Home » Modeling » GMF (Graphical Modeling Framework) » Creating Elliptical Shape
Re: Creating Elliptical Shape [message #174272 is a reply to message #174150] |
Mon, 25 February 2008 16:37   |
Originally posted by: trommas.yahoo.com
Toyin Fakorede wrote:
> Hi Tomas,
> Many thanks for your help, Tomas. I tried your advice and it worked.
> Going a step further, what if I want to create an unusual/irregular
> shape like - a cloud. How do I go about it?
> I realized that creating other shapes will involve modifying the
> properties of other shapes e.g rectangle, polygons, ellipse e.t.c But
> creating a cloud, Im not sure if I can modify other predefined shapes.
> Please, what do I do?
You have two options:
1. Create your customshape with template points in the graph, or by code
like below.
In class: xyzEditPart
public class xyzNodeFigure extends Shape {
public xyzNodeFigure() {
this.setLayoutManager(new StackLayout()); this.addPoint(new
Point(getMapMode().DPtoLP(50), getMapMode().DPtoLP(0)));
this.addPoint(new Point(getMapMode().DPtoLP(100),
getMapMode().DPtoLP(50)));
this.addPoint(new Point(getMapMode().DPtoLP(50),
getMapMode().DPtoLP(100)));
this.addPoint(new Point(getMapMode().DPtoLP(0),
this.setForegroundColor(ColorConstants.black);
this.setBackgroundColor(ColorConstants.green);
createContents();
2. Since the above 2D method is unsuited to figures like a cloud - you
could use an svg image. That process is described here:
http://wiki.eclipse.org/GMF_Tutorial_BPMN#Custom_Figures_.28 SVG.29
If you need to create the figure from scratch, Incscape is a great tool.
Hope this helps,
Tomas Zijdemans
Re: Creating Elliptical Shape [message #174989 is a reply to message #174272] |
Fri, 29 February 2008 09:43   |
Hi Tomas,
Thanks for your responses.
I tried using inkscape and followed the BPMN tutorial. However, I got some
errors.
Im posting the java code for you to view, just incase you find any errors:
The protected IFigure createNodeShape() is the method thats giving errors.
Please, I need your help. Thanks
package classmodel.diagram.edit.parts;
import org.eclipse.draw2d.IFigure;
import org.eclipse.draw2d.PositionConstants;
import org.eclipse.draw2d.StackLayout;
import org.eclipse.draw2d.geometry.Dimension;
import org.eclipse.gef.EditPart;
import org.eclipse.gef.EditPolicy;
import org.eclipse.gef.Request;
import org.eclipse.gef.commands.Command;
import org.eclipse.gef.editpolicies.LayoutEditPolicy;
import org.eclipse.gef.editpolicies.NonResizableEditPolicy;
import org.eclipse.gef.requests.CreateRequest;
import
org.eclipse.gmf.runtime.diagram.ui.editparts.AbstractBordere dShapeEditPart;
import org.eclipse.gmf.runtime.diagram.ui.editparts.IBorderItemEdit Part;
import
org.eclipse.gmf.runtime.diagram.ui.editpolicies.BorderItemSe lectionEditPolicy;
import org.eclipse.gmf.runtime.diagram.ui.editpolicies.EditPolicyRo les;
import org.eclipse.gmf.runtime.diagram.ui.figures.BorderItemLocator ;
import
org.eclipse.gmf.runtime.draw2d.ui.render.figures.ScalableIma geFigure;
import org.eclipse.gmf.runtime.gef.ui.figures.DefaultSizeNodeFigure ;
import org.eclipse.gmf.runtime.gef.ui.figures.NodeFigure;
import org.eclipse.gmf.runtime.notation.View;
import classmodel.diagram.edit.policies.ClassItemSemanticEditPolicy ;
import classmodel.diagram.part.ClassModelVisualIDRegistry;
* @generated
public class ClassEditPart extends AbstractBorderedShapeEditPart {
* @generated
public static final int VISUAL_ID = 1001;
* @generated
protected IFigure contentPane;
* @generated
protected IFigure primaryShape;
* @generated
public ClassEditPart(View view) {
super(view);
* @generated
protected void createDefaultEditPolicies() {
super.createDefaultEditPolicies();
installEditPolicy(EditPolicyRoles.SEMANTIC_ROLE,
new ClassItemSemanticEditPolicy());
installEditPolicy(EditPolicy.LAYOUT_ROLE, createLayoutEditPolicy());
// XXX need an SCR to runtime to have another abstract superclass that
