Multiple Inheritance in UML Profile [message #1753981] |
Mon, 13 February 2017 16:21 |
Hi there,
We currently have a problem related to modeling multiple inheritance using Papyrus creating an UML profile.
As shown in screenshot provided, we created three Stereotypes S1, S2 and S3 (base class UML::Class). When we want to create a UML model and try to apply S2 to a Class, nothing happens.
Please advise, minimal example provided.
Will
Research Associate
Department of Computer Science
University of York
Re: Multiple Inheritance in UML Profile [message #1753990 is a reply to message #1753981] |
Mon, 13 February 2017 16:54 |
In fact, you have fin a a bug: may be due to ecore
when you create a stereotype a property named base_<metaclass> is created in the stereotype.
In your case S3 inherits form S1 and S2. So by inheritance it references 2 properties named base_class.
In order to run you profile we must delegate to EMF ecore a profile definition ( a generation of a ecore model) But ecore does not like that S3 reference 2 references with the same name. So it named the Eref as S2_base_class. and this is the problem.
Rename this ereference and it runs
Could you add this problem in the papyrus bugzilla, please.
Could you add this problem with ecore it in the bugzilla please.
<uml:Profile xmi:version="20131001" xmlns:xmi="http://www.omg.org/spec/XMI/20131001" xmlns:ecore="http://www.eclipse.org/emf/2002/Ecore" xmlns:uml="http://www.eclipse.org/uml2/5.0.0/UML" xmi:id="_PSN_8PH_Eeavesbv6PLofw" name="RootElement" metaclassReference="_Z0CY4PH_Eeavesbv6PLofw">
<eAnnotations xmi:id="_brWf0fH_Eeavesbv6PLofw" source="http://www.eclipse.org/uml2/2.0.0/UML">
<contents xmi:type="ecore:EPackage" xmi:id="_9LSZUPIKEeabIfKVa3jbNw" name="RootElement" nsURI="http:///schemas/RootElement/_9LIoUPIKEeabIfKVa3jbNw/1" nsPrefix="RootElement">
<eAnnotations xmi:id="_9LWDsPIKEeabIfKVa3jbNw" source="PapyrusVersion">
<details xmi:id="_9LWDsfIKEeabIfKVa3jbNw" key="Version" value="0.0.2"/>
<details xmi:id="_9LWDsvIKEeabIfKVa3jbNw" key="Comment" value=""/>
<details xmi:id="_9LWDs_IKEeabIfKVa3jbNw" key="Copyright" value=""/>
<details xmi:id="_9LWDtPIKEeabIfKVa3jbNw" key="Date" value="2017-02-13"/>
<details xmi:id="_9LWDtfIKEeabIfKVa3jbNw" key="Author" value=""/>
</eAnnotations>
<eClassifiers xmi:type="ecore:EClass" xmi:id="_9LSZUfIKEeabIfKVa3jbNw" name="S1">
<eAnnotations xmi:id="_9LSZUvIKEeabIfKVa3jbNw" source="http://www.eclipse.org/uml2/2.0.0/UML" references="_XZQYgPH_Eeavesbv6PLofw"/>
<eStructuralFeatures xmi:type="ecore:EReference" xmi:id="_9LSZU_IKEeabIfKVa3jbNw" name="base_Class" ordered="false" lowerBound="1">
<eType xmi:type="ecore:EClass" href="http://www.eclipse.org/uml2/5.0.0/UML#//Class"/>
</eStructuralFeatures>
</eClassifiers>
<eClassifiers xmi:type="ecore:EClass" xmi:id="_9LSZVfIKEeabIfKVa3jbNw" name="S2">
<eAnnotations xmi:id="_9LSZVvIKEeabIfKVa3jbNw" source="http://www.eclipse.org/uml2/2.0.0/UML" references="_X5TxkPH_Eeavesbv6PLofw"/>
<eStructuralFeatures xmi:type="ecore:EReference" xmi:id="_9LSZV_IKEeabIfKVa3jbNw" name="base_Class" ordered="false" lowerBound="1">
<eAnnotations xmi:id="_9LSZWPIKEeabIfKVa3jbNw" source="redefines" references="_9LSZU_IKEeabIfKVa3jbNw"/>
</eClassifiers>
<eClassifiers xmi:type="ecore:EClass" xmi:id="_9LSZWvIKEeabIfKVa3jbNw" name="S3" eSuperTypes="_9LSZUfIKEeabIfKVa3jbNw _9LSZVfIKEeabIfKVa3jbNw">
<eAnnotations xmi:id="_9LSZW_IKEeabIfKVa3jbNw" source="http://www.eclipse.org/uml2/2.0.0/UML" references="_YVW0YPH_Eeavesbv6PLofw"/>
</eClassifiers>
</contents>
</eAnnotations>
<elementImport xmi:id="_Z0CY4PH_Eeavesbv6PLofw" alias="Class">
<importedElement xmi:type="uml:Class" href="pathmap://UML_METAMODELS/UML.metamodel.uml#Class"/>
</elementImport>
<packagedElement xmi:type="uml:Stereotype" xmi:id="_XZQYgPH_Eeavesbv6PLofw" name="S1">
<ownedAttribute xmi:id="_apv44fH_Eeavesbv6PLofw" name="base_Class" association="_apvR0PH_Eeavesbv6PLofw">
<type xmi:type="uml:Class" href="pathmap://UML_METAMODELS/UML.metamodel.uml#Class"/>
</ownedAttribute>
</packagedElement>
<packagedElement xmi:type="uml:Stereotype" xmi:id="_X5TxkPH_Eeavesbv6PLofw" name="S2">
<ownedAttribute xmi:id="_aQY9sfH_Eeavesbv6PLofw" name="base_Class" association="_aQYWoPH_Eeavesbv6PLofw">
</ownedAttribute>
</packagedElement>
<packagedElement xmi:type="uml:Stereotype" xmi:id="_YVW0YPH_Eeavesbv6PLofw" name="S3">
<generalization xmi:id="_bAp9APH_Eeavesbv6PLofw" general="_XZQYgPH_Eeavesbv6PLofw"/>
<generalization xmi:id="_bU4gkPH_Eeavesbv6PLofw" general="_X5TxkPH_Eeavesbv6PLofw"/>
</packagedElement>
<packagedElement xmi:type="uml:Extension" xmi:id="_aQYWoPH_Eeavesbv6PLofw" name="E_S2_Class1" memberEnd="_aQY9sPH_Eeavesbv6PLofw _aQY9sfH_Eeavesbv6PLofw">
<ownedEnd xmi:type="uml:ExtensionEnd" xmi:id="_aQY9sPH_Eeavesbv6PLofw" name="extension_S2" type="_X5TxkPH_Eeavesbv6PLofw" aggregation="composite" association="_aQYWoPH_Eeavesbv6PLofw"/>
</packagedElement>
<packagedElement xmi:type="uml:Extension" xmi:id="_apvR0PH_Eeavesbv6PLofw" name="E_S1_Class1" memberEnd="_apv44PH_Eeavesbv6PLofw _apv44fH_Eeavesbv6PLofw">
<ownedEnd xmi:type="uml:ExtensionEnd" xmi:id="_apv44PH_Eeavesbv6PLofw" name="extension_S1" type="_XZQYgPH_Eeavesbv6PLofw" aggregation="composite" association="_apvR0PH_Eeavesbv6PLofw"/>
</packagedElement>
</uml:Profile>
FUDForum. Page generated in 0.03355 seconds
