ScopeProvider and Linker [message #1763891] |
Mon, 22 May 2017 16:38  |
Fy Za Messages: 245 Registered: March 2010 |
Hi all
I have this metamodel
package fsm : fsm = 'http://fsm'
class FSM
property ownedState#owningFSM : State[*|1] { ordered composes };
class State
property owningFSM#ownedState : FSM[1];
attribute name : String[?];
property outgoingTransition#source : Transition[*|1] { ordered composes };
property incomingTransition#target : Transition[*|1] { ordered };
attribute initial : Boolean[1];
attribute final : Boolean[1];
class Transition
property source#outgoingTransition : State[1];
property target#incomingTransition : State[1];
attribute input : String[?];
attribute output : String[?];
primitive datatype _'String' : 'java.lang.String' { serializable };
I generate a Xtext grammar from this metamodel
// automatically generated by Xtext
grammar org.xtext.example.fsm.FSM with org.eclipse.xtext.common.Terminals
import "http://fsm"
import "http://www.eclipse.org/emf/2002/Ecore" as ecore
FSM returns FSM:
{FSM}
'FSM'
('ownedState' '{' ownedState+=State ( "," ownedState+=State)* '}' )?
State returns State:
initial?='initial'
final?='final'
'State'
('name' name=ID)?
('outgoingTransition' '{' outgoingTransition+=Transition ( "," outgoingTransition+=Transition)* '}' )?
Transition returns Transition:
'Transition'
('input' input=STRING)?
('output' output=STRING)?
'target' target=[State|ID]
In order to manage the eopposite relation target <--> incomingTransition
I create a FSMLinker class
public class FSMLinker extends LazyLinker {
protected EObject createProxy(EObject obj, INode node, EReference eRef) {
State s = (State) ((Transition)obj).eContainer();
FSM fsm = (FSM) s.eContainer();
for (State state : fsm.getOwnedState())
if(state.getName().equals(node.getText())){
return state;
return super.createProxy(obj, node, eRef);
I manage also the scope provider by editing FSMScopeProvider
class FSMScopeProvider extends AbstractFSMScopeProvider {
override getScope(EObject object, EReference ref) {
if (object instanceof Transition) {
scope_Transition_target(object as Transition, ref)
def scope_Transition_target(Transition transition, EReference reference) {
var ArrayList<IEObjectDescription> res = new ArrayList<IEObjectDescription>
var State s = transition.eContainer as State
var FSM fsm = s.eContainer as FSM
for (state : fsm.ownedState) {
res.add(EObjectDescription.create(state.name, state))
return new SimpleScope(IScope.NULLSCOPE, res)
When I create a model like this
FSM{
ownedState
initial final State { name s1 outgoingTransition {Transition {
input "did" output "aa" target s1
initial final State { name s2 }
no error is happened.
However, when i change the model to be like that
FSM{
ownedState
input "did" output "aa" target s2
An error appears
- The required feature 'target' of 'fsm.impl.TransitionImpl@58395231{platform:/resource/fsm/test.fsm#//@ownedState.0/@outgoingTransition.0}' must be set
Any suggestion?
Re: ScopeProvider and Linker [message #1763908 is a reply to message #1763896] |
Mon, 22 May 2017 19:07   |
well after installing and fiddling around with oclinecore the following seems to work
public class MyDslDerivedStateComputer implements IDerivedStateComputer {
@Inject
SyntheticLinkingSupport sls;
public void installDerivedState(DerivedStateAwareResource resource, boolean preLinkingPhase) {
if (!resource.getContents().isEmpty() && preLinkingPhase) {
FSM fsm = (FSM) resource.getContents().get(0);
for (State s : fsm.getOwnedState()) {
for (State ss : fsm.getOwnedState()) {
for (Transition t : ss.getOutgoingTransition()) {
List<INode> nodes = NodeModelUtils.findNodesForFeature(t, FsmPackage.Literals.TRANSITION__TARGET);
if (!nodes.isEmpty()) {
String text = nodes.get(0).getText().trim();
if (s.getName().equals(text)) {
final EObject proxy = EcoreUtil.create(FsmPackage.Literals.TRANSITION);
((InternalEObject) proxy).eSetProxyURI(EcoreUtil.getURI(t));
s.getIncomingTransition().add((Transition) proxy);
public void discardDerivedState(DerivedStateAwareResource resource) {
if (!resource.getContents().isEmpty()) {
s.getIncomingTransition().clear();
class MyDslRuntimeModule extends AbstractMyDslRuntimeModule {
def Class<? extends IDerivedStateComputer> bindIDerivedStateComputer() {
def Class<? extends Manager> bindIResourceDescription$Manager() {
DerivedStateAwareResourceDescriptionManager
override Class<? extends XtextResource> bindXtextResource() {
Twitter : @chrdietrich