would let children add reasonable editpolicies
removeEditPolicy(org.eclipse.gmf.runtime.diagram.ui.editpoli cies.EditPolicyRoles.CONNECTION_HANDLES_ROLE);
* @generated
protected LayoutEditPolicy createLayoutEditPolicy() {
LayoutEditPolicy lep = new LayoutEditPolicy() {
protected EditPolicy createChildEditPolicy(EditPart child) {
if (child instanceof IBorderItemEditPart) {
return new BorderItemSelectionEditPolicy();
EditPolicy result = child
.getEditPolicy(EditPolicy.PRIMARY_DRAG_ROLE);
if (result == null) {
result = new NonResizableEditPolicy();
return result;
protected Command getMoveChildrenCommand(Request request) {
return null;
protected Command getCreateCommand(CreateRequest request) {
return null;
return lep;
* @generated NOT
protected IFigure createNodeShape() {
URL url =
FileLocator.find(ClassModelDiagramEditorPlugin.getInstance() .getBundle(),
new Path("images/Cloud.svg"), null); //$NON-NLS-1$
return new ScalableImageFigure(RenderedImageFactory.getInstance(url),
true, true, true);
* @generated
public ScalableImageFigure getPrimaryShape() {
return (ScalableImageFigure) primaryShape;
* @generated
protected void addBorderItem(IFigure borderItemContainer,
IBorderItemEditPart borderItemEditPart) {
if (borderItemEditPart instanceof ClassNameEditPart) {
BorderItemLocator locator = new BorderItemLocator(getMainFigure(),
PositionConstants.SOUTH);
locator.setBorderItemOffset(new Dimension(-20, -20));
borderItemContainer.add(borderItemEditPart.getFigure(), locator);
} else {
super.addBorderItem(borderItemContainer, borderItemEditPart);
* @generated
protected NodeFigure createNodePlate() {
DefaultSizeNodeFigure result = new DefaultSizeNodeFigure(getMapMode()
.DPtoLP(40), getMapMode().DPtoLP(40));
return result;
* Creates figure for this edit part.
* Body of this method does not depend on settings in generation model
* so you may safely remove <i>generated</i> tag and modify it.
* @generated
protected NodeFigure createMainFigure() {
NodeFigure figure = createNodePlate();
figure.setLayoutManager(new StackLayout());
IFigure shape = createNodeShape();
figure.add(shape);
contentPane = setupContentPane(shape);
return figure;
* Default implementation treats passed figure as content pane.
* Respects layout one may have set for generated figure.
* @param nodeShape instance of generated figure class
* @generated
protected IFigure setupContentPane(IFigure nodeShape) {
return nodeShape; // use nodeShape itself as contentPane
* @generated
public IFigure getContentPane() {
if (contentPane != null) {
return contentPane;
return super.getContentPane();
* @generated
public EditPart getPrimaryChildEditPart() {
return getChildBySemanticHint(ClassModelVisualIDRegistry
.getType(ClassNameEditPart.VISUAL_ID));
Re: Creating Elliptical Shape [message #175462 is a reply to message #175385] |
Tue, 04 March 2008 06:52   |
Which version of GMF are you using, and what URL class is imported? (you'll
need java.net.URL)
This code works fine with the latest GMF:
URL url = FileLocator.find(Activator.getDefault().getBundle(), new
Path("images" + IPath.SEPARATOR + "ievent.svg"), null);
return new
ScalableImageFigure(RenderedImageFactory.getInstance(url), true, true,
true);
On 3/4/08 4:51 AM, in article
62ec7bec8c81efd3fc5c6af716d8d6b8$1@www.eclipse.org, "Toyin Fakorede"
<fakoredejohnson5@yahoo.com> wrote:
> Hi QiuluYUAN,
> I'm having problems with this line of code:
> true, true, true);
> The error message being displayed is - The method getInstance(URL) is
> undefined for the type RenderedImageFactory.
> Please, help.
> Or could u mail me your source code for the xxxEditPart.java file.
> Thanks.
> Toyin
Re: Creating Elliptical Shape [message #175501 is a reply to message #175385] |
Tue, 04 March 2008 08:25   |
Originally posted by: yuanqiulu.163.com
The problem I mentioned above has been solved this afternoon.
