impl.ResourceImpl.load(ResourceImpl.java:1518)
at org.eclipse.cmf.occi.core.xtext.ui.OCCIDocumentProvider.setDocumentContent(OCCIDocumentProvider.java:44)
... 128 more
Caused by: org.xml.sax.SAXParseExceptionpublicId: temp.xmi; systemId: file:///Applications/Eclipse%20copie.app/Contents/MacOS/temp.xmi; lineNumber: 1; columnNumber: 1; Fin prématurée du fichier.
at com.sun.org.apache.xerces.internal.util.ErrorHandlerWrapper.createSAXParseException(ErrorHandlerWrapper.java:203)
at com.sun.org.apache.xerces.internal.util.ErrorHandlerWrapper.fatalError(ErrorHandlerWrapper.java:177)
at com.sun.org.apache.xerces.internal.impl.XMLErrorReporter.reportError(XMLErrorReporter.java:400)
at com.sun.org.apache.xerces.internal.impl.XMLErrorReporter.reportError(XMLErrorReporter.java:327)
at com.sun.org.apache.xerces.internal.impl.XMLScanner.reportFatalError(XMLScanner.java:1472)
at com.sun.org.apache.xerces.internal.impl.XMLDocumentScannerImpl$PrologDriver.next(XMLDocumentScannerImpl.java:1014)
at com.sun.org.apache.xerces.internal.impl.XMLDocumentScannerImpl.next(XMLDocumentScannerImpl.java:602)
at com.sun.org.apache.xerces.internal.impl.XMLDocumentFragmentScannerImpl.scanDocument(XMLDocumentFragmentScannerImpl.java:505)
at com.sun.org.apache.xerces.internal.parsers.XML11Configuration.parse(XML11Configuration.java:841)
at com.sun.org.apache.xerces.internal.parsers.XML11Configuration.parse(XML11Configuration.java:770)
at com.sun.org.apache.xerces.internal.parsers.XMLParser.parse(XMLParser.java:141)
at com.sun.org.apache.xerces.internal.parsers.AbstractSAXParser.parse(AbstractSAXParser.java:1213)
at com.sun.org.apache.xerces.internal.jaxp.SAXParserImpl$JAXPSAXParser.parse(SAXParserImpl.java:643)
at com.sun.org.apache.xerces.internal.jaxp.SAXParserImpl.parse(SAXParserImpl.java:327)
at org.eclipse.emf.ecore.xmi.impl.XMLLoadImpl.load(XMLLoadImpl.java:175)
... 131 more
!SUBENTRY 1 org.occiware.clouddesigner.occi.xtext.ui 4 0 2017-06-01 13:31:39.328
!MESSAGE Failed to save
!STACK 0
... 131 more
1 [Worker-12] ERROR org.eclipse.xtext.builder.impl.XtextBuilder - Passed org.eclipse.xtext.builder.clustering.CurrentDescriptions is not based on a resource set
java.lang.IllegalStateException: Passed org.eclipse.xtext.builder.clustering.CurrentDescriptions is not based on a resource set
at org.eclipse.xtext.resource.containers.ResourceSetBasedAllContainersStateProvider.getResourceSet(ResourceSetBasedAllContainersStateProvider.java:44)
at org.eclipse.xtext.resource.containers.ResourceSetBasedAllContainersStateProvider.get(ResourceSetBasedAllContainersStateProvider.java:26)
at org.eclipse.xtext.resource.containers.StateBasedContainerManager.getState(StateBasedContainerManager.java:81)
at org.eclipse.xtext.resource.containers.StateBasedContainerManager.internalGetContainerHandle(StateBasedContainerManager.java:106)
at org.eclipse.xtext.resource.containers.StateBasedContainerManager.getVisibleContainers(StateBasedContainerManager.java:59)
at org.eclipse.xtext.resource.impl.DefaultResourceDescriptionManager.isAffected(DefaultResourceDescriptionManager.java:138)
at org.eclipse.xtext.builder.clustering.ClusteringBuilderState.queueAffectedResources(ClusteringBuilderState.java:525)
at org.eclipse.xtext.builder.clustering.ClusteringBuilderState.doUpdate(ClusteringBuilderState.java:300)
at org.eclipse.xtext.builder.builderState.AbstractBuilderState.update(AbstractBuilderState.java:116)
at org.eclipse.xtext.builder.impl.XtextBuilder.doBuild(XtextBuilder.java:287)
