Home » Eclipse Projects » Papyrus for Real Time » Problem with attaching Port to Capsule(Working through tutorial)
icon8.gif  Problem with attaching Port to Capsule [message #1759071] Wed, 05 April 2017 12:04 Go to next message
Cavan Watson is currently offline Cavan WatsonFriend
I think that I have managed to install Papyrus-RT (using the Testers Installer).
Everything was going well until I got to the part about adding a port to the Pinger capsule., the protocol selection dialog does not appear.
I can drag the protocol to the right-hand edge of the capsule diagram and create the port.
Is this a known issue or have I missed an installation step?
Thanks for your attention.
regards
Cavan
Re: Problem with attaching Port to Capsule [message #1759133 is a reply to message #1759071] Thu, 06 April 2017 10:33 Go to previous messageGo to next message
Christian Damus is currently offline Christian DamusFriend
Hi, Cavan,
Are you running Windows 10 on a laptop with a touch display? See the release note on the subject.
HTH,
Christian
Re: Problem with attaching Port to Capsule [message #1759818 is a reply to message #1759071] Tue, 18 April 2017 16:46 Go to previous message
Ernesto Posse is currently offline Ernesto PosseFriend
FYI, the Tester installer will get you the nightly build, so it is less stable than the release [1].
[1] https://www.eclipse.org/papyrus-rt/content/download.php.
Previous Topic:How to add Multiple Triggers & How to avoid multiple Transitions (same source to same target)
Next Topic:Request to evaluate our model validation plug-in for Papyrus-RT
Current Time: Thu Dec 26 12:32:43 GMT 2024
Powered by FUDForum. Page generated in 0.03939 seconds