The following are my codes(EmptyEditPart.java):
package webapplication.diagram.edit.parts;
import java.net.URL;
import org.eclipse.core.runtime.FileLocator;
import org.eclipse.core.runtime.Path;
import org.eclipse.gmf.runtime.diagram.ui.editparts.ShapeNodeEditPa rt;
import org.eclipse.gmf.runtime.draw2d.ui.figures.ConstrainedToolbar Layout;
import org.eclipse.gmf.runtime.draw2d.ui.figures.WrapLabel;
import
org.eclipse.gmf.runtime.draw2d.ui.render.factory.RenderedIma geFactory;
import
import
webapplication.diagram.edit.policies.ClientBrowserItemSemant icEditPolicy;
import webapplication.diagram.part.WebApplicationDiagramEditorPlugi n;
import webapplication.diagram.part.WebApplicationVisualIDRegistry;
* @generated
public class ClientBrowserEditPart extends ShapeNodeEditPart {
* @generated
public static final int VISUAL_ID = 2001;
* @generated
* @generated
* @generated
public ClientBrowserEditPart(View view) {
super(view);
* @generated
new ClientBrowserItemSemanticEditPolicy());
* @generated
return result;
return null;
return null;
return lep;
* @generated
URL url = FileLocator.find(WebApplicationDiagramEditorPlugin
.getInstance().getBundle(), new Path("icons/invoke.svg"), null);
true, true, true);
* @generated
* @generated
private org.eclipse.gmf.runtime.draw2d.ui.figures.WrapLabel
fClientBrowserNameFigure;
* @generated
protected boolean addFixedChild(EditPart childEditPart) {
fClientBrowserNameFigure = new WrapLabel();
if (childEditPart instanceof ClientBrowserNameEditPart) {
((ClientBrowserNameEditPart) childEditPart)
.setLabel(fClientBrowserNameFigure);
return true;
return false;
* @generated
protected boolean removeFixedChild(EditPart childEditPart) {
return false;
* @generated
return result;
* @generated
protected NodeFigure createNodeFigure() {
figure.add(shape);
return figure;
* @generated
if (nodeShape.getLayoutManager() == null) {
ConstrainedToolbarLayout layout = new ConstrainedToolbarLayout();
layout.setSpacing(getMapMode().DPtoLP(5));
nodeShape.setLayoutManager(layout);
* @generated
return contentPane;
* @generated
return getChildBySemanticHint(WebApplicationVisualIDRegistry
.getType(ClientBrowserNameEditPart.VISUAL_ID));
* @generated
protected void addChildVisual(EditPart childEditPart, int index) {
if (addFixedChild(childEditPart)) {
return;
super.addChildVisual(childEditPart, -1);
* @generated
protected void removeChildVisual(EditPart childEditPart) {
if (removeFixedChild(childEditPart)) {
return;
super.removeChildVisual(childEditPart);
* @generated
public class ClientBrowserFigure extends
org.eclipse.draw2d.RectangleFigure {
* @generated
public ClientBrowserFigure() {
this.setFill(true);
this.setFillXOR(false);
this.setOutline(true);
this.setOutlineXOR(false);
this.setLineWidth(1);
this.setLineStyle(org.eclipse.draw2d.Graphics.LINE_SOLID);
createContents();
* @generated
private void createContents() {
clientBrowserNameFigure0 = new
org.eclipse.gmf.runtime.draw2d.ui.figures.WrapLabel();
clientBrowserNameFigure0.setText("<...>");
this.add(clientBrowserNameFigure0);
setFigureClientBrowserNameFigure(clientBrowserNameFigure0);
* @generated
private void setFigureClientBrowserNameFigure(
org.eclipse.gmf.runtime.draw2d.ui.figures.WrapLabel fig) {
fClientBrowserNameFigure = fig;
* @generated
private boolean myUseLocalCoordinates = false;
* @generated
protected boolean useLocalCoordinates() {
return myUseLocalCoordinates;
* @generated
protected void setUseLocalCoordinates(boolean useLocalCoordinates) {
myUseLocalCoordinates = useLocalCoordinates;
Re: Creating Elliptical Shape [message #175951 is a reply to message #175501] |
Thu, 06 March 2008 05:30   |
Many thanks for your code and help so far.
I tried the codes, I cant just place the problem. When I used this code:
URL url = FileLocator.find(ShapeDiagramEditorPlugin
getInstance().getBundle(), new Path("images/cloud.svg"), null);
true, true, true);
It kept underlining the getInstance(url) saying that it's undefined for
When I used an alternative code:
protected IFigure createNodeShape() {URL url =
FileLocator.find(Activator.getDefault().getBundle(), new Path("images" +
IPath.SEPARATOR + "cloud.svg"), null);
return new
true);
I got 2 errors: 1. The method getDefault() is undefined for the type
Activator.
2. getInstance(url) is undefined for the type RenderedImageFactory.
Please, what further advise can you give.
Im using GMF version 2.0.1.v20071003 - 0000 Build id: 2.1M2
Thank you.
Current Time: Thu Apr 24 03:05:24 EDT 2025
Powered by FUDForum. Page generated in 0.05143 seconds
