Home » Eclipse Projects » Model Driven Health Tools » Meaningful Use 2015(Support of 1.1 and 2.1 CDA formats)
Meaningful Use 2015 [message #1740112] Tue, 09 August 2016 11:44 Go to next message
nm anand is currently offline nm anandFriend
We used MDHT Java APIs for Meaningful Use 2 to support CDA1.1 requirements. Now we need to support both CDA1.1 and CDA2.1 for Meaningful Use 2015.
Is this a good and stable release to download?
https://github.com/mdht/mdht-models/releases/tag/v2.5.16.20160725_Consol2
Also does this support both 1.1. and 2.1 formats?
Anand
Re: Meaningful Use 2015 [message #1740134 is a reply to message #1740112] Tue, 09 August 2016 14:20 Go to previous messageGo to next message
Dan Brown is currently offline Dan BrownFriend
Hi Anand,
The release is stable and is live in SITE and ETT.
It does support R2.1 and R1.1. However, it will not support R1.1 with MU2 requirements on top of it at this time. In order to accomplish that you would need the latest consol1 release (https://github.com/mdht/mdht-models/releases/tag/v2.5.8.20160323_Consol1).
Dan
Re: Meaningful Use 2015 [message #1740183 is a reply to message #1740134] Wed, 10 August 2016 08:33 Go to previous messageGo to next message
Thanks Dan. A followup question:
Q. The requirement in MU2015 cert is the following:
- Create R2.1 CDA doc
- Read and incorporate R1.1 CDA doc (with MU2 requirements) and R2.1 CDA doc
As we won't be able to use two MDHT versions in one build. Can you suggest which of the following MDHT versions to use?
Narinder
[Updated on: Thu, 11 August 2016 05:17]
Report message to a moderator
Re: Meaningful Use 2015 [message #1755972 is a reply to message #1740183] Thu, 09 March 2017 16:24 Go to previous message
Hi Narinder. Sorry I did not see this reply. It seems the forum subscription is only emailing me new posts and no further actions within a post.
Anyway, things have changed for the better so only one build (and one consol jar (consol2) is required now for R2.1/R1.1/MU2).
Use the latest release here https://github.com/mdht/mdht-models/releases/ and see this post for the answers on how to incorporate it in your application:
https://www.eclipse.org/forums/index.php/m/1755970/#msg_1755970
Dan
Previous Topic:Help on getting started with MDHT
Next Topic:Create CDA R1.1 and R2.1
Current Time: Fri Dec 27 03:31:47 GMT 2024
Powered by FUDForum. Page generated in 0.44393 seconds
