Home » Modeling » TMF (Xtext) » Compare and merge/mark on Regeneration Xtext-Xtend(Compare and merge/mark on Regeneration Xtext-Xtend)
icon5.gif  Compare and merge/mark on Regeneration Xtext-Xtend [message #1762853] Fri, 12 May 2017 05:44 Go to next message
Rodrigue Sandio is currently offline Rodrigue SandioFriend
Hi All,
I recently made Xtext-Xtend app to generate C++ classes.
Some code needs to be typed externally, as for instance the implementation of functions.
However, whenever I regenerate the files all the manually written code is deleted.
Is there a way to Compare and Merge/Mark files when regenerating?
Re: Compare and merge/mark on Regeneration Xtext-Xtend [message #1762860 is a reply to message #1762853] Fri, 12 May 2017 05:47 Go to previous message
Christian Dietrich is currently offline Christian DietrichFriend
you ususally use the generation gap pattern for that. Abstract Generated Superclass, Subclass With Manual Code is Generated once. Xtext supports this by having different OutoutConfigurations.
if you really want protected regions you might need to port https://github.com/danieldietrich/xtext-protected-regions to the current version of xtext
Twitter : @chrdietrich
Day Job: https://www.everest-systems.com
Previous Topic:Cross Reference without additional feature
Next Topic:[SOLVED] Enable Java generation with a partial compilation
Current Time: Thu Dec 26 12:45:26 GMT 2024
Powered by FUDForum. Page generated in 0.03490 seconds
