| Can't setup JSP debugging in Neon.3 with tomcat8 [message #1763355] |
Sat, 13 May 2017 05:42  |
Short story: We are migrating from Luna to neon.3 but we can not get JSP breakpoints to work properly
long story:
- installed neon.3 and added jdk1.8.0_131 as default Java runtime
- cleaned the luna workspace by removing all eclipse control files (settings, profiles, etc)
- added the old luna workspace as workspace for neon
- imported the old projects into neon
- added a new tomcat server in eclipse
- Added 2 projects (using Add external web module)
- Configure "Use tomcat installation"
- Start server in Debug mode
The webapplications startup as usual, the applications run as expected, no errors so far.
- In the JSP Editor open an existing JSP
- Set some test breakpoints (inside java code parts)
- From a browser call the jsp
Result: The jsp runs, no Stop at breakpoints.
- in the Java Editor open a java file
- Set some breakpoints in the java file
- Run the very same JSP again
Result: The Java breakpoints are recognized, the Debugger opens up
- Click through the debugger until the java code is done and return to JSP
Result: Source not found
- Trying various folders, as lookup, including the tomcat work folder, but can't get any source to show up.
Here we are stuck. It worked before in Luna without any need to do special configuration for getting JSP's to work with the debugger.
How can i debug this further to figure out why JSP breakpoints are not recognized and why JSP Sources are not found ?
thanks for any tip on that.
| Re: Can't setup JSP debugging in Neon.3 with tomcat8 [message #1763508 is a reply to message #1763492] |
Tue, 16 May 2017 15:15  |
Hello, all;
Many thanks for your suggestions!
I am sorry for my late response.
But for some reason i got the permission to reply in the forums only since today.
Luckily i got it to work after i did following changes:
- Updated to tomact 8.5.15
- Configured the Server entry to "Use tomcat installation"
- Removed the JRE runtime libraries from the projects and added them back (using the default java-8 libraries)
- Take care to only set breakpoints into java parts in the jsp.
- Double checked that the facets "java" and "Dynamic Web Module" where enabled (they where active)
I do not know which of the changes (or combination of changes) actually brought things back to work. But everything plays nicely again. So this issue is solved!
I noticed the breakpoints at declaration statements like for example: int x = 0; are still ignored, but that's ok for me. Possibly it has always been like that, i just never noticed before (we do not need to debug jsp's often).
fyi: Our project started about 16 years ago as a java-1.2 project. We switched to eclipse around 2006 but we kept the initial project structure intact as it was running stable since 4 years by then. In the following 11 years up til today we have been happy users of the eclipse environment. Thanks for everybody who contributed to Eclipse over the years!
kind regards,
Hussayn
FUDForum. Page generated in 0.48154 seconds
