Home » Modeling » TMF (Xtext) » Cross Reference
Cross Reference [message #1759457] Tue, 11 April 2017 12:11 Go to next message
MOJ Na is currently offline MOJ NaFriend
I do not know how cross reference works in the case that I want to use features of Actions rule in another rule.
Actions:
name=ID
(features+=Feature)
|(moves+=Move))
I would appreciate it if you could help me.
[Updated on: Tue, 11 April 2017 20:12]
Report message to a moderator
Re: Cross Reference [message #1759458 is a reply to message #1759457] Tue, 11 April 2017 20:12 Go to previous messageGo to next message
Christian Dietrich is currently offline Christian DietrichFriend
Hi I don't get the question. Can you please explain?
Twitter : @chrdietrich
Day Job: https://www.everest-systems.com
Re: Cross Reference [message #1759459 is a reply to message #1759458] Tue, 11 April 2017 20:29 Go to previous messageGo to next message
Ps maybe you are simply looking for
someRef=[Feature|FQN] ....;
FQN:ID ("." ID)*;
Re: Cross Reference [message #1759460 is a reply to message #1759458] Tue, 11 April 2017 12:44 Go to previous messageGo to next message
Sorry for the confusion. I have the following grammar:
Actions:
'Action' name=ID
((features+=Feature))*
'constraint' constraint= LiteralOrIdentifier
Feature:
'feature' ':' name+=ID;
LiteralOrIdentifier:
Literal
| Identifier;
Literal:
int=INT;
Identifier:
'feature' ref=[Feature];
Based on the above grammar, I expect the following text to be parsed correctly, but It gives me the error "could not resolve reference to feature Y"
Action test {
feature: X
feature : Y
constraint feature Y}
What I am missing?
Thank you very much for your help.
Re: Cross Reference [message #1759593 is a reply to message #1759459] Thu, 13 April 2017 14:15 Go to previous messageGo to next message
I have not been able to solve my problem yet. I am a beginner in Xtext, so I am not sure what I want to do is possible in Xtext . I tried "someRef=[Feature|FQN] ....,
FQN:ID ("." ID)*;", but I still get the same error.
What I should do?
Re: Cross Reference [message #1759599 is a reply to message #1759593] Thu, 13 April 2017 08:37 Go to previous messageGo to next message
the problem is the following:
you can reference things with a name only by default.
you feature does not have one (it has a list of names with always one element)
=> the easiest is to change to
Feature:
'feature' ':' name=ID;
Re: Cross Reference [message #1759611 is a reply to message #1759593] Thu, 13 April 2017 19:11 Go to previous messageGo to next message
Thank you very much. The problem is that I need to have a list of features and then reference them.
Re: Cross Reference [message #1759612 is a reply to message #1759611] Thu, 13 April 2017 19:18 Go to previous messageGo to next message
You have a list of features but you reference them one by one right?
Re: Cross Reference [message #1759656 is a reply to message #1759612] Fri, 14 April 2017 15:31 Go to previous messageGo to next message
Yes, that is what I am looking for
Re: Cross Reference [message #1759658 is a reply to message #1759656] Fri, 14 April 2017 15:58 Go to previous messageGo to next message
So Feature : ... name=ID will solve your problem
Re: Cross Reference [message #1759672 is a reply to message #1759658] Fri, 14 April 2017 23:27 Go to previous message
Thank you so much it solved my problem Smile
Previous Topic:Import issues regarding qualified names
Next Topic:Xtext and antlr4?
Current Time: Thu Jan 02 20:44:26 GMT 2025
Powered by FUDForum. Page generated in 0.03951 seconds