at org.eclipse.xtext.builder.impl.XtextBuilder.incrementalBuild(XtextBuilder.java:267)
at org.eclipse.xtext.builder.impl.XtextBuilder.build(XtextBuilder.java:161)
at org.eclipse.core.internal.events.BuildManager$2.run(BuildManager.java:735)
at org.eclipse.core.internal.events.BuildManager.basicBuild(BuildManager.java:206)
at org.eclipse.core.internal.events.BuildManager.basicBuild(BuildManager.java:246)
at org.eclipse.core.internal.events.BuildManager$1.run(BuildManager.java:301)
at org.eclipse.core.internal.events.BuildManager.basicBuild(BuildManager.java:304)
at org.eclipse.core.internal.events.BuildManager.basicBuildLoop(BuildManager.java:360)
at org.eclipse.core.internal.events.BuildManager.build(BuildManager.java:383)
at org.eclipse.core.internal.events.AutoBuildJob.doBuild(AutoBuildJob.java:144)
at org.eclipse.core.internal.events.AutoBuildJob.run(AutoBuildJob.java:235)
!ENTRY org.apache.log4j 4 0 2017-06-01 13:31:39.450
!MESSAGE org.eclipse.xtext.builder.impl.XtextBuilder - Passed org.eclipse.xtext.builder.clustering.CurrentDescriptions is not based on a resource set
!STACK 0
Any idea/suggestion/example please?
Re: MyDslDocumentProvider failed to save [message #1764784 is a reply to message #1764725] |
Fri, 02 June 2017 05:14   |
Thanks Chrisitan. It works perfectly.
So, the main issue is not here.
I just wanted to create a framework that corresponds to my real case.
The problem concerns the dsl itself.
Let me explain:
I have this metamodel
package myDsl : myDsl = 'http://www.xtext.org/example/mydsl/MyDsl'
class Model
property greetings : Greeting[*|1] { ordered composes };
class Greeting
attribute name : String[?];
attribute condition : Boolean[1] = 'true';
Just a small precision, in my genmodel, the Resource Type == XMI ("none" is the default value in the genmodel)
Then, I generate a Xtext grammar from this metamodel
// automatically generated by Xtext
grammar org.xtext.example.mydsl.MyDsl with org.eclipse.xtext.common.Terminals
import "http://www.xtext.org/example/mydsl/MyDsl"
Model returns Model:
{Model}
'(' greetings+=Greeting* ')'
Greeting returns Greeting:
'Hello'
name=ID
(condition?='condition')?
The main problem concerns the condition attribute.
Two sub-problems exist:
1) when condition is false
When opening the resource with the textual editor, this error appears.
java.lang.RuntimeException: Could not serialize Greeting via backtracking.
Constraint: Greeting_Greeting returns Greeting: (name=ID condition?='condition'?);
Values: name(1), condition(1)
Semantic Object: Model.greetings[0]->Greeting'Eclipseee'
URI: temp.my
Context: Greeting returns Greeting
As explained previously here https://www.eclipse.org/forums/index.php?t=msg&th=1086278&goto=1763635&#msg_1763635
It is necessary to customize the MyDslTransientValueService by adding the following code.
class MyDslRuntimeModule extends AbstractMyDslRuntimeModule {
override Class<? extends ITransientValueService> bindITransientValueService() {
public class MyDslTransientValueService extends DefaultTransientValueService {
override boolean isTransient(EObject owner, EStructuralFeature feature, int index) {
if (feature == MyDslPackage.Literals.GREETING__CONDITION) {
var Boolean value = owner.eGet(feature) as Boolean;
if (value === null) {
return false;
} else if (value == Boolean.FALSE) {
return true;
return super.isTransient(owner, feature, index);
Therefore, this sub-problem is resolved.
