Re: Eclipse & Suse 9.0 [message #176281 is a reply to message #176034] |
Tue, 06 January 2004 17:42 |
Originally posted by: chris.remove.nospam.occidopagus.nl
I have the same problem with Eclipse 2.1.2 (Build 200311030802) on Suse
9.0 using Sun Java2 SDK 1.4.2_03. I am using the GTK eclipse with KDE 3.1.
The shows up after installing the Sysdeo Eclipse/WSAD Tomcat plugin.
(http://www.sysdeo.com/eclipse/tomcatPlugin.html).
Leon Webster wrote:
> I installed eclipse 3.0 m6 on a system with Suse Linux 9.0 I am running KDE
> 3.1 on the desktop, but I installed the GTK2 libs when I installed Suse
> Linux.
> When I start Eclipse, I get an exception with the following stack trace:
> org.eclipse.swt.SWTException: Unsupported or unrecognized format
> at org.eclipse.swt.SWT.error(SWT.java:2592)
> at org.eclipse.swt.SWT.error(SWT.java:2522)
> at
> org.eclipse.swt.internal.image.FileFormat.load(FileFormat.ja va:73)
> at
> org.eclipse.swt.graphics.ImageLoader.load(ImageLoader.java:1 24)
> at org.eclipse.swt.graphics.ImageData.<init>(ImageData.java:308)
> Can anyone give me a hint about what I need to do to make Eclipse work under
> Suse 9.0? Is there a "readme" file for Suse that I have overlooked?
> Thanks much
> Leon Webster
Re: Eclipse & Suse 9.0 [message #176287 is a reply to message #176281] |
Tue, 06 January 2004 18:12 |
Sorry for my double post. I tried the 1.4.2_01 JVM by SUN. No plugins
installed this time. In the error occurred after opening the
File|New|Other dialog.
Here is my error log:
!SESSION Jan 06, 2004 19:06:20.712
java.version=1.4.2_01
BootLoader constants: OS=linux, ARCH=x86, WS=gtk, NL=en_US
Command-line arguments: -os linux -ws gtk -arch x86 -data
/home/chris/Documents/eclipse -install file:/opt/eclipse/
!ENTRY org.eclipse.jface 4 2 Jan 06, 2004 19:06:20.713
!MESSAGE Problems occurred when invoking code from plug-in:
"org.eclipse.jface".
!STACK 0
at org.eclipse.swt.SWT.error(SWT.java:2330)
at org.eclipse.swt.SWT.error(SWT.java:2260)
at org.eclipse.swt.internal.image.FileFormat.load(FileFormat.ja va:73)
at org.eclipse.swt.graphics.ImageLoader.load(ImageLoader.java:1 24)
at org.eclipse.swt.graphics.ImageData.<init>(ImageData.java:311)
at
org.eclipse.jface.resource.URLImageDescriptor.getImageData(U RLImageDescriptor.java:51)
at
org.eclipse.jface.resource.ImageDescriptor.createImage(Image Descriptor.java:118)
at
org.eclipse.jface.resource.ImageDescriptor.createImage(Image Descriptor.java:94)
at
org.eclipse.jface.resource.ImageDescriptor.createImage(Image Descriptor.java:83)
at
org.eclipse.ui.model.WorkbenchLabelProvider.getImage(Workben chLabelProvider.java:129)
at
org.eclipse.jface.viewers.TableViewer.doUpdateItem(TableView er.java:202)
at
org.eclipse.jface.viewers.StructuredViewer$UpdateItemSafeRun nable.run(StructuredViewer.java:119)
at
org.eclipse.core.internal.runtime.InternalPlatform.run(Inter nalPlatform.java:1006)
at org.eclipse.core.runtime.Platform.run(Platform.java:413)
at
org.eclipse.jface.viewers.StructuredViewer.updateItem(Struct uredViewer.java:1271)
at
org.eclipse.jface.viewers.TableViewer.internalRefresh(TableV iewer.java:494)
at
org.eclipse.jface.viewers.TableViewer.internalRefresh(TableV iewer.java:431)
at
org.eclipse.jface.viewers.StructuredViewer$7.run(StructuredV iewer.java:861)
at
org.eclipse.jface.viewers.StructuredViewer.preservingSelecti on(StructuredViewer.java:801)
