Home » Modeling » TMF (Xtext) » XText grammar with lookbehind
XText grammar with lookbehind [message #1756248] Tue, 14 March 2017 09:41 Go to next message
I am new in developing a DSL using XText and I am currently stuck in a problem.
I have to parse a file which contains elements called Class and might look like this:
A {
B, //this comma is needed
C,
D {E}, //comma is optional after a closing curly brace
F {G}
H
I,
J
As you can see, a comma is a must after a class without subclasses (those enclosed by curly brackets) when another class follows. Otherwise, the comma is optional.
My current (wrong) solution is:
Model: (classes += Class)*
Class: name = ID ('{' (subclasses += Class) (',' subclasses += Class)* '}')?
Sadly, this works only when the comma is a must in any case. I believe the grammar should express the following structure:
Class: ID (',' Class | '{' subclasses += Class '}' ','? Class)?
Of course, that does not work since I need to assign the return value of Class to the subclasses of the parent. After some looking around different blogs, I belive that using a lookbehind would be a solution. However, I havn't found a way to express this in XText.
Is there a solution or a workaround for this issue?
Thanks in advance
Stephan
Re: XText grammar with lookbehind [message #1756272 is a reply to message #1756248] Tue, 14 March 2017 14:51 Go to previous message
Did you try something like
Model:
	((classes+=ClassWithBraces|classes+=ClassWithComma)* classes+=ClassAtEnd?);
ClassWithComma returns Class:
	name=ID ","
ClassWithBraces returns Class:
	name=ID =>("{" ((classes+=ClassWithBraces|classes+=ClassWithComma)* classes+=ClassAtEnd?) "}") ","?
ClassAtEnd returns Class:
	name=ID
(you may need to add a validation if you dont want a "," at the very end
[Updated on: Tue, 14 March 2017 15:11] by Moderator
Previous Topic:2 OutputConfiguration's on Idea with Error
Next Topic:Maven not able to find MWE2 file referred by unit tests.
Current Time: Wed Sep 17 23:41:14 EDT 2025
Powered by FUDForum. Page generated in 0.03378 seconds