2) when condition is true
This is the real problem.
If condition is true (shown by the emf editor), the "condition" keyword doesn't appear in the textual model.
In addition, when I try to add it manually, It is hidden during the save.
I saw that in the xmi, the condition attribute doesn't appear when it is true.
As explained in the EMF forum, to serialize the default value, it is necessary to customize the MyDslResourceImpl by overriding the doSave method as shown in the following.
public class MyDslResourceImpl extends XMIResourceImpl {
* Creates an instance of the resource.
* <!-- begin-user-doc -->
* <!-- end-user-doc -->
* @param uri the URI of the new resource.
* @generated
public MyDslResourceImpl(URI uri) {
super(uri);
public void doSave(OutputStream outputStream, Map<?,?> options) throws
IOException {
this.getDefaultSaveOptions().put(XMLResource.OPTION_KEEP_DEFAULT_CONTENT,
Boolean.TRUE);
super.doSave(outputStream, options);
} //MyDslResourceImpl
Consequently, the condition attribute is serialized when it is true.
However, the "condition" keyword doesn't appear in the textual model.
And, when I edit the textual model (add white space for example); during saving, the xmi is changed by removing condition="true" from the xmi.
To conclude, my questions are:
How can I show the "condition" keyword when the condition attribute is true?
How can I inhibit Xtext removing condition="true" from the xmi?
I added a demo in the attachment to more explain the issue.
I share Also the source code with an example project.
best regards,
Attachment: MyDslXtext.mov
(Size: 13.14MB, Downloaded 113 times)
Attachment: xtext.zip
(Size: 1.71MB, Downloaded 247 times)
Re: MyDslDocumentProvider failed to save [message #1764862 is a reply to message #1764809] |
Fri, 02 June 2017 12:02   |
I customize CustomLegacyTransientValueService like that
public class CustomLegacyTransientValueService extends LegacyTransientValueService {
public ValueTransient isValueTransient(EObject semanticObject, EStructuralFeature feature) {
if (feature.getName().equals("condition")) {
if (((Greeting) semanticObject).isCondition())
return ValueTransient.NO;
else
return ValueTransient.YES;
} else {
return super.isValueTransient(semanticObject, feature);
protected boolean defaultValueIsSerializeable(EStructuralFeature feature) {
return super.defaultValueIsSerializeable(feature);
I comment the following lines
//resourceSet.getResourceFactoryRegistry().getExtensionToFactoryMap().put("*", new XMIResourceFactoryImpl());
and
// static {
// MyDslStandaloneSetup.doSetup();
the following class CustomDefaultEcoreElementFactory, where must be localized?
I put it in org.xtext.example.mydsl.
is it correct?
import org.eclipse.emf.ecore.EClassifier;
import org.eclipse.emf.ecore.EObject;
import org.eclipse.xtext.parser.DefaultEcoreElementFactory;
import myDsl.Greeting;
public class CustomDefaultEcoreElementFactory extends DefaultEcoreElementFactory {
public EObject create(EClassifier classifier) {
EObject created = super.create(classifier);
if (created instanceof Greeting) {
((Greeting) created).setCondition(false);
return created;
I am very near to resolve the issue.
Actually, when I change from the emf model, the changes are propagated to the textual model (changing condition to true, "condition" keyword appears, changing condition to false, "condition" keyword removed).
The only issue at this moment, it that, when I remove "condition" keyword from my textual model, it reappears when I save.
If you reproduced my case study, can you please share the code after your customizations please?
Current Time: Sun Oct 19 05:12:54 EDT 2025
Powered by FUDForum. Page generated in 0.30056 seconds
