Re: Git Clone & Project Import Won't Run Automatically [message #1753521 is a reply to message #1753484] |
Tue, 07 February 2017 12:04 |
Ingo Mohr Messages: 23 Registered: September 2011 |
Ed,
thank you for the quick reply.
> When you created this product installation with the installer, did you use the advanced mode of the
> installer to select the project setup(s) that you say you also tried to add manually using "Import > > Projects..."?
Yes, I invoked the same project setup via "Import Projects..." that I selected in the advanced mode of the installer.
The installer installed everything else defined by that project setup. Just the Git-Clone and Project Import from that project setup
were missing.
> You say you manually triggered "Import Projects..." but you could only add a project if it wasn't already present
> , and of course if the project isn't already present/referenced, the tasks it specifies won't be performed until
> that's the case. So to me it sounds like you created purely an installation, without also creating a workspace
> that references projects. I.e., when you launch your product the first time, use
> Navigate -> Open Setup -> Workspace (to open the workspace.setup), and look at the properties view
> of the Workspace root object, does the Streams property show any values?
No, "Streams" has no value. Only "Name" and "Qualified Name" have a value - which is just "workspace".
I'll check the workspace setup bit. Seems to be the key problem.
(The product is defined to always ask for a workspace on startup using a dialog.)
Thank you so far.
FUDForum. Page generated in 0.05015 seconds