at
org.eclipse.jface.viewers.StructuredViewer.refresh(Structure dViewer.java:859)
at
org.eclipse.jface.viewers.StructuredViewer.refresh(Structure dViewer.java:821)
at
org.eclipse.jface.viewers.TableViewer.inputChanged(TableView er.java:398)
at
org.eclipse.jface.viewers.ContentViewer.setInput(ContentView er.java:238)
at
org.eclipse.jface.viewers.StructuredViewer.setInput(Structur edViewer.java:991)
at
org.eclipse.ui.internal.dialogs.NewWizardNewPage.handleCateg orySelection(NewWizardNewPage.java:256)
at
org.eclipse.ui.internal.dialogs.NewWizardNewPage.selectionCh anged(NewWizardNewPage.java:334)
at org.eclipse.jface.viewers.Viewer$2.run(Viewer.java:159)
at
at org.eclipse.jface.viewers.Viewer.fireSelectionChanged(Viewer .java:157)
at
org.eclipse.jface.viewers.StructuredViewer.updateSelection(S tructuredViewer.java:1290)
at
org.eclipse.jface.viewers.StructuredViewer.handleSelect(Stru cturedViewer.java:657)
at
org.eclipse.jface.viewers.StructuredViewer$4.widgetSelected( StructuredViewer.java:681)
at
org.eclipse.jface.util.OpenStrategy.fireSelectionEvent(OpenS trategy.java:178)
at org.eclipse.jface.util.OpenStrategy.access$3(OpenStrategy.ja va:173)
at
org.eclipse.jface.util.OpenStrategy$1.handleEvent(OpenStrate gy.java:308)
at org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java :81)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:923)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.ja va:1847)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :1639)
at org.eclipse.jface.window.Window.runEventLoop(Window.java:583 )
at org.eclipse.jface.window.Window.open(Window.java:563)
at org.eclipse.ui.actions.NewWizardAction.run(NewWizardAction.j ava:136)
at org.eclipse.jface.action.Action.runWithEvent(Action.java:842 )
at
org.eclipse.jface.action.ActionContributionItem.handleWidget Selection(ActionContributionItem.java:456)
at
org.eclipse.jface.action.ActionContributionItem.handleWidget Event(ActionContributionItem.java:403)
at
org.eclipse.jface.action.ActionContributionItem.access$0(Act ionContributionItem.java:397)
at
org.eclipse.jface.action.ActionContributionItem$ActionListen er.handleEvent(ActionContributionItem.java:72)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:1402)
at org.eclipse.ui.internal.Workbench.run(Workbench.java:1385)
at
org.eclipse.core.internal.boot.InternalBootLoader.run(Intern alBootLoader.java:858)
at org.eclipse.core.boot.BootLoader.run(BootLoader.java:461)
at
at
at java.lang.reflect.Method.invoke(Method.java:324)
at org.eclipse.core.launcher.Main.basicRun(Main.java:291)
at org.eclipse.core.launcher.Main.run(Main.java:747)
at org.eclipse.core.launcher.Main.main(Main.java:583)
<<cut>>
Re: Eclipse & Suse 9.0 [message #176443 is a reply to message #176287] |
Wed, 07 January 2004 00:10 |
Originally posted by: info.oti.com
This is a FAQ:
< http://dev.eclipse.org/viewcvs/index.cgi/%7Echeckout%7E/plat form-swt-home/faq.html#konquerorUnzip>.
I found it by searching in Bugzilla for FileFormat.load. Take a look at
<https://bugs.eclipse.org/bugs/show_bug.cgi?id=39670> - in general, it
never hurts to search Bugzilla for something in the log to see if it's
been seen before.
Hope this helps!
Andrew Jr.
> !STACK 0
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> <<cut>>
FUDForum. Page generated in 0.03334 seconds