Day Job: https://www.everest-systems.com
Re: ScopeProvider and Linker [message #1763920 is a reply to message #1763919] |
Tue, 23 May 2017 03:11   |
and i my unit test it works fine
* generated by Xtext 2.12.0-SNAPSHOT
package org.xtext.example.mydsl.tests
import com.google.inject.Inject
import fsm.FSM
import org.eclipse.xtext.testing.InjectWith
import org.eclipse.xtext.testing.XtextRunner
import org.eclipse.xtext.testing.util.ParseHelper
import org.eclipse.xtext.testing.validation.ValidationTestHelper
import org.junit.Assert
import org.junit.Test
import org.junit.runner.RunWith
import org.eclipse.emf.ecore.EPackage
import fsm.FsmPackage
import org.eclipse.emf.ecore.resource.impl.ResourceSetImpl
import org.eclipse.emf.common.util.URI
import java.io.ByteArrayOutputStream
import java.nio.charset.StandardCharsets
@RunWith(XtextRunner)
@InjectWith(MyDslInjectorProvider)
class MyDslParsingTest {
@Inject
ParseHelper<FSM> parseHelper
@Inject extension ValidationTestHelper h
@Test
def void loadModel() {
EPackage.Registry.INSTANCE.put(FsmPackage.eNS_URI, FsmPackage::eINSTANCE)
val result = parseHelper.parse('''
FSM{
ownedState
Assert.assertNotNull(result)
Assert.assertTrue(result.eResource.errors.isEmpty)
println(result.validate)
println('''
«FOR s : result.ownedState»
«s.name»:
«FOR t : s.outgoingTransition»
«t.target.name»
«ENDFOR»
«s.name»: «s.incomingTransition»
«ENDFOR»
val RS2 = new ResourceSetImpl
val r2 = RS2.createResource(URI.createURI("dummy.xmi"))
r2.contents.add(result)
val baos = new ByteArrayOutputStream
r2.save(baos, null)
println(new String(baos.toByteArray, StandardCharsets.UTF_8))
Re: ScopeProvider and Linker [message #1763946 is a reply to message #1763920] |
Tue, 23 May 2017 09:42   |
For me also the test is fine.
For the tested model
FSM{
ownedState
when, I test parse it, I obtain the correct xmi
<?xml version="1.0" encoding="ASCII"?>
<fsm:FSM xmi:version="2.0" xmlns:xmi="http://www.omg.org/XMI" xmlns:fsm="http://fsm">
<ownedState name="s1" initial="true" final="true">
<outgoingTransition target="//@ownedState.1" input="did" output="aa"/>
</ownedState>
<ownedState name="s2" incomingTransition="//@ownedState.0/@outgoingTransition.0" initial="true" final="true"/>
</fsm:FSM>
However, when I Run my toxmi method
I obtain the following without incomingTransition
</ownedState>
<ownedState name="s2" initial="true" final="true"/>
</fsm:FSM>
This is my code used to save as xmi.
public void run(IAction action) {
IFile file = getFile();
URI xtextURI = URI.createPlatformResourceURI(file.getFullPath().toString(), true);
XtextResourceSet resourceSet = new XtextResourceSet();
Resource xtextResource = resourceSet.createResource(xtextURI);
System.out.println(xtextURI.toString());
if (xtextResource != null){
Map<String,Boolean> options = new HashMap<String,Boolean>();
options.put(XtextResource.OPTION_RESOLVE_ALL, Boolean.TRUE);
try {
xtextResource.load(options);
} catch (IOException e1) {
e1.printStackTrace();
Resource xmiResource = new XMIResourceFactoryImpl().createResource(xtextURI.trimFileExtension().appendFileExtension("xmi"));
xmiResource.getContents().add(xtextResource.getContents().get(0));
EcoreUtil.resolveAll(resourceSet);
try {
xmiResource.save(null);
} catch (IOException e) {
e.printStackTrace();
}else{
ModelStatus sts = new ModelStatus(IStatus.ERROR, "org.eclipse.xtext.toXmi", "http://fsm", "Impossible to load the selected file for xmi conversion.\n" +
"Maybe this file is not an XText instance ? Status");
ErrorDialog.openError(shell, "Error", "Impossible to load the selected file for xmi conversion.\n" +
"Maybe this file is not an XText instance ?", sts);
Is it correct, PLZ ?
Re: ScopeProvider and Linker [message #1763964 is a reply to message #1763952] |
Tue, 23 May 2017 12:49   |
I update my toXmi class
Injector injector = FsmActivator.getInstance().getInjector("org.xtext.example.fsm.FSM");
XtextResourceSetProvider provider = injector.getInstance(XtextResourceSetProvider.class);
ResourceSet resourceSet = provider.get(file.getProject());
XtextResource xtextResource = (XtextResource) resourceSet.getResource(xtextURI, true);;
try {
try {
}else{
I obtain that
<outgoingTransition input="did" output="aa">
<target href="My.fsm#|0"/>
</outgoingTransition>
</ownedState>
</fsm:FSM>
No IncomingTransition and target reference is not correct.
Plz, Christian, Does exist an example that can be followed to create my own toxmi module for my dsl?
best regards
FUDForum. Page generated in 0.04546 seconds
